BusTimes.Org
geoffk
4 Aug 2010
Exeter
Stagecoach in Exeter seems to be tracking as normal on my route but some buses are "missing" elsewhere.
M60lad
31 May 2011
What's with all the times coming up on the map page when tracking a bus? Its only started to happen recently, every dot on the map now has a time stamp on it now.
PeterC
29 Sep 2014
Living in a small village I always check bustimes before leaving the house. Its not perfect but most issues are down to the operators.
One feature which could be confusing is on "banjo" routes. I don't know if that is down to bustimes or the data feed but where a service uses the same road in both directions it doesn't distinguish inbound and outbound stops. If I look at the comparison between the schedule and actual times it tells me that the bus is almost back 30 minutes early despite the map showing it still outbound.
Teapot42
12 Jan 2022
Living in a small village I always check bustimes before leaving the house. Its not perfect but most issue sare down to the operators.
One feature which could be confusing is on "banjo" routes. I don't know if that is down tobustimes or the data feed but where a service uses the same road in both directions it doesn't distinguish inbound and outbound stops. If I look at the comparison between the schedule a actual times it tells me that the bus is almost back 30 minutes early despite the map showing it still outbound.
I would suspect this is because bustimes is just checking the location of the bus against the location of the stop. It would be possible to improve the algorithm to match direction of the bus against direction expected, but that would take a fair bit of development time and testing to get reliable and, unless some body is prepared to fund the site, that won't happen quickly.
I'd guess a simple 'mask' which either ignores or otherwise highlights as likely incorrect the passing of a stop more than say 5 or 10 minutes early and 30 minutes late would be easier to implement.
pokemonsuper9
20 Dec 2022
Greater Manchester
Even the buses themselves get tricked by this, the next stop announcements on some Bee Network routes break where the route loops.
PeterC
29 Sep 2014
With regard to vehicle details it is helpful to know what colour I am looking out for in a busy environment. The rest is irrelevant geek stuff to the general public.
Robertj21a
22 Sep 2013
Many companies use various colours, allover adverts etc...
wildcard
13 Feb 2011
Some time ago the forum pointed me to bustimes.org - which I had confused with an iOS app - which appears on the phone as Bus Times but was actually titled London Live Bus Times . It only showed TfL services . Their phone logo is a red wristwatch over a single decker silhouette . This app now appears to be updated to include UK wide services - renamed to London & UK Live Bus Time - same logo as before. I find this update very useful living in Hertfordshire just north of Watford . It now shows the totality of services I can use . Personally I found the web based bustimes rather difficult to use ( on a phone ) , the new iOS app is easy to use by comparison. I appreciate the app may not have comprehensive UK coverage - maybe only services close to larger towns & cities . Also I have yet to test its accuracy . Edit - It's TfL accuracy is/was spot on.
ricoblade
28 Sep 2015
Thanks - I'll check that out and see if it's comprehensive on my patch of North Notts/South Yorks.
LUYMun
15 Jul 2018
Cancelled
It appears this morning that most buses in England aren’t tracking, with the exception of Stagecoach and CT4N. Buses in Wales and Scotland track unaffected, so perhaps some data feed issues are bugging up Bustimes?
PeterC
29 Sep 2014
I just spotted that too. Its not the first time, I did not check further but it certainly lost all Carousel and Red Group services for a while recently although on that occasion TfL routes were tracking.
Twingo37175
24 Mar 2019
Just looking around yorkshire and most now seem to be back (was just stagecoach earlier)
pepperpot80
29 Sep 2009
Hove
Looks like an issue at source with Ticketer, as most of the bus companies' apps and a few other sources weren't showing live times or tracking. Seems to be resolved now though.
PeterC
29 Sep 2014
Carousel's new route 1C doesn't track on bustimes despite tracking on their own website and counting down on the timer in Chesham Broadway.
Wuggie Norple
9 Sep 2021
Cardiff
For some time now, Stagecoach South Wales buses (eg 122, 124, 132) show duplicated entries when you look at the list of departures from a particular stop.
lxfe_mxtterz
3 Mar 2018
Sarahdale (West of Emmerdale)
It appears that in the last few days, bus stop information at certain locations has disappeared - for example, at Victoria Bus Station in London, every stop is now showing as "Victoria Bus Station (Stop)" as opposed to, say, "Victoria Bus Station (Stop A)".
Quite disappointing as it makes planning a journey a lot more difficult, particularly at bus stations with lots of stands. I hope this is merely an issue which will soon be fixed rather than something intentional.
markymark2000
11 May 2015
Great Britain
Stagecoach South Wales seem to have duplicated the trips on some of their routes.
Bustimes get it's stop information from the NAPTAN database and according to the NAPTAN site, the last time London uploaded NAPTAN data was 27th August (https://beta-naptan.dft.gov.uk/last-updated). Did the issue come about before or after that date?
miklcct
2 May 2021
Cricklewood
I think there is something recently broken in the Bus Open Data Service. The station / platform relationships have broken recently that our app no longer displays the two directions of a tube stations as within a single station.
lxfe_mxtterz
3 Mar 2018
Thanks both for the information, hopefully it's resolved soon enough.
@markymark2000, that date sounds just about right with when the issue started, as I seem to remember first noticing it just over a week ago.
johncrossley
30 Mar 2021
This is as a result of he cyber attack on TfL. However, other apps still supply real time info, such as the Bus Times London app.
borage
21 Feb 2018
The cyberattack (probably) hasn't changed the "Indicator" field in a bunch of bus stop data from "Stop A" to "Stop" – as @markymark2000 says, that's the NaPTAN (national public transport access nodes) database. But it is why red London buses aren't tracking on the bustimes.org map – as per this post in the TfL Tech Forum:
  • Live bus location data (from BODS) is unavailable
PeterC
29 Sep 2014
Twice today it has simply stopped updating for 15 or 20 minutes on on both my outbound ind inbound trips.
Normally I would use it to decide when to leave the house
Edit 12 September
I was looking my local services today and noticed that tracking dropped for about an hour on a number of operators.
All the same companies have dropped out again.
markymark2000
11 May 2015
Great Britain
Bus Open Data is having issues and the BODS teams are aware. Remember, bustimes is a 'garbage in, garbage out' site, in that they only display information given to them by others.
ricoblade
28 Sep 2015
Hi @wildcard - I normally use my "home" Stagecoach East Midlands app but was out of area today in Sheffield and found the app really useful as it was the Sheffield 10K and routes and services were subject to changes.
The app found the bus stop I was at and showed me the live departures.
The one downside is that there isn't a map to "see" the buses but I corrborated the live information with the bustimes.org map and it was accurate.
PeterC
29 Sep 2014
I see a lot of GIGO if I follow my local Red Rose routes. Routes set before runnng out of service to the start point is common while some journeys never track, presumably because no route is set in the machine. Add in the drivers' cavalier attitude to the actual routes (wrong way round a circular being the least of it) and i am just grateful that I don't have to rely on the bus stop timetables.
Vexed
12 Jan 2020
Herts / Hants
Another GIGO issue is the ticket machine staying on the previous journey when starting a new one. It's less common than it used to be but does still happen on Red Eagle near me.
nw1
9 Aug 2013
Just noticed the "predict the rest of the duty" feature on Bustimes for Bluestar seems to have returned, having been missing of late: presumably the block info is now included again.
Checked a couple of vehicles currently on the 1.
