Best DMU for passenger comfort?
Bevan Price
22 Apr 2010
Classes 123 & 124 were the best in my opinion. Of current units, Classes 175, 180 & 168 are probably the best. Classes 170 & 185 not bad, but for long journeys, the 185s would benefit by having more (thicker) padding in the seats.
Voyager (& Pendolino) seats are a bit too narrow to be comfortable if someone is sat next to you.
railfan100
31 Oct 2016
Indeed, the problems that the 158s initially had activating track circuits were nothing to do with ride quality and everything to do with the use of disc brakes instead of tread. This allowed a build up of leaf mulch and other detritus around the wheel tread, causing a reduction in conductivity. They were subsequently fitted with 'scrubbers' to alleviate the problem.
Large numbers of EMU's had disc brakes fitted over 10 years before the Class 158 units, why did they not suffer the same issues? Not convinced that the issue was related to the use of disc brakes.
sprinterguy
4 Mar 2010
Macclesfield
No idea, but that seems to have been noted as the cause by more than one source online.The only written source I have to hand that makes mention of the issues isn't specific on the underlying cause.
railfan100
31 Oct 2016
Maybe it was a mixture of everything, having sampled the Class 158 in its early years I was amazed how smooth the ride was, clearly now the suspension has had many million miles of wear but back in 1989\1990 the Class 158 was setting the standard.
It was openly discussed in 1990 with BR sources that the ride was so smooth they were vanishing 'off grid' compared to the current standard of harder riding stock.
D5645
1 Oct 2016
Ripley, Derbyshire
Class 222 Meridians are the best diesel unit for comfort.
All the speed and power of a Voyager but without the awful internal layout.
Having been at BR Research at the time, the 158s were the first to have the track circuit actuation problems in a big way but also the first to have disc brakes and also the first with the more sophisticated T4 bogie. It's a bit of a moot point how much each contributed, but the scrubber brakes didn't totally eliminate the problem which suggests it wasn't totally down to the discs. Earlier classes suffered less, and initially 156s and 158s were split and coupled to each other to give a better chance of detecting at least one coach. However all second and later generation DMU classes were then fitted with the TCA, as were some on-track machines, so track circuit problems were clearly seen as a significant risk for any of them.
For passenger comfort I'd vote for the maroon and gold Transpennine 158s.
Ayman Ilham
2 Jul 2016
Blackburn (Lancs)
Best would definitely be the Northern 158 (basically all ex-TPE and WYPTE units) - it's seats are even more comfortable than any Intercity train I've been on (if you can get a seat that is, cos services to Leeds from Manchester Victoria tend to be quite busy) - other contenders would be the 175 (making journeys along the North Wales Coast even more enjoyable), 170 (though I haven't been in a Turbostar for 6 years), 185 and other 158 variants.
railfan100
31 Oct 2016
Maybe the Class 185 units if you bring your own seat cushion and have ear defenders?! Unless in the coach with the engine shut down due to TPE's 'eco mode'. Which still means that in terms of being eco friendly the dead weight of a 750hp unit is still dragged around.
61653 HTAFC
18 Dec 2012
The WYPTE 10 have the original seats (though reupholstered) and the cushions are starting to become permanently flattened now. The only ex-TPE vehicles with Northern, which had the thicker cushions fitted are the centre cars in the 3-car units, which I always seek out if I get one!
Pacers are pretty rubbish of course, but the "car seats" in the ex-Northern Spirit 142s aren't too bad as long as you're on CWR and not passing over loads of pointwork such as the approach to Leeds or Victoria... still be glad when they're dispatched one-way to Rotherham though!
185s are pretty quiet when you're inside them, the noise when one departs and you're on the platform shows how good the soundproofing on the units is.
I do see your point, but I find them quite claustrophobic because of the "bench" seating with no gaps. They also seem, like the Voyagers, to be getting into a poor state of repair, suggesting poor build quality.
DarloRich
Fenny Stratford
not a bad call actually. much better seats than the Voyager and so much more pleasant! Not an HST but not bad for a horrible new unit ;)
sprinterguy
4 Mar 2010
Macclesfield
Thanks for shedding a little more light on the matter - it seems that it wasn't as clear cut as I suggested.
I must agree with this post as it aligns closely with my own views, although I am too young to have experienced the class 123 and 124 units. I would have liked to have the opportunity to, though; it's a real shame that none of the latter in particular made it into preservation.
The Transpennine 158s were pretty good as well, though.
MarlowDonkey
4 Apr 2013
123 sets were essentially powered Mk1s, with side corridors even. In style, they were similar to Southern's longer distance EMUs and the Clacton units which became Class 309.
godfreycomplex
23 Jun 2016
Further afield SNCB Class 41 are very good; seats reasonably comfortable and lining up with windows
D6975
26 Nov 2009
Bristol
185s are my favourite, closely followed by 168s.
Riding in the middle car of a Northern 3 car 158 over the Copy Pit route is my favourite DMU journey.
123s and 124s were very nice to travel in, as were the Ayrshire 126s.
Prestige15
6 Aug 2016
Warrington
I go for 175, Its rather quiet for a train this type especially when its idling. The way i see it its a successor to the 158 only with no front end gangway and higher speed. But right now they badly need a new livery.
It's more of a successor to the Class 156, coming from the same stable. But the build quality is substantially inferior.
Deepgreen
12 Jun 2013
Gomshall, Surrey
Are they planning on refurbishing the other 165s and 166s as well? Personally i would classify HSTs as Locomotive Hauled Trains rather than DMUs.
I hope so. I believe 166205 is being evaluated in service to check the durability of the finishes. It's rather like a 'mini HST' inside, with the leather first class seats (actually the same seats in both driving cars' cab-end sections, but one end has been de-classified) being quite similar to, but smaller than, the HST equivalents.
