Chiltern MK5s Starting 2026 (non speculative updates thread)
sjpowermac
26 May 2018
Out of pure curiosity. Could a 37 technically be upgraded to be controlled from a Mk5 rake?
Given enough money, most things are possible. It has been a hard enough job though making the Class 68s work with Mk5A without starting out with a different class of loco;)
camerar1
21 May 2009
68026 now in Chiltern scheme, took set TP03 (to be CH03) into Eastleigh Works today. It then collected set CH06 and removed it to the T&RSMD.
Photo coverage.
The exile
31 Mar 2010
Somerset
If there is a daily path to/from Eastleigh, wouldn't it be a more ethical Carbon if it was run in passenger service?
(This probably has potential for a speculative discussion thread across all stock moves for maintenance.)
There might be a daily path available - but that doesn’t mean the train will run daily. Even if it did, running it in service would mean it couldn’t run early - and would need different crewing arrangements.
fgwrich
15 Apr 2009
Hampshire
Another set has been delivered to Eastleigh tonight behind 37884. This time it was one of the sets left at Longsight which has been taken south (CH3 or CH11).
warwickshire
6 Feb 2020
leamingtonspa
It was CH11, CH03 was taken, on Friday 31st October 2025, by 37800,
Only unbranded set CH08 remains at Longsight with 68019, 68023,
Its possible 68019 68023 are now off lease, or awaiting modifications, or acceptance to chiltern, and could well be moved to Leicester Loughbourgh Works, or Eastleigh Works, by a move in the near future, to prepare entry for Chiltern use.
because likewise with these, two locomotoives above, one of them would have done the above move today.
Usually up until Around Late July 2025, from around mid May 2024 those two undbranded 68s, was reqular locomotives on the Longsight to Long Marston Mk5 runs,
Meanwhile
0Z21 0718 Crewe Drs Depot to Eastliegh
Saw 68021 unbranded being transferred over today as well, which was undertaken by Drs.
Peter Sarf
Croydon
Looks to be TP08 11 according to this :-
37884 GROG LSIGHTDMD 325Q871I07 V * ELGHARLTN N
With consist
11508 12722 12723 12724 12808
Dan
UPDATE 09/11/2025
Sytems now showing set 11 no longer 08.
PLY2AYS
26 Mar 2024
Montserrat
One of the new vinyled locos is currently at Aylesbury getting tires turned I believe.
Will report back when I find out more. One was detached and replaced by the unvinyled loco at Wembley on one of the Mk V sets yesterday. So I imagine it will be that loco with a DVT.
*EDIT: confirmed to be 68022
Peter Sarf
Croydon
It was CH11, witnessed it at Lapworth Warwickshire directly behind
6X01 1018 Scunthorpe to Eastleigh Gbrf service, consiting of 66799, 66790, 66206 ,
A eventful 5 minutes just after 1600 pm,
I guess maybe TP08 was entered on the system but then TP11 was substituted ?.
Istr these were the only two sets at Longsight.
UPDATE 09/11/2025
Confirmed set 11, apparently the system has been updated since the original request for info.
I suppose a late change of plan.
PLY2AYS
26 Mar 2024
Montserrat
68022 was conducted off of Aylesbury depot this evening, with a Mk3 coach and 68014 (HVO Green vinyl) leading towards Wembley Depot via Princes Risborough
(My first time in a Class 68 and infinitely more techy than the Class 43s I used to drive)
Photo below shows 68022 Number 1 (north) end with rear tail lights lit in Headshunt 1 at Aylesbury Depot. Taken of course, from a position of safety:
amazon1675
23 Oct 2016
37800 plus CH08 at Eastleigh this evening forming 5Q86 09.27 Longsight-Eastleigh Works.This just leaves CH01 at Wolverton Works to come south.
alanc
19 Jul 2020
kennington
Can anyone please advise when sets CH04 and CH07 arrived at Eastleigh ?
Many thanks
Can someone please advise when CH04 and CH07 moved to Eastleigh?
MTIA
wickham
3 Feb 2021
Knaphill
Many thanks
MTIA
I have CH04 arriving Eastleigh 30.09.25 and CH07 22.09.25:
172007
2 Jan 2021
West Mids
So if understand this right Chiltern have all sets except TP01/CH01 which is at Wolverton. Potentialy in December all 13 sets will be available for Training / service except for ones on routine maintenance at Eastleigh.
Whats the status of the 68's. All have noise abatement modifications or are some still at Loughborough or need arrive there.
Very impressive of Chiltern if this is the case.
BanburyBlue
18 May 2015
Interesting. My office overlooks Birmingham Snow Hill station. The only trains I can ever ‘hear’ are 68’s. I always try and bag a desk by the window overlooking the north end of the station. Of course, I get stuck into work so head down. The only time a train comes to my attention is a 68 - and I’m on the 13th floor!
172007
2 Jan 2021
West Mids
Try and listen out for the difference in sound beteen the ex TPE vs current Chiltern 68's. One of the current mk3 68's appears to have the mod too so assume that was the trial loco.
They still are loud but the best comparison beteen modified and un-modified is like the difference between a millitary aircraft using reheat vs dry thrust. Less raspy which i assume were the sound frequencys which were the cause of complaints by residents at Marylebone
BanburyBlue
18 May 2015
Will do - something to wind the hours down.
sjpowermac
26 May 2018
Are the driving trailers of the 5A sets compatible with a 37?
The coupling is hook and shackle, brakes are standard air break.So for hauling the Mk5A stock yes, the Class 37 is compatible. Where a modified loco is needed (68019-32 for the Chiltern contract) is in order to communicate with the Driving Trailer and stock for passenger operation. Hope that helps:)
