CAF class 197 Civity for TfW: News and updates on introduction.
Jez
22 Jan 2011
Neath
According to RTT we have 44 in service today - 27 x 2 car and 17 x 3 car so that leaves 5 short to cover their diagrams.
The units not in service appear to be:
197006 197008 197010 197011 197012 197013 197014 197016 197017 197018 197020 197024 197028 197029 197030 197033 197035 197036 197039 197042 197043 197046 197047 197051 197103 197106 197107 197110 197111 197113 197119 197123 and 197125
Peter Sarf
Croydon
It seems 197039 has sneaked back to Cambrian Testing and/or Training (according to info passed on from a friend).
So no exposure to passengers yet !.
Harpo
21 Aug 2024
Newport
Russel
30 Jun 2022
Lichfield
Quite a few glitches if you look at the whole days service at somewhere like Welshpool with many 197s showing including some coupled to 158s. I suspect the usual TfW ‘set swap Shrewsbury’ is in the mix too.
That was my guess but wasn't sure.
nigelsporne
20 Dec 2012
Coleshill
Serious problems for TfW today with unit shortages due to maintenance issues so no service to Birmingham. Units being turned around at Wolverhampton so anything may be possible!
Jez
22 Jan 2011
Neath
Do we know how many 197s were in service today and how many diagrams were uncovered or short formed?
Ive just seen TFW Bristol service may be going ahead from December. They will need to get things moving by then especially if 197s are needed for Cambrian by then too.
nigelsporne
20 Dec 2012
Coleshill
Sorry unable to shed any lights on 197 situation. The Brums are normally 158s so the Aberystwyth services have been affected. Wrexham to Chester service, which I assume is a 197, also affected.
tfw756rider
30 Nov 2024
Wales (sometimes in England), thanks for replying!
RTT Suggests 197103 has worked the 1527 Aberystwyth to Wolverhampton today, is the correct or an RTT glitch?
Impossible for 197103 (or any of the 56 197s of 197101-126 or 197001-002, 197004-021 or 197042-051) to go on the Cambrian as they're not ETCS-fitted.
The 21 197s that are ETCS-fitted (and therefore can go on the Cambrian) are (197003 and) 197022-041. Even if it had been one of those showing, I'd have been very surprised, as that would've meant an entry-to-service of Class 197 on the Cambrian railway about 2 months earlier than planned.
Caaardiff
9 Jun 2019
This has been happening for nearly 2 weeks. Most of their 158 fleet is parked up due to failed air con. 197s have stepped in to cover where they can on the parts off the Cambrian.
Harpo
21 Aug 2024
Newport
I’m guessing it’s 158 cab air-con that’s failed? 158 passenger air con is hardly high quality or reliable: A TfW 158 without opened windows is a bit of a rarity in summer.
Having spoken with an a/c engineer, he doesn't really understand why so many would fail simultaneously (rather than evenly over time)
- system would be used all year because it also does dehumidifying and demisting in winter
- it's not like an engine that can overspeed, it should be able to run continuously at its maximum setting.
- gas won't leak from properly maintained pipes and seals
So is it the air con has just suddenly failed in last week or so, or is the truth that a lot of it it failed months ago, and sloppy maintenance didn't get it repaired many weeks/months ago.
Moderator note: 158 air-con issues moved to:
Peter Sarf
Croydon
Anyway back to 197s. Any ideas how long 197039 is going to hide away on Cambrian testing and training ?
I had assumed it would have to do a stint sooner rather than later exposed to real passengers, so on non-Cambrian services.
I now suspect that will not happen until 197s take over on Cambrian services and so then it will only EVER get as far out of the Cambrian sphere as Birmingham with the occasional trip to Chester DMU depot of course.
sd0733
7 Nov 2012
I Believe theres a Sunday diagram from December for an ERTMS unit to visit Canton, working down from Holyhead mid-morning and back to Shrewsbury in the evening with a few hours on Canton so even if it doesnt appear before it should still escape occasionally!
Peter Sarf
Croydon
Thanks for that info. That is a big stray. Just getting to Holyhead seems dramatic - but then there is a wheel lathe at Holyhead now. Of course with Canton having a replacement wheel lathe soon (when ?) a working linking both ends of Wales that have wheel lathes is interesting.
sd0733
7 Nov 2012
Theres a 158 which overnights in Holyhead now too with an early Holyhead to Birmingham service so it having ERTMS sets there will be a continuation of that.
DelW
15 Jan 2015
Apologies if this has already been discussed and I've missed it.
There has been debate about whether the change of the Cambrian main line from 158s to 197s would be a 'big bang' change over a weekend, or staged over a period. A post on the class 398 thread includes a slide showing a three-stage changeover of Cambrian services.
Until Sep 2026: 18 x class 158
Sep - Oct 2026: 10 x class 158 and 8 x class 197 (spare 158s retained)
Oct 2026 - Feb 2027: 6 x class 158 and 12 x class 197 (158s being returned to ROSCO)
Feb 2027 onward: 18 x class 197
This is the first time I've seen this laid out. It's contained within the first attachment of this post (please ignore the summary description) :
absolutelymilk
18 Jul 2015
Of the three changes in May 2026, looks like Liverpool - Chester has gone to Liverpool - Llandudno and Manchester Airport - Llandudno has moved to Manchester Airport - Holyhead. However looks like the Chester-Crewe services haven't been extended to Crewe - Wrexham? (apologies if there is another thread this is being discussed in!)
EDIT: looks on RTT like the extension to Wrexham is starting tomorrow?
Jez
22 Jan 2011
Neath
Seems to be a massive shortage of 197s today - just 39 in service to cover 49 diagrams. Noticed quite a few covered by Sprinters including two Manchester services cWest Wales-Cardiff and then switched to a 197.
Most of the Manchester-South Wales are 2 or 3 cars only. Two of the Pembroke Dock diagrams and most of the Maesteg-Ebbw are Sprinters. Conwy Valley, Ebbw-Newport and Wrexham to Chester all suspended.
sh24
28 Sep 2023
I saw at least 2 or 3 197's at Chester with coloured tape placed over where the external cameras would normally be. Supply chain issues with cameras?
