BusTimes.Org
Teapot42
12 Jan 2022
One thing i do find really annoying with bustimes.org when looking to see if a service is on time, they only show the last stop the service called at, you have to click on, show previous stops, to bring up the whole route, i rather they showed previous stops from the start without having to click that show previous stops box.
Maybe not all previous stops, as there can be a lot, meaning a long scroll. However, the last 2 or 3 plus timing points would be useful.
Arriva Fan
14 May 2018
Why don't some Operators Track? Have First Glasgow ever Tracked? McGill's used to and are no longer on there.
markymark2000
11 May 2015
Great Britain
It depends who has public live tracking feeds pretty much. There's lots of sources though such as bus open data, local transport authorities, operators direct, etc etc.
First Glasgow doesn't have an tracking feed that is open to the public (as far as I know).
The feed that was being used for McGills (and various other Scottish operators) the data wasn't very good and there was no way to link the tracking to an actual trip, so the data was quite poor really for passengers. I don't think the feed was really meant to be used for the purposes that bustimes was using it for, and certainly wasn't of the normal tracking schemas, so it was a bit useless.
On the plus side, with Scottish BODS seemingly starting soon, these operators will hopefully start sending data there, and bustimes I am sure will make use of that open data.
CMBS
24 Jan 2026
Operators aren't required to publish BODS data in Scotland. Bustimes also pulled out of Passenger API data which is why McGills/Mytrip operators no longer track.
Arriva Fan
14 May 2018
I see, so what the McGill's & First App Tracking publishes isn't copied over to BusTimes.
Will Scottish Operators be required to publish BODS at anypoint?
CMBS
24 Jan 2026
BODS for Scotland is currently being rolled out, though operators aren't required to publish vehicle positions until 2028.
Volvodart
12 Jun 2010
It will only be 2028 if the legislation is published by the end of the year. It could be 2029.
CMBS
24 Jan 2026
Even though that is a while away that is positive news! Will little independent operators also need to comply with this? What about scottish citylink?
They are expected to have more time than larger operators but eventually comply with it. I think Citylink will need to comply because they run local services.
5 Dec 2025
Central Scotland
Right okay - cheers
Update - Scottish Citylink Seems To Now Be Broadcasting Location data?
