Cathdral Hill TCD
LucaZone
24 Feb 2006
West End, Surrey
Cathedral Hill - Multiple Unit Depot
Size: 8'x1' (plus 6" hidden fiddle yard)
Scale: N-Gauge
Power: DCC
Era: Post Privatisation and Sectorisation
Misc: Compatible with 4 Track N-Mod as used by N-Gauge Berkshire Area Group
The originally proposed track layout. Not much has changed during construction except for more operational interest I have added crossovers between the two closest mainlines.
Construction Progress:
Part of my desire with this layout was that when in transit it could fit in my car without having to put the rear seats down to get it in.
The end plates are used to box up the two main boards for transit, usually the layout will operate without them in place.
Finishing off the trackwork
being new to DCC, I setup some very basic wiring to test out how the whole thing works and get the track smooth for trains to run over.
This is the layout in transit form
LucaZone
24 Feb 2006
West End, Surrey
Hiya,
Latest on the woodwork side of things. Tonight the layout stood on its own two feet...well actually 6 of them. Things were concerning at first as in testing the legs hadnt proved that stable, but once the whole structure was up it was very sturdy indeed.
With the main backscene boards also now installed, once the setup is broken down it boxes very neatly together. The extra 6" x 4' strip is the as yet unstarted fiddle yard that will hang off the back of the of the main boards.
Finally an image of the wiring being completed. Replacing the test setup from before with better routing and cable ties.
LucaZone
24 Feb 2006
West End, Surrey
Been a few months and progress hasnt been great, but here is a look at what ive done in the mean time.
Wiring of Switch Pilots
Footprint of the heavy maintenance shed
Base area where the wash units will be installed, dead centre of the display, as well as the fiddle yaard access hole which will be behind the double stack porta-cabins used to control the washer units.
Overview of the layout
Construction of the fiddle yard behind the backscene
