can i still get PRIV rate on the underground
goatie
20 Mar 2014
hi all,
trying to get my head around this one
I'm a retired BR safeguarded staff member, can I still get a pri rate ticket at the underground ticket office (if they still exist)
going to Kings cross then on to seven sisters via the underground on sunday
I've not been to London for a few years & just been reading about oyster cards but it does not say anything about 1 off visits/jurouney's on the underground
What is your entire journey? Are you wanting a single, or returning the same day?
tsr
15 Nov 2011
Between the parallel lines
This perhaps "may or may not" be of use, but...
Buying a standard Oyster card and only completing one journey is fine. You can get a refund of the deposit and any remaining credit. It's probably best to check you have ID with you for the refund process!
I expect you should find the ticket office at Kings Cross St Pancras open, though it may, naturally, be very busy.
Ploughman
15 Jan 2010
Near where the 3 ridings meet
hi all,
As of 6 months ago they were still available.
Used one for Kings Cross to Central area.
CyrusWuff
20 May 2013
Safeguarded staff (both Active and Retired) do indeed still get PRIV rate on paper Singles and Returns on LU, though note that the PRIV rate Day Travelcard has been abolished.
You can also get your entitlement added to an Oyster, but the normal undiscounted daily caps apply!
goatie
20 Mar 2014
thanks for your comments
I'll be trying to get a PRIV day return KX to Seven Sisters. don't want all the hassle of oyster card and trying to get refund, as only have a few trains back home (live in Retford)
John @ home
1 Mar 2008
Do you intend to travel Retford - Kings X using a £43.50 PRV ANYTIME RETURN RETFORD - LONDON TERMINALS ticket?
If so, consider a £43.50 PRV ANYTIME RETURN RETFORD - SEVEN SISTERS route ✠ ANY PERMITTED instead. This is valid via Kings X at no extra cost and operates the tube ticket barriers at Kings X and Seven Sisters.
If not using a £43.50 PRV ANYTIME RETURN RETFORD - LONDON TERMINALS ticket, you may save time if you buy a £2.35 PRV ANYTIME DAY RETURN LONDON TERMINALS - ZONE U123* LONDN route VIA UNDERGRD/DLR ticket at Retford ticket office before your journey to London.
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
John @ home
1 Mar 2008
I agree that the ZONE U123* LONDN ticket is more appropriate. I'll edit post #7.
Mojo
7 Aug 2005
To get Priv discount applied to your Oyster card:
1. Print off and fill in this (WARNING: opens pdf directly) form
2. Post it to Rail Staff Travel
3. When it has been signed off by them, and returned to you, take it to any London Underground ticket office
You say that you live in Retford, but will you seriously never be using the Underground again? Paper singles for LUL travel at Priv rate will be abolished next year, so you should definitely consider this if the options mentioned above are no good for you.
Mojo
7 Aug 2005
There is no joint/inter availability between London Terminals and Seven Sisters on LU or NR services. A ticket from Zone U1 -> Seven Sisters (or vice versa) would however have joint availability between LU and NR.
falcon
8 Mar 2009
The simple answer is that there is no difference than from 30yrs ago.You just go to the ticket office window at Kings cross undergound there must be at least a dozen windows all open.As you did in the past you say "can I have a PT return to seven Sisters please" give them the money and you get your return PT to Seven Sisters".I did it last week my self.No different to 35yrs ago.You don't need an oyster or anything to do with them.Simple answer!:roll:
Deerfold
26 Nov 2009
Which will cost £2.35 return.
Priv on oyster will be £0.85 or £0.60 each way depending on the time.
hairyhandedfool
14 Apr 2008
Just reading iKB again, this is what it says.....
Knowledgebase said:
National Rail tickets valid on LU/DLR services
Subject to tickets being valid between the appropriate stations or for the zones shown National Rail singles and returns only (not Season Tickets) are valid on the LU/DLR services as shown below:
National Rail tickets which include validity
Between Seven Sisters/Tottenham Hale/Walthamstow Central and Zone U1 and beyond
Are also valid on LU/DLR services
Via the Victoria Line from Seven Sisters/Tottenham Hale/Walthamstow Central to any station in Zones 1 to 3
I guess you'll have to forgive me for thinking Seven Sisters-Liverpool St.-Kings Cross-Retford (on a Seven Sisters-Retford '+Any Permitted' ticket) is travelling beyond Zone U1. You'll also have to forgive me for for seeing Seven Sisters in the cross London connection list and thinking there is some sort of implied validity.
Deerfold
26 Nov 2009
Mojo only said there was no validity on a ticket from London Terminals - Seven Sisters ticket (a ticket which was suggested by John@home but then corrected).
So far as I can see, nothing you've posted disagrees with that.
goatie
20 Mar 2014
Falcon thanks that's what I was hope would happen
