Caledonian Sleeper
Sealink
16 Aug 2006
Bridport
The 6th January 20:45 Inverness to Euston shows as "no service" in the "month view". I think this is because every class of accommodation is closed to new bookings, which is being misleadingly translated as "no service". I'd have to investigate more deeply to properly find out.
Thank you. I am hoping that is the case.
Well that was the case....
A fair few no shows, presumably due to weather, an extended stop at Willesden and Wembley sidings (such a shame to see 321s absolutely plastered in graffiti)... and an hour 55 minute delayed arrival at Euston so delay repay automatically generated. (RTT showed 69 minutes but this was against the WTT)
BenBracken
27 Oct 2019
Pembrokeshire
Looking at the ECML route it’s taking atm, it seems to hang around in Wembley reception yard for about 20 mins, and RTT mentions a loco running around? Does anyone know why it hangs out there so soon into the journey?
Bill57p9
1 Dec 2019
Ayrshire
The train reverses there.
The loco doesn't actually run round: the train is top and tailed between Wembley and Euston, with the second loco being added (southbound) or detached (northbound) at Wembley
Reversal is required to access the Euston from the North London Line.
CW2
7 May 2020
Crewe
The top-and-tail working always used to be the case, but with the northbound departure times now being closer together the workings have changed. 1S25 works as a single loco to Wembley and runs round there. The loco left at Euston then works 1S26, which runs into Euston earlier (and hence the ECS cannot be worked by the loco off 1S25).
seacat
Isle of Man
Stupid question time.....
I was on the Glasgow sleeper on Friday night (09/01/26). The Glasgow portion was at the front of the train departing Euston. We reversed at Wembley which put the Glasgow portion at the rear of the train. How did we get past the the Edinburgh portion at Waverley? Did we reverse again at Newcastle?
norbitonflyer
24 Mar 2020
SW London
Not according to RTT, as it went iver the King Edward Bridge. Nor did it use the Sub in Edinburgh.
GW43125
8 Dec 2014
I can only assume that maybe it split in one of the long platforms at Waverley, and a new locomotive came to take the Glasgow portion out via the "scissors" halfway down?
Jessicas Dad
1 Mar 2015
Realtimetrains has 92014 operating the train to Edinburgh and then 92018 to Glasgow Central which would agree with this.
Segedunum
International Transport
22 Dec 2013
Up North
Funnily enough I was also on board this service...
92038 took us to Wembley, 92014 took over to Edinburgh where we used a long platform to allow the terminating Edinburgh portion to detach. 92018 then continued for the last bit to Glasgow.
Hopefully you slept better than I did - the bit between Newcastle and Edinburgh felt like a white knuckle ride!
SuspectUsual
11 Jul 2018
Unless I'm misreading it, RTT shows the up Highlander stuck in Peterborough
I assume that's a data error? If so, does anyone know what time it actually arrived at Euston?
hexagon789
2 Sep 2016
I understand it's correct and the loco (92014) failed and thus the service was terminated at Peterborough.
Segedunum
22 Dec 2013
Up North
ECS of the failed set has moved out of Peterborough (AIUI due to issue with headlights on the 92) but since failed again north of Huntingdon.
Tetragon213
14 Oct 2024
West Midlands
Surprisingly, the new stop at Birmingham International does open up some new options.
I've booked a ticket for 2 with a family member to return home on the sleeper. If all goes well, I can WFH on Monday and Tuesday, return to Brum on Tuesday night, and be in the office for Wednesday morning. A minor missed opportunity is the lack of an option to take a bit of a lie-in at International; being booted off the train at 6 in the morning is a bit too early for a comfortable night's sleep imo, and there are precious few services up the West Highland Line towards Crianlarich to try and squeeze in an extra hour or so onboard.
I'm looking forward to it, will hopefully be boarding at Dumbarton to Birmingham. The pricing isn't so appalling if you book with someone else to split the fare.
BRX
20 Oct 2008
I wonder what CS would do if they found there were lots of people wanting to book from places like Dumbarton or Falkirk to Birmingham (indicating demand for trips between Edinburgh/Glasgow and Birmingham).
Bikeman78
26 Apr 2018
1S25 was definitely departed top and tailed last Monday. 92038 from Euston to Wembley, then 92018 from Wembley to Edinburgh.
Exactly this. Having worked 1S25 into Edinburgh, 92018 then worked 1S26 from Edinburgh to Glasgow. Whatever hauled 1S26 from Wembley must have drawn the front portion forward slightly with 92018 dropping on to the rear. During the east coast diversions, the southbound Glasgow portion gets three different 92s for haulage.
nilvaj395
11 Oct 2025
This is an unfortunate downside of sleeper services everywhere when you alight somewhere that isn't the end destination. I don't know if allowing more time (depending on the time) would affect pathing or the advantage of people needing to arrive early in London?
Anyways, I hope you enjoy your trip! Like the other poster says maybe CS will take an interesting view on people making journeys like that.
enginedin
15 Dec 2020
or, unsurprisingly, depending on your point of view ;)
similar to my observation though
that's not the only market though - I recently had to go from the Central Belt to near Plymouth. Timings-wise, the most feasible (and cost effective) way was: Highland Sleeper -> Crewe (getting kicked off the train at 05:15! seat only - too late in booking a room and didn't see the point in getting a room for a 5 hr journey anyway); Crewe -> Birmingham; Birmingham -> CrossCountry to destination (admittedly I did have 1st class on this leg which helped the comfort somewhat). And then try and look awake for a day of meetings :lol:
If I'd made this journey next month, I could have had least stayed on till Birmingham International and had an hour's extra sleep (well, broken sleep!) and still got the same XC train I got from New Street
nilvaj395
11 Oct 2025
The biggest downside of the ECML routing is the lowlander running as a single portion meaning being kicked off at Edinburgh before 5am
There is also Preston, Crewe and Birmingham being devoid of service when it goes this way. It's not ideal for people anywhere other than London, but it does keep the service moving for what I assume is the majority of journeys.
Tetragon213
14 Oct 2024
West Midlands
I suspect there would be pathing issues caused by blocking a platform at Birmingham International. Detaching isn't really an option, either. A shuttle from Queen Street to Crianlarich departing at about 8pm would at least allow passengers to connect on to the sleeper and squeeze in an extra hour and a half of sleep. I was tempted to go all the way to Bridge of Orchy, but the earlier departure required from Glasgow defeats the purpose of using the sleeper in the first place.
Thanks! Here's to hoping it at least lives up to what I enjoyed on the Riviera...
As previously noted, the Highland sleeper has a special path in the timetable to get to Euston before the prime long distance trains ramp up in frequency, so there isn't any leeway for a later arrival.
nilvaj395
11 Oct 2025
Thanks for mentioning, I thought that was the case. Nor would I necessarily want a later arrival either because it is sometimes essential for onward connections.
Bill57p9
1 Dec 2019
Ayrshire
The southbound Glasgow portion is top & tailed into Glasgow from Polmadie, and then the buffer end 92 is detached and follows the service out before running light to Edinburgh, sometimes to haul the southbound Highlander.
All makes sense, however I just noticed with the WCML closure and the Glasgow portion running via Edinburgh, rather than joining at Carstairs. What is the reason for continuing the light loco move rather than simply leaving it attached to the rear of the train and uncoupling in Edinburgh? The portions are currently running as 7 coaches each, so I can’t think of a length issue.
BenBracken
27 Oct 2019
Pembrokeshire
This may have been discussed elsewhere but I’ve just finished watching ‘Down Cemetery Road’ on Apple TV+ and the sleeper is a key part of Episode 6. They used Mk3 stock and filmed on the WSR last February with a 37 hauling, Bishops Lydeard was transformed into a remote Scottish station. I’m just curious as to where they got the stock from? Are there still Mk3 carriages knocking around somewhere for US tech giants to purchase or hire and where is it now?
Bill57p9
1 Dec 2019
Ayrshire
Eastern Rail Services in Great Yarmouth have a number of MK2/3 former CS coaches. They're always up for leasing out their stock.
A number of the MK3A sleeper vehicles were procured by preserved railways to use as staff accommodation.
JamesT
25 Feb 2015
I was wondering whether any of the footage was of the Night Riviera, as the coaches are in green and they filmed a couple of scenes in Paddington. It was in general a South-West production, Cornwall stood in for most of Scotland and most of the rest of the filming was Bristol.
BenBracken
27 Oct 2019
Pembrokeshire
The set builders would have created a studio based version of the interior for much of the inside footage. I’m wondering if they stripped an existing coach for fittings or just built from scratch.
MDoodle
16 Aug 2024
I booked a journey from London to Edinburgh on a Friday in June. I think it is a highlander service as it scheduled to depart from Euston at 21:30.
Just found out the highlander service splits into 3 parts at Edinburgh at 04:44 to 3 different directions, and my booking says I must vacate my room by 08:00, does it mean some coaches are staying at Edinburgh between 04:44 and 08:00?
p.d87
18 May 2010
You will likely be diverted via the East Coast Mainline which explains the earlier departure time. You wouldnt have a booking to Edinburgh on the Highlander. It is not an advertised stop apart from the Edinburgh to Fort William seats.
alistairlees
29 Dec 2016
You are travelling on the Lowlander to Edinburgh. Your coaches will sit in a platform at Edinburgh until 08:00. It's quite possible that this will be retimed to go via the West Coast (and leave later / arrive at a more normal time)
