Hi folks,
On Sunday 06/09, there will be engineering work on c2c routes. The c2c service alterations calendar says the following:
However if we try to buy a ticket, for this day, between Stanford-le-Hope and Upminster (where there should be a shuttle service) or between Stanford-le-Hope and Pitsea (where there should be a rail replacement bus) then there aren't any services shown except around midnight either side of Sunday. Does anyone know what's going on here and when the timetable will be released?
Screenshots are from raileasy but the result is the same regardless of which booking website I try (including c2c's own). I'm not sure whether different sites have their own copy of the data which they update periodically or they pull it "live" from the same source.
I should mention that I've emailed c2c with this query already.
(I'm unable to edit the first post for some reason).
Engineering Work Between Basildon and Leigh-on-Sea and Between Stanford-le-Hope and Pitsea
These services will start/terminate at Upminster and Stanford-le-Hope.
Rail replacement in place between Stanford-le-Hope – Pitsea & Pitsea – Shoeburyness.
During peak times (around 08:00 – 11:00 & 16:00 – 19:00), train shuttles will run between Leigh-on-Sea – Shoeburyness and rail replacement will run between Stanford-le-Hope – Pitsea & Pitsea – Leigh-on-Sea during these times.
