Cambridge South new station opening
aron2smith
20 Jan 2025
I was on a Greater Anglia train recently and looked at the network map in the corner of the carriage, under Cambridge South, I remember it saying 'Opening June 2026'.
andy33gmail
23 Mar 2025
cambridgeshire
Yep. Although it triggered me the maps were all the wrong way around; given the train never changes which way it faces, they could have stuck it by the other door so that London on the map is towards the London end of the train
TiddlyPom
2 Feb 2021
South Cambridgeshire
My daughter was on a Cambridge to Liverpool Street train the other day that indicated on the internal displays that the first stop after Cambridge would be Cambridge South, which created a certain amount of confusion!
mr_moo
7 Sep 2009
Cambridgeshire
I commute on the London to cambridge route 4 days per week. Quite a few trains have been saying that! Not sure what's gone wrong in their systems but it always raises some eyebrows when it comes up!
dk1
2 Oct 2009
East Anglia
Yes the conductors are asking the drivers of 755 operated services through Cambridge to delete the South from the PIS.
mr_moo
7 Sep 2009
Cambridgeshire
So every driver has to manually edit this for every run? Oof, no wonder it's being missed/forgotten/ignored by some drivers, especially if running late. Wow!
dk1
2 Oct 2009
East Anglia
Yeah you’ll always get the odd driver who doesn’t but it’s very straightforward. I used to enjoy editing the schedules. Control can also do it remotely.
Magdalia
1 Jan 2022
The Fens
Update here on closure of the busway bridge for safety fences to be installed.
Hopefully this will be completed before the station opens.
Walkers and cyclists will be unable to use a bridge on a guided busway for two months while safety fencing is being installed.
The bridge, between the Cambridge Biomedical Campus and Trumpington, will also be closed in one direction for buses, with diversion routes put in place.
The closure is part of Cambridgeshire County Council's work to install safety fencing between the busway track and the shared pathway running alongside it.
It agreed to install the permanent fencing and barriers after it was fined £6m following the deaths of three people on the Busway.
The safety works are due to take place between March and May, as reported by the Local Democracy Reporting Service.
Trainbike46
18 Sep 2021
belfast
Why? Wouldn't it be advantageous if the station opened before these works start, as the station can then be an alternative point to cross the railway close to the temporarily closed one?
Magdalia
1 Jan 2022
The Fens
No. The station footbridge will be platform side of the barrier line, and it would be overwhelmed by the amount of traffic, especially cycles.
neill
4 Apr 2012
Here are some photos from this morning. The busway path closes in a couple of days so these are likely the last for a while.
Lots of work to the landscaping and streetscape now, plus looks like the lawn is being laid on the roof today.
The prefabricated lift shaft on the island always seems odd to me, from an architectural viewpoint. Although it’s mostly not visible from inside the station, you see so many others on new stations that are clad in some sort of sheeting, or brick faced.
WesternBiker
26 Aug 2020
Thank you for another great set of pictures. I went through it yesterday and the platforms are looking pretty much ready.
I also noticed the attached poster up in my local station (apologies if this has been posted further up the thread, but I don't recall seeing it).
absolutelymilk
18 Jul 2015
I'm excited for this station to open, but I'm slightly worried by the fact that the main footbridge is at the north end, same as at Cambridge station, meaning that everyone will want to be at that end of the train to change or exit, same as at Cambridge. From plans I can see there is also a secondary/emergency footbridge at the southern end, will this be open in normal service or just when the main footbridge is closed?
Magdalia
1 Jan 2022
The Fens
From plans I can see there is also a secondary/emergency footbridge at the southern end, will this be open in normal service or just when the main footbridge?
The south end bridge only spans what are currently the down lines, and is the emergency evacuation route from the central island platforms 2 and 3 into Hobsons Park. My understanding is that it is for evacuation only.
neill
4 Apr 2012
I was able to get the drone up today and took some photos. Very much into the finishing touches stage now. Watering the grass on the roof!
Went through yesterday - and the platform name boards were being erected on platform 1
Yup - these were visible!
It looks like the emergency egress route is separate from the bridge, which does indeed only span the down lines. At the moment it appears the the bridge may be open for regular use, but I can imagine it will be of limited appeal. It is also possible barriers will appear prior to opening.
edit: more photos
Magdalia
1 Jan 2022
The Fens
Thanks for the update. It is quite hard for me to see what's happening while the busway bridge is closed to pedestrians and cyclists. One thing that is noticeable is the amount of floodwater on what used to be the site compound.
I'm not convinced! I don't see anywhere at the south end for barriers in your pictures.
So basically July?
As far as I'm aware there is still no official announcement of the opening date.
mr_moo
7 Sep 2009
Cambridgeshire
It's a "Secondary Means of Evacuation" footbridge, specifically there to give people on the island platform a second way out in an emergency. It crosses to platform 4 only where passengers will then have a small walk along platform 4 to the emergency exit.
The bridge will be open and available for use by anyone normally. There will be no gates or barriers and it does have lighting.
Indeed. The official line, as per https://www.networkrail.co.uk/our-w...he-railway-in-anglia/cambridge-south-station/, is "Cambridge South station is expected to open for public use in June 2026."
Sunday 28th June is the date on the internal plan. Naturally, there is still work to be done and many things need to be within a high leveel of confidence of being completed without further issue before that opening date becomes officially announced.
Baxenden Bank
23 Oct 2013
28 June is given as the scheduled date in the Cross Country pdf timetable for May to December 2026
absolutelymilk
18 Jul 2015
Thanks, presumably that means anyone going north could use it to change from the island platform to the other northbound platform (and vice-versa)?
Netwrox
15 May 2023
Cambridge
Wouldn't that just encourage fare evasion? Anyone without a ticket could go this way if there are no barriers.
Does anyone know when the cycle path will be reinstated to its original route under the Addenbrooke's Road bridge?
Looks like they're in the process of restoring this. Original path looks pretty clear now, and the farmland they were using is having soil put back.
