Can anyone identify this 153 inside Crewe Carriage Shed
andrewslack
20 Nov 2021
Huddersfield
Hi,
Going past Arriva Train Care / Crewe Carriage Shed on 10th August, next to 170105, there is something else clearly undergoing major work. I can't even work out what class it is. My first thought was boxy 153-ish but the bottom is wrong. The bottom looks more 158ish but the sides don't have the slope. I wondered if it might be a 350. Does anyone know what it is, class and identity? Best photo I could manage sorry!
thanks
SECR 65
2 Apr 2026
East Sussex
The bottom curvature makes me think 158.
I don't know why but I have a gut feeling it's a Sprinter.
Although it seems quite wide at the top.
fgwrich
15 Apr 2009
Hampshire
I would strongly say that is a small end cab of a 153, the cab windows being rather high up is the giveaway.
andrewslack
20 Nov 2021
Huddersfield
Thanks. Does anyone know which one or why?
That was my confusion. It's like a 153 with a bit of 158 bottom curvature
trent129
4 Mar 2024
derby
It’s a class 153. If you google 153374 it shows a partially stripped shell. you can see similar features
CR165022
12 Nov 2019
Buckinghamshire
It can either be a TfW one or a Network Rail one and the NR ones tend to be done at Long Marston, so I'd guess it's a TfW one going through overhaul perhaps?
andrewslack
20 Nov 2021
Huddersfield
Would that be corrosion checking/fixing that means it got stripped so much? I've been looking for info on fleet status and havent managed to ID it.
sd0733
7 Nov 2012
All the 153/3 vehicles of the Active Travel units have been through Crewe ATC for heavy exams/overhauls. 153312, the spare vehicle is currently there for the same work so seems a good chance of it being that.
andrewslack
20 Nov 2021
Huddersfield
Thanks all. 312 seems likely then but I'm not going to count it unless I can get positive confirmation. I cant see anything to suggest 158910 specifically. What makes you think that? It looks more like a 153, unless you know something about the current status of 910?
tel
10 Mar 2010
norwich
The only 153 i've got at LNWR Crewe is 312, so i would think that is the one.
tel
Shaw S Hunter
21 Apr 2016
Over The Hill
I would suggest people look at the picture more closely. On the left hand side is a view through the doorway on Track 14 where the bodyside of the mystery vehicle can be seen: it is surely a 170. And the the yellow above the cab window does not extend to the roofline but meets a grey painted area of the roof end dome: again, looks like a 170. Thoughts?
43096
23 Nov 2015
The vehicle on the right of the photo provided by the OP is a 170 and described as such. We are talking about the vehicle on the left, which is clearly not a 170 - it obviously has a cab end gangway for starters.
Shaw S Hunter
21 Apr 2016
Over The Hill
Mea culpa, that is so heavily stripped I didn't recognise it as being a train!:oops:
Below the missing light cluster there appears to be a white patch, possibly with "text" on it. Is that a trick of the light or is it a temporary identification sign? Someone with serious image enhancement software might be able to answer.
Armchair Bob
28 Oct 2021
Glamorgan
tel
It's a safe bet that it is TfW-owned 153 312. It was reported a good while back that it was at Crewe for repairs, and the rest of their fleet have been seen in service or otherwise recently bar that one. It will reportedly be earmarked particularly as a spare for the Active Travel sets.
29 Aug 2026
South Wales
Hi,
thanks
AndrewView attachment 210222
Thats 153312, spare unit for the AT sets. Its been there for most of the year, just that and 153921 which is sitting idle in Canton are left to re-enter service with TFW
