BVE going from 17FPS to 5FPS and staying there!
28 Jan 2007
A6-EHF
Ive mucked about with all the settings on my card and its no differn't:???:, Has anyone got any ideas?
P156KWJ
26 Nov 2007
Nottinghamshire
I only have a problem with certain trains. The most problematic are the HST4 and class 323. Occasionally the 153 likes to have an arguement - but I've stopped using them :)
5872
28 Jan 2007
A6-EHF
Right... Use certain trains :arrow: :arrow: :arrow:.
Try reformatting your PC.
A good thing to do is have two hard drives (for reliability two physical drives are best), but two partitions on the same drive will do. One drive can have your system files on it, the other for data. Back up the data regularly, and create a ghost image of your system drive. When the system goes wrong just re-ghost it.
BVE 4 uses the .net Framework, have you tried installing the latest service packs from Windows Update?
I've not done any extensive testing, but based on my experiences I believe it matters far more what raw processing power you have by having a fast CPU and system bus, than having a good graphics card. It runs well on my laptop with integrated graphics, but not well on my PC with an old CPU but a reasonable graphics card.
5872
28 Jan 2007
A6-EHF
It was fine a while ago
Zamracene749
11 Dec 2005
East Durham
Have you (or anyone else) updated your graphics card drivers?
If so you may need to go back to older drivers-have had this problem a few times in the past with nvidea and also with sound card drivers.
