Sonicstud85
- Joined
- 3 Jun 2015
- Messages
- 4
Can you get sacked for failing a random drug test?
Couldn’t see a thread on this.
asking for a mate.
asking for a mate.
asking for a mate.
In short, yes you can. If you're caught taking something, anything, that if declared would have taken you off track, you can, and probably will be, sacked.Can you get sacked for failing a random drug test?
asking for a mate.
asking for a mate.
And that has made all the difference.asking for a mate.
If you don't declare it, you'll get shafted?There has to be a pun here somewhere...
Could be a “hard” medical...If you don't declare it, you'll get shafted?
And don't wear tight fitting trousers to the medical.
I would assume a TOC would have such a list and it would be available to staff.
Pretty much every time you ring up to check your medication they will ask for the ingredients.And maybe ask a pharmacist because generic drug names on the TOC list may be different from trade names.
so if you take some night nurse you have to declare it?There are thousands of medicines available. Last time I went to the Doctors, my Doc has to look up the medication I had requested to take. It is also dynamically changing all the time. The best example is Hay fever tablets. They reformulate all the time and each year it can change. There are some that are well known to be acceptable but the procedure MUST be followed each time. The procedure is robust and if one of the most important safeguards of the railway.
Wow.
Gee whiz I just spat my beer out! Bravo!It depends whether you’ve been prescribed it by its commercial name of Viagra or of its chemical name of mycoxaflopin.
Gee whiz I just spat my beer out! Bravo!![]()
You’re in so much trouble for that post Jon...You're supposed to swallow...
