Brittle plastic
DJ_K666
5 May 2009
Way too far north of 75A
I managed to break the chassis of my Lima Western (ironically while gluing it back together) so I'm guessing it's not long for this world. Can anyone recommend a decent plastic weld which might work better? I'm reticent to use Pipe welding as that might melt too much plastic and in any case it could break apart elsewhere.
EDIT: it's ok I got it back together. Turns out poly cement is better than superglue on this type of plastic.
4COR
30 Jan 2019
W Oxon (UWL exile)
I was going to say poly cement. If you need to fill any cracks, then filling with some modelling putty and then a respray/paint with matching paints should sort (judicious weathering to hide slight colour mismatches perhaps!)
