I think 25kv AC, as in solid conductor bar in the tunnels.Are the references to overhead third rail about DC or AC? I only know of overhead rail as AC, eg Elizabeth line.
The way I understand it for crossrail it isn't conductor rail but the standard copper contact rail with a special cantilever arrangement and bracket to hold it.I think 25kv AC, as in solid conductor bar in the tunnels.
Indeed they were looking last year at alternative solutions...Is this the same initiative for battery electrics that Chiltern had a call for competition last year or something new looking at a wider range of options? Timelines seem like it could be preparing to present to DfT for sign off if it was from last year. It's fully possible that came to nothing and instead they are back to the drawing board looking at other solutions.
I'd tend to agree with other posters that while High Wycombe is a good idea (allows a high frequency metro-style service to run), I'm not so convinced about Banbury. Banbury is a long way out of Birmingham, much further out than High Wycombe is from London, and in the centre of a sparsely-populated rural area. The services at Banbury are basically long-distance services (XC and Chiltern end-to-end), not commuter trains.For electrification I'd start from both ends. Wire to Wycombe and Banbury and the two ends can convert to EMUs, the DMUs freed up (172 and 168) can then do the end to end services with the 165s scrapped while new EMUs (or something like 350/2s) do the local services. Then do the middle bit and the 168s and 172s get redeployed somewhere else (probably 168 to Northern converted to 170s and 172s to strengthen Snow Hill Lines services pending wiring those) and EMUs take over the lot.
because you need Kidderminster, two routes to Stratford etc - if full interworking was done (in future, perhaps!)
If you are electrifying from both the Birmingham and the London end, the first services to go electric at the Birmingham end would presumably be WMR services, so you would need to start with a section that makes sense to run WMR services on?Why do you need Kidderminster? Chiltern no longer run trains there.
If you got rid of the Met fasts bi-mode units would only need to have enough battery for the eight or so miles between Aylesbury and Moor Park...
EDIT:
Getting the Met to Watford Junction is going to cost an awful lot of money.
The Birmingham end of the Chiltern route and the WMR Snow hill lines overlap, so it doesn't really make sense to separate them out?Eight miles from Aylesbury to Moor Park?
This thread specifically relates to Chiltern routes, maybe a new thread should be created for lines outside that scope?
They're separate sets of routes though - you'd logically do the Snow Hill Lines as their own electrification and have Chiltern as a separate scheme that extended out from the London end to meet it.The Birmingham end of the Chiltern route and the WMR Snow hill lines overlap, so it doesn't really make sense to separate them out?
An advantage of doing the Snow Hill Lines early on would potentially be releasing 172s to Chiltern, in case the 168s aren't enough for the end to end service alone, alllowing the 165s to be scrapped?
As previously mentioned several times. the 165s won't last long enough to survive until this mythical electrification project becomes reality.
The Snow Hill lines wouldn't be quick - there's numerous problem bridges and a big problem Tunnel at Old Hill/Blackheath.An advantage of doing the Snow Hill Lines early on would potentially be releasing 172s to Chiltern, in case the 168s aren't enough for the end to end service alone, alllowing the 165s to be scrapped?
I still think this is bizarre. They're just posh Sprinters.
Getting certain parts may be hard, but that just means you'll need to replace bigger parts (e.g. if the PIS is an issue, replace the whole thing).
an unlimited supply of cash would certainly be a way of speeding up electrification!Bizarre or not, that's the reality of the situation. Maybe if there were an unlimited supply of cash we might be in a better position.
It doesn't look overly constrained at either end: https://en.wikipedia.org/wiki/Snow_Hill_tunnel_(Birmingham)#/media/File:168003_at_Moor_st._station,_Birmingham.jpg and https://www.wikiwand.com/en/Birming...ilway_Station_-_geograph.org.uk_-_1471393.jpg shows a tram outside the Snow hill end, and Steam usually doesn't get any restrictions on it, unlike Old Hill which is very definitely not electrification-ready. I appreciate the tunnel may get worse further in.The tunnel between Moor Street and Snow Hill wouldn't be easy either...
But really, if Chiltern can't afford to keep all the 16x running longer, they should be looking for any DMUs available for a cascade.
I still don't get discontinuous electrification. Dropping the pantograph while on the move isn't that easy and isn't worth it compared to a bridge replacement. It could work for the Snow Hill tunnel but I can't see much use elsewhere compared to the crossrail style mounting of OHLE.Another case for discontinuous electrification and battery fitted EMUs?
I was under the impression that was to replace the loco-hauled sets, though if the 16x are so problematic keeping those is probably neededWhich they are - their franchise agreement specifically mentions the possibility of 175s. Which might not be able to replace all the 165s, but might make it possible to take some apart for parts.
Snow Hill Tunnel is where it's worth spending the money to electrification. Discontinuous OLE might be worth it for Old Hill Tunnel as trains will have a bit of a run up on the juice anyway. I think permanently earthed sections are sensible where clearances don't allow and the bridge rebuild would be silly money, but if you're getting longer stretches of no wires then you have to ask whether the battery solution might be better overall anyway.I still don't get discontinuous electrification. Dropping the pantograph while on the move isn't that easy and isn't worth it compared to a bridge replacement. It could work for the Snow Hill tunnel but I can't see much use elsewhere compared to the crossrail style mounting of OHLE.
There's nothing saying Chiltern have to take every Class 175 or none of them.There are far more 175s than you need to replace the very low current usage of the LHCS.
And yet it takes about 4km at 125mph on Great Western for the automatic system. Here is a nice diagram of the distance involved for dropping it.Dropping the pantograph automatically while on the move by way of some sort of balise is extremely easy. I don't think we're suggesting drivers doing it.
