CAF class 197 Civity for TfW: News and updates on introduction.
Anonymous10
19 Dec 2019
wales
The guard said the only toilet options were Carmarthen, Llanelli and Swansea. The extra services to Milford are very welcome. It appears that and up and down services now cross at Hwest? Does that mean Platform 2 in use now for the first time in many years? We were held at Clarby for 10 minutes as the up was delayed and we were a bit late, so I’m guessing Hwest is where the passing is designed to happen?
Haverfordwest platform 2 under the previous timetable had no booked work but was used when passenger services and tankers crossed. I believe it now acts as the passing point.
chrisjo
18 May 2024
Llanishen
I can see only one instance today where two trains are due to arrive at HVF at more or less the same time, that being 1V32 CRE-MFH at 11:13 and 1W20 MFH-MAN at 11:15. Perhaps I'm missing something?
RTT shows 1B34 CDF-MFH using platform 2 at 10:33 but it's not apparent why it would need to do so.
BenBracken
27 Oct 2019
Pembrokeshire
The train I was on was due to arrive at 17:11 and there’s an up train that arrives at 17:10 so I presume the cross happens at the station. But as both were late I didn’t get to find out!
chrisjo
18 May 2024
Llanishen
Ah yes, I see it now. RTT has them both at platform 1, which would be a bit snug.
IslandLine101
8 Dec 2022
Shropshire
This is the departure list out of Manchester today heading for south wales. Almost everything 5 car, with two 4 cars. Seems like we’ve been waiting years and years for this, but the plans are finally bearing fruit. Long many it continue
BenBracken
27 Oct 2019
Pembrokeshire
The west Wales service I was on the other day arrived at Swansea as 5 cars then split to 2. Does seem to make sense.
Topological
20 Feb 2023
Swansea
Things are definitely getting better. Today looks to have the most 5-car trains of any day since the timetable change.
Hopefully, the splitting and joining at Swansea proves smooth enough.
Certainly looking forward to my first trip to Manchester on a 5-car 197 in mid-January.
BillStampy
6 Jan 2024
Llanharan
I think it was just a matter of putting stuff in the right place from the old timetable; some stock may have been in the wrong location to run the new timetable requirements and now that it has run for a few days things are settling into where they should be.
Kite159
27 Jan 2014
West of Andover
It just needs a way to avoid having the 19;30 & 20;30 splitting into 2 coach units, as those get extremely busy at Manchester.
Topological
20 Feb 2023
Swansea
Presumably, one is supposed to be a 3-car, but the 2+2 coming north is all they had today.
It does not help that the 20:30 would otherwise be a Mk4. I can see why they do not send the Mk4 back to Cardiff though. If Crewe was not so busy the 19:30 could be 4-car to Crewe and leave a 2-car there. The Mk4 set run in service to Crewe as the 20:30. The 197 dropped at Crewe could then be the 21:11* from Crewe. That would probably clear most of the capacity issues from Manchester, but creates a lot of messing about. The current situation is the most effective, even if there is not as much capacity leaving Piccadilly as there could be.
In a parallel universe, Northern could provide a Crewe service to give more capacity. In a distant parallel universe there would be crew to run the Mk4 in service back to Crewe (presumably needs a spare guard, since TfW must have a spare driver at Picccadilly to work the 20:30 after the driver who works the Mk4 in from Cardiff takes the Mk4 back out ECS)
TT-ONR-NRN
30 Dec 2016
Cambridge
Yes, there are many who use it as an evening service to Crewe. It empties out and fills up again there.
Jez
22 Jan 2011
Neath
that is certainly good to see. Hopefully this will happen every day now things have settled down a bit with the new timetable.
I also see the 1530 and 1730 are now going further rather than terminating in either Swansea or Carmarthen.
WAB
27 Jun 2015
Anglia
"Fills up" may be an overstatement - yes it is always busy to Crewe but beyond that is often very quiet - I have sometimes been one of a handful of passengers. 1V66 was always a bit odd under the old timetable - it often went out as a loco + set which got swapped at Crewe for a 2-car 197, and had some extended dwells - 13 mins at Crewe and 18 mins at Hereford.
Western 52
19 Jun 2020
Burry Port
New signs have appeared at Swansea Station showing where class 197s should attach and detach. The photo shows the one on platform 2 but others are the same.
Jez
22 Jan 2011
Neath
Very interesting. Thanks for posting. So im guessing they can attach and detach at any platform, even platform 4 which isnt used that often.
Western 52
19 Jun 2020
Burry Port
Yes it looks that way. The signs appear to be about the length of a 3 car 197 from the buffers, so will they still use this position if the front unit when arriving is a 2 car I wonder?
pokemonsuper9
20 Dec 2022
Greater Manchester
Is the operation likely going to be 3+2 arrives, they detach and the 3 moves towards the buffers, leaving a 3 car gap between the trains and then the 2 continues West?
WAB
27 Jun 2015
Anglia
Given the ongoing fleet challenges, relying on the 3-car leading would perhaps be unwise.
BenBracken
27 Oct 2019
Pembrokeshire
The platform staff moved us a long way up the platform to get the 2 car west when the 5 cars arrived, but we ended up walking back up the platform to pretty much where we started!
markglos
21 Oct 2014
Went past the CAF Factory today and could see 3 197 cars parked at the back, Also saw 2 trams, no idea who for
Jez
22 Jan 2011
Neath
I noticed a pair of 153s were covering a 197 diagram all day today on West Wales-Cardiff. I had it on my return journey from Swansea after going there for 197031.
It seems they are still struggling to cover all 197 diagrams without help from the Sprinters.
Any update on when more 197s may come into service? (still missing 2 x 3 cars plus maybe more of the Cambrian 2 cars may come into service to help out)
Topological
20 Feb 2023
Swansea
Not a great day on the Marches today.
Only 1 5-car 197 (15:30) from Manchester. There is a 4-car on 1V38 at 09:30, but otherwise not a great first working day of 2025.
(The 2 car on 1V62 is a pair of 153s, with a report that the same pair of 153s formed 1V33 from Wilmslow today (cancelled from Manchester in the screenshot)
Jez
22 Jan 2011
Neath
Yesterday was much better with quite a few 5 cars on the Swansea to Manchesters.
However yesterday due to the lack of services on the valleys there were many spare sprinters to help to cover the likes of Swanline- Pembroke Dock in order to keep 5 car 197s on the longer distance Manchester route.
Caaardiff
9 Jun 2019
Am I missing something? There's a number of 4 and 5 car services out today.
Only 4 services are 2 cars, with 1V62 likely to have the 153 replaced before it leaves Cardiff. With the 1930 and 2030 arriving as a 4 car to split as usual.
Steveswan10
11 Aug 2016
Herefordshire
Yes I can confirm 5 car on 1W18 (197030/197115)
