Booking card required
GW43125
8 Dec 2014
Evening all,
I booked some tickets online via the SWR website, but when I went to collect them this evening, the TVM told me I didn't have the booking card. This is weird as it's definitely the card I booked with and I've been using this card on the RST website for the last 18 months with no issue!
As the machine is refusing, is this something the ticket office can help with? Sod's law that our helpful TO clerk went on break just as I got there!
Thanks.
[.n]
8 Apr 2016
Evening all,
Thanks.
how odd - but yes I believe the ticket office shouodl be able to help - might be worth trying to reinsert the card again? Or trying a different TVM
winks
11 Jun 2009
What they don’t tell you is that if you don’t have the booking card but have it saved as contactless in your phone you can tap the black cube reader and it authorises your ticket.
Mcr Warrior
8 Jan 2009
The card used wasn't a "Chase" card, was it? Sometimes we see reports of ticket machines not recognising this particular card.
GW43125
8 Dec 2014
Indeed it was-how peculiar.
RST have been perfectly happy with it, it's only this one time I've booked with SWR...
JacobWrenn
13 Dec 2020
I've had the same issue recently and indeed Chase do warn their customers that the card cannot be guaranteed to work for ticket collection. I wonder if RST default to offering any card collection and SWR does not?
GW43125
8 Dec 2014
Quite possible now you mention it-not seen that warning on chase.
Thanks, guess I'm not using SWR again then!
Hopefully I can bribe persuade the TO to help on this one.
Thanks all :)
Mcr Warrior
8 Jan 2009
Hopefully someone better informed than me can explain, in simple terms, what the actual "problem" is, with not being always able to use 'Chase' branded cards to collect pre-booked tickets from TVMs, if indeed this is the issue.
Starmill
18 May 2012
Bolton
My interpretation of the problem is that Chase UK issue cards which do not have their number printed on them, and use a virtual number for any cardholder not present transactions by that account. The last four digits of the "real" number are visible in the app after a transaction on the physical card has been made.
As a result, if a customer uses the number from the app for an online transaction, they can't use the card they have to match the last four numbers. It's the same problem you'd come up against if you tried to collect a ticket with, say, a Revolut single use "disposable virtual" card, or a prepaid card that's also virtual only.
This problem also inhibits things like Airtime Rewards, the cashback app which uses the card numbers to track cashback. You can't claim that on Chase cards as I understand it.
Thanks all :)
The ticket office ought to be able to assist you; hopefully you should be able to present something to prove your name anyway, which fingers crossed is a match for the name in the booking (hopefully it's not blank or Mx C Customer or similar).
If I were you I would stick to using the same site every time if you have to use ToD. Otherwise, use a physical card on any site other than the ones you know work for any card. Other ways around that include buying an evoucher and paying with the evoucher, or paying by PayPal - this always sets any ToD to any card. I believe you can put Chase through PayPal and still receive your 1% chase cashback.
Could be that, could be they've got some logic for accounts which are "trusted" to deliver by any card.
James H
25 Jun 2014
You can, if you're prepared to use a workaround - I used a third party NFC app to obtain my 'real' Chase card number and added that to the Airtime app (as well as having added the virtual card number)
Starmill
18 May 2012
Bolton
You can, if you're prepared to use a workaround - I used a third party app to obtain my 'real' Chase card number and added that to the Airtime app (as well as having added the virtual card number)
Ah ha good to know!
