Assessments & Medicals discussion
CJ21
11 Jun 2025
Borehamwood
I've successfully got through all the assessments, interviews and medical and have a start date next month and as this Forum was so helpful to me I thought I'd pay it forward by breaking down how the process went for me to hopefully shine some light on what can seem quite an opaque process.
Timeline
Application submitted & SJT completed: 07/12
Invited for online assessment (miniSCAAT):11/2
Stage 1 assessment: 02/04
Stage 2 assessment: 15/04
DMI: 06/05
Medical: 15/05
Start Date: 16/06
So all in all the whole process has taken me ~7 months which from the looks of things is on the quicker side. On that front I think I just got very lucky as I'll explain later.
I won't cover the application and SJT in any detail as the former should be self-explanatory and the latter is just something you either get right or you don't. I'll just say I initially applied for the Thameslink Cricklewood talent pool.
Online Assessment (miniSCAAT)
Basically you just go through rows of letters and click on ones It's asked you to. You do this three times with each round a little more difficult but I say that lightly as this is an incredibly straightforward test. I've seen a few people on here worried when they get invited to this but they give a practice go before all three runs and you can repeat those as much as you want. Obviously I don't know what score I got but this felt by far the easiest test I did through the whole process and bluntly I struggle to see how you'd be able pass any of the other tests if you can't pass this. Which i guess is the point of using it as a pre-sift.
Stage 1 (Pencil and Paper tests)
Group Bourdon - One of the tests I think practice would have the biggest impact as you'll learn to recognise the patterns. You can practice this actual test online although it's much easier to do with pen and paper than on a computer let alone a touch screen. You can print off practice papers to do it that way or just do it the harder way knowing on the day it will be easier.
Tea-Occ - Done in 3 stages. Firstly you hear a series of high and low tones and count the low ones. Secondly you have to go through what's essentially a telephone directory of IIRC plumbers all with symbols next to them. You circle all the ones with double symbols next to them. Finally you combine the two although the tones are all one tone and you just have to count them whilst circling the symbols. I just focused on the tones and circled the symbols in the gaps between. Not sure this is one you can really practice.
TRP1 - A memory test. They read a sheet of A4 to you about something related to the railways, then gve you 5 minutes to read it as many times as you want and make notes (these are taken away from you after the 5 minutes though), then you're asked multiple choice questions about what you learned. I've got an excellent memory so this was very easy for me. If you have a poor one then maybe look at some memory techniques but i don't think any of the specific practice materials are going to do much.
TRP2 - Dials test - The practice material they give you is almost identical to the actual test so if you can do that you'll be fine, and I'd save your practicing for the Bourdon and DFFT. You'll never complete all 43 questions so don't worry if you don't, I think i managed 31.
DFFT - Basically you get a series of illustrations of train dash boards as well as a instruction sheet telling you how to spot faults and if there are multiple how many and which to prioritise. You then record what was at fault. Probably the most "difficult" test in it requires you to somewhat think for yourself. Well worth going over the practice materials as it familiarises you with how it works and I can imagine some people wasting precious time working that out if they haven't gone over the practice materials provided.
At the end they told us at the OPC we'd hear from the TOC within 10 working days, Thankfully I didn't have to wait that long and they contacted me two days later to say I'd passed and then the following Monday gave me dates for the Stage 2.
Stage 2 (Computer Tests and MMI)
You do the 3 computer tests one after another with no breaks in the order below. Everybody starts at the same time but depending on how long it takes you to read the instructions, have a practice you'll finish at different times so try to ignore other people as best you can.
WAFV - Very straightforward in that all you have to do is watch a screen and press the large green button on your console, as quickly as you can, every time the flashing grey square on screen turns black. However it is IMV the most challenging of all the psychometrics ests and the only one somebody in my group of 5 failed at. Why? because you're doing it for 32 minutes. I don't think I missed a single black square but i definitely pressed the green erroneously a couple of times. The guy who failed said he did zone out at one point, I can't really add anything more than tr not to do that as you can't really practice this.
ATAVT - You hear a beep then see an image for 1 second and then you select if you saw pedestrians, vehicles, bikes, traffic lights and traffic signs. I was worried about this but felt it was much simpler on the actual test than when I'd tried to practice it with either the material provided or youtube. So personally i wouldn't bother practicing and from what I've seen it's rare people fail it.
2HAND - You have to take a ball round a track using two joy sticks one moves it vertically the other horizontally. Every time it goes outside the track you hear a beep. You get a couple of practice runs then you have to do it 10 times for the test*. Everybody thought they'd failed (I only didn't because I'd read on here everybody thinks that!) and everybody passed. I think the main thing is not to panic if you make a bunch of mistakes and then spiral into making more or get too cautious and then become too slow. The only people I've heard fail this was from taking too long. Stay calm and try to remember they're just sifting out people with below average hand-eye coordination not testing to see if you have the fine muscle control of Roger Federer.
*I saw somebody earlier in this thread have a problem with people revealing how many times you have to go round the track. Which I find a bit daft as the instructors tell you before you start as do the instructions on screen so it's not meant to be a secret and I can't see how it gives you any advantage when it's a physical test.
MMI - The 4 of us that passed (they told within 20 minutes) were then all given the SJE and a pre-interview form. The former has no wrong answers they just use it to inform what to ask you at interview and the latter is just asking for one sentence examples to the interview questions that they'll then interrogate further in the interview. You then get given a time slot for to come back for. Overall the interview took almost 90 minutes and was the most gruelling thing of the whole process. I finished the stage 1 and the rest of stage 2 and the DMI fairly confident I'd passed but I was really unsure with this. My main advice would be to think about the type of questions you'll be asked (you can google them, search the forums or even use AI), come up with about 10 and then get confident answering them using the STAR method. HOWEVER you can't just memorise a monologue as the interviewer will really delve into your answer. For one of mine she said my answer wasn't appropriate so asked me to give a hypothetical scenario, which i had to do off the cuff, but i was able to to do as I'd practice enough at the type of answers to give.
DMI
Found out the next day I'd passed the MMI and this is when my luck came in as the recruiter for GTR called me up to check if I still wanted to be at Cricklewood depot as she'd arrange my interview with the relevant manager. I asked what other depots were available and she mentioned Hornsey (for Great Northern) which just so happens to be 10 minutes from where I now live, and even better had space on course dates right around the corner. I'm not a "meant to be" type of person but it felt it at that moment!
Interview was very straight forward with sevral competency based questions plus a few questions about why I wanted to switch careers and become a train driver, what i knew about GTR and what I foresaw as the challenges of driving a train. Honestly after the MMI this felt easy and took a third of the time. Just practice similar things to the MMI, they'll ask you follow up questions if they feel you haven't provided enough but if you have they won't cross examine you like at the MMI.
Got a call later that day to say I'd passed and got my verbal offer.
Medical
They'll scan your glasses if you wear them when you come in (although beware as my prescription was very inaccurate) and getv you to fill out a form then you'll see the Nurse who'll do hearing, eyesight, colour blindness, diabetes, drugs & alcohol tests as well as an ECG. As I said in an earlier post if you need the toilet tell them so they'll do the urine tests first!
After that you'll see the Doctor. Who will ask you some medical history questions then do some very basic mobility tests (standing on one leg, rasing hand above your shoulder) and check your peripheral vision. She told me I was cleared straight away so no waiting to hear. I then got my formal offer later that day and just had to provide 2 character references (Can't be family, employer or somebody you live with).
Hope this helps somebody like similar posts helped me.
Congratulations on the offer!
Thanks for sharing all of the information with us.
I was just wondering if you could maybe pm me any extra info or tips about the MMI? I’ve been searching for info and it’s the only part that has me a bit concerned and I really want to do well.
ads2911
16 Jun 2025
ilford
Thank You!
Yeah you’ll get given a pre-interview form which has 6 questions that are all like “give an example of when you dealt with/demonstrated X” you just give one sentence answers in the form and in the MMI they will interrogate your examples.
Hi, do you remember what the 6 questions were? I have my second stage assements and hopefully if I pass, the MMI this week so would be really helpful to prep as much as possible. Thanks I’m advance!
Nadz B
9 Jun 2025
Timeline
DMI: 06/05
Medical: 15/05
Start Date: 16/06
DMI
Medical
Hi @Kieran88,
Firstly, congratulations on passing all the assessments and securing your place with GTR that’s such an incredible achievement and really inspiring to read. Your detailed breakdown has been super helpful and appreciated by so many of us following the same path.
I just had a quick question — was the RAAT (Rules Acquisition Aptitude Test) part of your assessment journey at any point? I’ve seen some TOCs include it early on, but it doesn’t seem to be mentioned in your timeline, so I wondered if GTR omitted it or replaced it with other tests like the DFFT.
Thanks again for taking the time to share your experience, wishing you all the best for your start date and training!
Lurch_UK
21 Jan 2025
Canterbury, Kent
Waiting on DMI from either Dover, Ramsgate or Faversham (anyone recently had DMI in those locations?)
I wear glasses, and am wondering what the eyesight testing in the medical is like?
(Eyesight in Left eye is pretty ****!)
And wear varifocals.
Dippa
15 Mar 2017
Does anyone know what the hearing test pass criteria is?
I’ve recently recovered from an ear infection and just had a hearing test at Boots. Everything came back fine overall, but I was hearing at 25 dB, which is apparently 5db below normal at 4000 Hz - most likely due to the recent infection. Just wondering if that would be an issue for the train driver medical?
thejedtrain
12 May 2025
Pretty sure it's enhanced
Reading the recent c2c recruitment drive forum on here, people were saying it was national but wanted to confirm on here to be sure. I have a pass mark for the paper tests but wasn’t unable to do the computer tests and MMI, so if it does national, I’ll go straight onto that stage. If enhanced then no I guess
FR510
20 Oct 2020
Kent
They only test at 500Mhz, 1khz & 2 khz and 25db is an easy pass.
GooseWaffe
3 Mar 2025
Westcliff-On-Sea
Just been through the tests.
c2c require a national standard only :)
Spincity
23 Nov 2019
C2c is national, but there is not a standard enhanced ‘score’ so even can potentially fail for one enhanced TOC but pass another enhanced level
Tocwarrior
17 Apr 2025
Manchester
Got my medical in 3 weeks, I hear they test for uncorrected vision aswell as corrected.
with glasses I can see everything, without I cant see anything, thats why I wear them!
My prescription is -6.. I cant even read the first massive letter on the eye chart without them, guess I'm doomed
driver333
27 Oct 2024
Kent
They do mate, they make you cover each eye and read out the letter chart, you’ll be fine, the minimum is read the big letter uncorrected, the rest can be corrected , I’m a -6 in 1 eye
And I passed
Tocwarrior
17 Apr 2025
Manchester
And I passed
I'm at a slighty more eased state thank you! Fingers crossed will update afterwards
thejedtrain
12 May 2025
Thanks. Recently failed the paper tests at ‘enhanced’. Passed the majority of tests at enhanced but one of the tests I only got national. OPC said I overall passed national, so if I apply for a toc that is national, I go to the computer tests, so will look out for c2c! Hope you did well on the tests!
GooseWaffe
3 Mar 2025
Westcliff-On-Sea
I passed them all :)
Starting my new role as a depot driver soon
kieran88
16 Dec 2024
london
Hi @Kieran88,
No, not part of my testing sorry. AIUI there’s the national standard of tests and pass scores then some TOCs are “enhanced” where they may ask for higher scores for those tests and add other ones like DFFT and VSE.
GTR are enhanced but DFFT was the only extra test they asked for. May be different for shunters I’m not sure.
erer245
8 May 2025
weston
Hi all. Quick question for those who are ideally already drivers or have been offered the job. I’m worrying, I’ve got 3 points on my drivers licence for lack of due care, if I apply for a position will this flag up anywhere / jeopardise the opportunity or does this not even get looked at. Thank you.
Horizon22
Jobs & Careers
8 Sep 2019
Extremely unlikely, if not 0% chance of this being any issue.
Yappi Yappo 23
27 Apr 2024
Hi, I hope everyone is well. I have a stage 1 assessment really soon and I'm really worried about the Tea-Occ (Test of Everyday Attention). Can anyone share some advice on how they combatted this part of the assessment
Scotts_pine79
6 Mar 2025
Northallerton
Last year I took three psychometric tests as part of a companies recruitment process. These were a STVT, TSCT and PAAT test.
I was told via email that I passed all three, but didn’t receive any certificates. I was told by the recruiter that these tests are widely recognised by other railway companies.
I now have a job offer from another company and although I passed these tests, I have no certification to prove I have, just an email.
Has anyone had any luck requesting these off of a company? Or any luck in general? TIA
SCDR_WMR
17 Dec 2017
Crewe
Test results are stored in a national database against your NI number so any other TOC/FOC will be able to access you scores.
You may still have to resit test even if you passed before as different companies set different scores as pass marks (often referred to as Enhanced Standards)
erer245
8 May 2025
weston
The tones in the listening task I can’t really advise on, just practice getting someone to make low and high tones and count all the low ones.
The phonebook - IGNORE the numbers completely. You’ll be asked to look at symbols and find matching pairs like matching ££. They try and distract you with loads of numbers in the phone book and other symbols like £@ but you only need to look at the matching pairs, that’s genuinely it.
Managed to pass it from advice just like that or similar enough
Yappi Yappo 23
27 Apr 2024
Thank you for the advise, I really appreciate it
NeoNeko
27 Aug 2024
Kent
I bought the software from here: https://traineetraindriverinfo.com/product/everyday-attention-test-tea-occ I found it very helpful, and, in fact, I thought it was harder than the real test. As erer245 said, for the phonebook, you only need to look for companies with two matching symbols. I will say that they are quite small, and I know I made at least one mistake, as a couple of the symbols are quite similar to each other, even though they don't match. For the final part, they play fewer tones, so even though you're doing two things at once, it's not as challenging as it initially seems (imho).
Yappi Yappo 23
27 Apr 2024
I bought this and tried it, it's quite difficult but I'm getting there. Thank you for the advice
