Blackpool - Manchester Electrification
LDECRexile
30 Jan 2014
Southport, UK
Yes, thanks I can confirm 5044j being present as 5044jq2.
Thanks once again for a fantastic effort.
Phew!
Thank you.
Joe has sent me this, which might be of interest, to travel or to view:
http://www.railwaytouring.net/uk-day-trips/winter-cumbrian-mountain-express-23-01-16
Wrinkley has been back to Orlando Street and to the library.
I've added the fruits of his labours to his album here:
https://www.flickr.com/photos/127646831@N03/albums/72157654034635234
Thank you Wrinkley.
Joe has had his Alfred Hitchcock hat on and edited several scenes from last Friday into one narrative film. The fine result is in 5020z which replaces 5020u, w, x & y
I've added it to his album here:
https://www.flickr.com/photos/127646831@N03/albums/72157651953947345
Thank you Joe.
I've reflected all these in the Combined Volume and also rationalised 5044jq2 to 5044j and 5044i2q to 5044i, here:
https://www.flickr.com/photos/127646831@N03/albums/72157648767927083
I have added an extra check when I publish additions and changes whereby I review albums as Joe Public before hitting GO.
Joe Callaghan has received this Tweet from Network Rail:
Hi Joe, we're over quarter of the way through the tunnel now. Thanks.
Thanks for sharing Joe.
thealexweb
5 Jan 2014
Thomas6187
27 May 2011
Rochdale
First Transpennine Express seem so confident the tunnel will open on weekends that they seem to want to terminate some of their Liverpool expresses in Blackpool North XD
All the work outside the tunnel, i.e. the trackwork and platforms, should be completed by October, so weekend train running should as normal. However only a limited train service can run because of the single line.
snowball
4 Mar 2013
So if it does run it will be the new tunnel's 'smoke christening'. :)
More likely to be through the narrow, formerly down bore, if it will fit.
I too can now see 5044i and j.
Apologies for the delay in confirming this - I've been otherwise occupied for most of the last couple of days.
Many thanks to LDECR and his collaborators.
LeylandLen
28 Oct 2013
Leyland Lancs
Any information on the Blackpool to Preston part of Blackpool to Manchester?
I believe Network Rail need to close Blackpool N station to rebuild it and do associated track work / sidings etc which will take a few months . I thought it was to be done this winter after Xmas/New Year but not aware of any early publicity or plans.
LDECRexile
30 Jan 2014
Southport, UK
Wrinkley has just sent this about Orlando St Bridge
I’ve just been down there, the crane that was there has gone but has not been replaced by anything bigger yet. Few people on site and no one close enough to talk to.
It probably needs a bigger crane for the reach/weight as I can now see that the inner and outer walls for each side are in one piece, i.e. there will be two lifts and it will be at least the same weight as Farnworth. they may bring a crane in overnight - it came in at 5.00 am at Ladybridge – but it will take longer to set up. I will check first thing tomorrow
We've got company coming this weekend, so I'm out of it.
Wrinkley has a family wedding so he'll scarcely be able to visit.
I hope others of our intrepid band of photographers will be able to step in.
It should be a good show.
If people send me material I'll be able to get cracking on it from Monday midday.
Have fun
Dave
LeylandLen
28 Oct 2013
Leyland Lancs
Seems that TPE are routing most Man Airport TO Blackpool services for w/c 5/10/2015 via Bolton Chorley and southbound returns via WCML and Wigan N/W
snowball
4 Mar 2013
I thought that was 2017.
Jonny
10 Feb 2011
I seem to recall hearing reading winter 2016/7 on this forum, possibly also subject to slippage. As that is Blackpool's "low" season, it is probably the least disruptive.
LDECRexile
30 Jan 2014
Southport, UK
News from Wrinkley, whio managed an early morning trip to Orlando St bridge before his wedding commitments kicked in.
1. The beams will be craned in next weekend
2. The four big new concrete cill blocks will be craned in this weekend
2.1 The pair on one side were craned in this morning, Wrinkley filmed one of the lifts
2.2 The pair on the other side aren't yet on site and the crane doesn't look to be in the right place for that lift, so he surmises that they will arrive and the crane be moved tonight
2.3 He surmises that they will be lifted into place tomorrow morning.
I agree with his assessment.
Great stuff Wrinkley ,thanks for sharing.
QueensCurve
22 Dec 2014
I believe all the bridges have been done. As for when we'll see masts, no idea.
Basically nothing then. My understanding is the route needs resignallng/remodelling so it will be bogged down in the general malaise/delays to signalling projects.
Originally scheduled for May 2016 - showing the slippage on what was arguably an undemanding project programme.
snowball
4 Mar 2013
In the case of Preston-Blackpool I thought the so-far-announced slippage, i.e. to spring 2017, was entirely due to the growth in scope, i.e. the proposals for track alteration and resignalling.
Class 170101
1 Mar 2014
I have had a look at Realtime trains this morning for the 5 October the following TPE services are running via Bolton (see attached)
http://www.realtimetrains.co.uk/sea...5/0200-0159?stp=WVS&show=all&order=wtt&toc=TP
I would suggest there appear to be minimal changes from currently and all other services are being routed via Wigan NW. (Unless the data is still being updated by NR).
Joseph_Locke
14 Apr 2012
I thought that too.
Phase 4 (Salford to Euxton) is delayed due the Balfour Beatty fiasco and the scope of signalling data design for Bolton.
Phases 3 (Blackpool) and 5 (Stalybridge) are delayed due the Balfour Beatty fiasco and general design delays.
LDECRexile
30 Jan 2014
Southport, UK
I've received this from Wrinkley:
re:orlando St Bridge
A bigger crane is on site on the west side, on the station car park. They have lifted in two cill beams on to the west side abutment. There are two more to go in on the east side, but I couldn’t se them anywhere.
There is a new hard standing on the east side near the bridge which can be accessed from the retail park, I don’t know if they can access it by crossing the tracks. They may have to move the crane to this area to lift the other cills as I was told that they weigh approx. 50 tons each and it’s a long reach from where it is now. If they have to go through the retail park with the crane and the cills, they may not move it until tonight or early tomorrow, but that’s only my guess.
The engineer told me that the bridge will be lifted in next Friday night/Saturday morning, she will email the times to me later. It will be a 1000 ton capacity crane as I was told by another orangeman that the two lifts are about 100 tons each.
There’s also another small bridge to replace over the roadway behind the retail park, it’s on the general arrangement drawing that Bolton MBC have. Orlando Street runs over both bridges.
re: Farnworth Tunnel
She also works on the tunnel, they are making good progress, as they are now in clay and the expect good ground under St Peter’s Way. They have some professional photos from the tunnel and we may be able to get copies, but I think we would have to get permission to publish them.
Great stuff Wrinkley, thanks for sharing.
LDECRexile
30 Jan 2014
Southport, UK
I called at the Footbridge at 4:10pm today to see the "Lack Of" Orlando Bridge. I have 2 photos which can be used by anyone for any reason on my Flickr page. Higher res images if required.
https://www.flickr.com/photos/kenward/21542102076/in/dateposted-public/
https://www.flickr.com/photos/kenward/20947170143/in/dateposted-public/
Hope the links work.
Smashing, thank you.
I've downloaded them and will strive to put them in the Combined Volume tomorrow pm.
Welcome aboard
Dave
I've received very welcome material from Bullfield West, Wrinkley and through Wrinkley, Network Rail.
I have created an album for Bullfield West and put his shots of Orlando Street bridge into it here:
https://www.flickr.com/photos/127646831@N03/albums/72157658887703492
Thank you Mr West (please may I call you Bullfield?), welcome aboard.
I've added Wrinkley's own material to his album here:
Thank you Wrinkley
I've added the Network Rail shots, courtesy of an engineer who works at both Orlando Street and Farnworth Tunnel, to Fillie's album here:
https://www.flickr.com/photos/127646831@N03/albums/72157657384006325
Thank you Wrinkley, Orangelady and Network Rail
and I've wanged the lot into the Combined Volume here:
I hope people can chip in in like style next weekend when I'll be in Germany.
Thanks to all.
Dave
LDECRexile
30 Jan 2014
Southport, UK
Thanks Graham, but I'm only the conduit on this occasion.
We fly to Frankfurt then train from there.
Hope it won't be too long before we meet again.
Kind regards
Dave
