Chiltern MK5s Starting 2026 (non speculative updates thread)
Forty29
10 Dec 2021
Bicester
I haven't seen 008/009 on the Chiltern line for a long time now though obviously don't record every working.
23 Nov 2015
Wondering if 1 spare loco at the moment even if stationed at Banbury is spreading the ground a little thin if a loco decides to sit down on the mainline and require rescuing.
Ultimately if 10 sets are working the full Service to Birmingham with 1 spare loco and set and two on maintenace cycle at say Eastleigh there is next to no spare capacity. I suspect the two DRS locos are going to be required semi permanently if not fully.
What was TPE's plan for rescue if they managed to get a full service runnin?
It's surprising how often 008 & 9 are on MK3 duties currently tbh
So if there are 11 sets diagrammed (10 service, one hot spare) that implies 79% availability for the loco fleet (14 locos in pool), which should be achievable. Add in a "ThunderCat" rescue loco and it is 86% availability required - which is more challenging for what is a fairly small fleet.
It has been suggested elsewhere that the Mark 5 kit off 68033/034 may be transferred to two Beacon owned locos (68017/018?) and that these would have their DRS lease ended and be re-leased direct to Chiltern, as additional support for the fleet.
matt
30 Jun 2005
Rugby
68008 was in use on the 23rd August, I travelled back to Birmingham behind it.
D365
29 Jun 2012
I’m going to be that annoying, pedantic person and state that none of the Class 68s (or indeed, any of the Stadler locos… so far) are fitted with the 61 way jumpers and cab equipment for working with Mk5 Sleeper coaches.
But yes, the transfer of Mk5A multiple working equipment from 68033/034 to 68017/018 has been previously suggested on RailUK.
172007
2 Jan 2021
West Mids
Depends whether DRS wants to lease locos to Chiltern, which seems unlikely (and 008 and 009 aren't compatible anyway).
Not sure why it's surprising that 008 and 009 appear a lot - 008-15 are all DRS locos and they provide however many it is they are contracted to provide from that pool: it doesn't really matter which specific locos it is. Apart from the livery those two locos are no different from the silver ones.
Its surprising that 008 & 009 are used as
A) most companies (in the real world) would prefer everything to be in their house colours. You ought to see the brand kits specifying typeface and where a Toc logo can and cannot be positioned that are on the intranet to see how seriously this stuff is taken in theory.
B) With 3 x mk5 sets in use and 6 silver locos albeit one in a Chiltern HVO livery the its somewhat staggering / bafflkng that 008 & 009 are ever used
L+Y
4 Jul 2011
On the subject of liveries, have we any indication at all for when we might see a set vinyled up in Chiltern livery?
22 Jan 2024
Not sure what the relevance of the sleeper coaches is as this discussion isn't about them, but as regards the Mk5a sets, those use the native multiple-working system fitted to all the UK Stadler locos, so nothing else needed there. What is needed is the equipment for integrating with the TMS - it is that which 68019-34 are fitted with. It's connected via an additional socket just above the buffer beam.
When 67s were used there was a wider range of liveries appearing. Likewise with the Wales operation - both now and previously. All of which suggests that the TOCs aren't that bothered.
That rather depends on the availability levels, and on whether there is a clear preference for Chiltern-liveried locos or whether it's just whichever of the pool is available.
Wyrleybart
29 Mar 2020
South Staffordshire
D365 was being a pedant and trying to highlight the difference between Mk5 and Mk5a.
It is written somewhere that the Caley sleepers are Mk5 and the ex TPE push pull sets are Mk5a
43 302
25 Oct 2019
68017 and 68018 off lease from the end of September.
317362
7 Sep 2017
Just seen a set on the west-south curve at Reading West, DVT facing South and silver, anyone know the set and 68? Hadn't expected it and took a while to work out what I was seeing
alanc
19 Jul 2020
kennington
Will have been 68030, uncertain of the set
Alan
xotGD
4 Feb 2017
Can the discussion about plastic please find another thread, so that this one can focus on proper trains?
BlueLeanie
21 Jul 2023
Haddenham
Surely all trains will be vinyled whether they be Locos + LHCS, or multiple units?
I'm looking forward to seeing the Mk5As in service in Chiltern livery.
XCTurbostar
13 Sep 2014
Likewise, I am interested to see if Chiltern Railways will retain the black fronts on the MK5 DTs and if they will follow the same format as the Clubmans. Historically, the locohauled sets always led the way with a slightly different livery.
Just a gentle reminder, this is traction & rolling stock updates thread regarding what is actually happening with Chiltern Mk5s.
Anything else, including anything that is speculative, belongs in a separate thread, please.
If anyone sees any post of concern and/or a thread go off-topic/speculative, please do not reply/react/respond to it; instead please use the report button.
Thanks
Edit: some posts have been moved to:
warwickshire
6 Feb 2020
leamingtonspa
Yes, 68008 had a 3 week spell at Chiltern, arrived on Saturday 16th August 2025 at Wembley from Crewe, and Returned Saturday 30th August 2025,
Most notably for the best part of time between Monday 18th August for Most of that week it actually ran with 68022 and CH12, Banbury depot to Banbury platform one, to see if in the interim, Doing various test runs to see if a Chiltern based 68 can rescue a Mk5 set, should one fail on the Mainline, ie for, obvious reasons because until March 2026, Whilst testing and graduall fleet replacement occurs, ie goodbye mk3s, this situation of a Chiltern 68 rescuing a Mk5 set could well happen,
Until enough Mk5 compatible 68s are around on Chiltern.
Yes 68008 returned to the Chiltern Mainline on Mk3s for a very short spell mainly just covering the Bank Holiday weekend either side.
Peter Sarf
Croydon
Also begs the question, can a TPE 68 rescue a Chiltern Mk3 set ?.
warwickshire
6 Feb 2020
leamingtonspa
Yes, should be able to do so,
However a Chiltern locomotive on a Mk5 set drag, has occurred before and can be done, anyway, because between Lockdown Covid one July 2020 and Covid two January 2021, in those final days of the pacers on the clc Lines Manchester Piccadilly to Chester, Transpennine Express did seem to hire in 68013 a lot for movement in around Longsight yard, because I remember seeing it there moving a set around and also was on a ecs move with one, between Stockport and Slade Lane junction on a ecs move from Crewe. With the pacer on the slow line, successful in undertaking it with great ease,
However yes a Chiltern 68, has occurred before on a mk5 set, but only for ecs or dragging move only, and rescue can be achieved but only for such purposes.
and the same vice versa,
XCTurbostar
13 Sep 2014
68022 and CH12: 3U20 > 3H22 > 3E23
68032 and CH13: 3N01 > 3J04 > 3N07 > 3J08
XCTurbostar
13 Sep 2014
There are some pictures floating around of the new Chiltern livery.. here you go.
The livery shows 68020 in a brand new Chiltern livery of all over blue with dark blue body sides and no yellow fronts.
