MCR247
- Joined
- 7 Nov 2008
- Messages
- 10,290
But having 3tph from Manchester - London, is good for publicity, I doubt they are actually needed
IMHO the Manchester Airport - Cleethorpes service has nothing to do with other TPE services (even calling it "TPE South" seems a bit false, but that's the timetable description it got); it was added to the franchise to beef it up, but would fit better with EMT or maybe even Northern would be better than TPE.
Newcastle - Carlisle or York - Blackpool cross the Pennines but aren't part of "Transpennine", so I'm not sure why the Cleethorpes service is (it serves Manchester Airport, as a lot of TPE services do, but then so does Southport - MIA and Liverpool - MIA and MIA - Crewe!)
It's a hard service as it's not really in anyone's "area". EMT do serve Sheffield, Nottingham, Grantham and Peterborough, so there's some logic to it being with them.
One trouble with it (other than train length, bottlenecks etc) is whether it's better to run it from the middle or from each end. As EMT are running it from the middle, they don't have the resources at Liverpool or Norwich (so early/ late services don't go "full route" and trips are often capped before getting to the terminus if things go wrong).
Here in South Yorkshire the Sheffield - Rotherham - Doncaster bus service used to be jointly operated from Sheffield and Doncaster depots. Now, it's 99% run from Rotherham, which gives some benefits but a lot of disadvantages.
If the Liverpool - Norwich service was run as a joint Northern/ NXEA service then it would solve a lot of problems (but create others!)
EMT have two units a night at Norwich Crown Point where they receive the same sort of attention they'd get at Nottingham Eastcroft, harking back to the days when both depots were run by NX/Maintrain.
Not really, because if say a 158 fails in Liverpool, EMT can send a train to Sheffield to take it's path, whereas if it was based in Norwich, then they are screwed.
I think it makes more sense than putting TPE with Northern. I would keep TPE standalone rather than merge it with Northern. The current XC with TPE, and the Liverpool-Norwich route from EMT would make a good franchise as I see it.
Keeps routes with first class together, makes for a more complete XC map, and could facilitate the movement of some TPE routes to "more IC standard" rolling stock. In addition some routes could be amended and interlaced with current XC routes to keep the core frequencies but provide more journey possibilities. Norwich-Newcastle, Hull-Reading or Glasgow-Nottingham anyone?
Strikes and staff shortages leading to lots of cancellations and emergency timetables, as I far as I am aware.
PS. 3tph Manchester - London is needed, had pulled more passengers than ever on to the rails.
Just left a shortage of paths for Northern's local services while Virgin are sending 90% empty Pendolinos northbound in the morning peak and 90% empty Pendolinos southbound in the evening peak.
However, the Virgin service is only one additional service an hour; if it's caused several more Northern journeys to be chopped/ amended then I'd suggest that there are other factors at play too.
(Of course a "90% empty" Voyager is still carrying a decent load when compared to a short 142)
As for Liverpool-Norwich, having the service operated by EMT seems the most logical decision, as the route spends the greatest amount of time in the EMT area and East Midlands Trains is the central section of the route.
It does create problems as well though. Just a couple of weeks ago heavy snow closed the Hope Valley route and as EMT are based East of the Pennines they ran a Sheffield-Norwich service only that left the busiest part of the route (Liverpool-Manchester) with a severe lack of capacity.
