CAF class 197 Civity for TfW: News and updates on introduction.
BenBracken
27 Oct 2019
Pembrokeshire
Had my second go on 197s today. First from Pembrokeshire. The acceleration is noticeably better and do they do seem to keep a better pace than the 175s. Have timetables been adjusted for them or are they still following what the 175s used to? Faults with the toilets on the return leg. Was a 3 car unit (107) neither toilet had any running water and one was blocked. Sounds a pretty regular problem according to the guard.
craigybagel
25 Oct 2012
Still on the original timetable. Too many services being worked by slower units to risk changing the timetable yet. Also, there isn't that huge of a difference between a 197 on Eco mode and a 175 - at low speeds yes, but there isn't a huge difference in getting towards 90 or 100. It's a whole different story in Superpower mode, but I doubt they'd want to plan a timetable that requires using superpower so the time.
Dan G
12 May 2021
Exeter
What's the difference between the two modes? Revs held higher when accelerating above a threshold speed?
craigybagel
25 Oct 2012
That's pretty much it. It goes it in the lower gear for longer before changing. Better acceleration, but at a cost of increased diesel, adblue and general wear and tear.
craigybagel
25 Oct 2012
So no incentive to use that mode whatsoever?!
I wouldn't say that - I've seen some astounding amounts of time made up on delayed trains. But I doubt the increased costs of every day would be seen to make an improved timetable worthwhile, especially as many of the paths are fixed in place around other operators services.
tomoufc
12 Dec 2014
Are there operating rules about this - eg you're allowed to use the booster jets if over 10 late?
I'd rather they don't adjust the timetable until the performance is sky high. Punctuality has to be the first target.
craigybagel
25 Oct 2012
Drivers discretion for now. Personally I only use it when running late as it's pointless the rest of the time, you just end up waiting at stations.
Jez
22 Jan 2011
Neath
Ive noticed recently far less substitutions for 197s on the Manchester to South Wales route. Yesterday I think just 1 x 150 was used to cover a 197 diagram (that started and ended at Cardiff I believe) and today there are 2 diagrams being subbed - 1 x 150 and a pair of 153s. If 197s werent covering so many MK4 then its possible all diagrams could be covered.
However ive not noticed many doubled up formations of 2 to 4 car. Quite a few are now 3 cars however. Any news on when we can expect more 197s accepted into service so they can run as 4 or 5 cars?
Danfilm007
5 Jul 2015
ETCS will spread round the UK gradually, on the basis that is is cheaper than classic resignalling (which is deemed unaffordable anyway).
After the ECML (South) project, TRU is likely to follow, plus (probably) WCML North (Warrington/Preston/Carlisle).
Once the Manchester area gets it all TOCs will need ETCS-fitted trains, including those running TfW's services into Manchester.
Is there a thread to discuss this?
sd0733
7 Nov 2012
That's the plan as a temporary for the spring. 2s and 4s on North Wales- Manchester/Cardiff (plus the diagrams that split in Manchester) and 3 car on Manchester-South Wales. With 5s still not permitted Shrewsbury-Manchester that's deemed best use of units over the spring
Acceptance is almost at a standstill seemingly. Lots of sets now going into Crewe but few seem to make it out again at the moment.
Last Hurrah
17 Jan 2023
Canton
Will the Marches services be suitably strengthened this coming Sunday when Manchester United visit Newport County ?
Short formed sets will otherwise bring adverse headlines
craigybagel
25 Oct 2012
If it's United fans you're worried about, it'll be the GWR London trains that need strengthening <D that said, TfW did manage to put a 5 car on the first Cardiff - Holyhead service that followed the Newport Vs Wrexham match last weekend.
MP393
28 Jun 2021
North West
Maximum of 4 coaches only with 197s between Manchester & Shrewsbury, anything longer isn’t cleared for service yet. The first departure of the day from Manchester is booked a mk4, the 09:30, but not sure where 5 car HD01 ends up this weekend - it would certainly be useful on that usually already busy service!
Geeves
6 Jan 2009
Rochdale
They were running 5 carriages back in December with 197s on the Cardiff to Holyhead so it seems like they are cleared already unless they stopped again...
Edit I have read your post properly, Manchester and Shrewsbury CHECK
sd0733
7 Nov 2012
Cardiff to Holyhead is but Shrewsbury Manchester isn't cleared for anything above 4 car 197.
Jez
22 Jan 2011
Neath
Thank you for the update sd0733. I had a feeling acceptance had slowed down, i think only 1 x 3 car has been introduced so far this month.
Its been good to see 3 cars on some services however. Its a shame the 150 diagram yesterday included the 1730 Manchester to Cardiff which is one of the busiest services to South Wales out of Manchester. But we have come a long way from 9-10 months ago when most were Sprinters.
Sunday often sees the longest formations of the week. Ive seen quite a few 4 car 197s and also 5 car Sprinters on a Sunday (usually either a 158 or 150 with 3 x 153s!)
sd0733
7 Nov 2012
Seems to be being kept captive on Crewe-Crewe diagrams over the next few days so it should be what's on that 09:30.
sd0733
7 Nov 2012
Still? What's causing the delay?
No sign of anything changing either hence the planned concentration of the 3s on the Manchesters. It would appear its a Network Rail decision not to allow them as it stands. Several rumours around why theyre not allowed but unsure what the actual reason is at this point.
TT-ONR-NRN
30 Dec 2016
Cambridge
I wonder what's prompting Network Rail to say that. That will be infuriating for many on the route if consistent 5 carriage services have been long promised and never materialise.
sd0733
7 Nov 2012
Especially when the (even longer) 5+2 Mk4s can run with no issues!
I'm sure at some point it'll be resolved with some tweaks here and there but it doesn't seem imminent.
TT-ONR-NRN
30 Dec 2016
Cambridge
Are we any closer to more 3 cars being introduced into service that could mitigate the effects of this slightly?
Jamesrob637
12 Aug 2016
One year (and a bit!) on from the first one entering service, they really all should be in service now.
