Arriva Midlands
aswilliamsuk
10 Jul 2016
The group has now announced the very large investment over the next year or so (including a number of recent deliveries), but right at the bottom it confirms Tamworth is being electrified.
The deckers for Tamworth appear to be BYDs - there are 39 coming, and 28 of those are known to be for the North East, so it looks logical that the rest are for Tamworth.
Russel
30 Jun 2022
Lichfield
Long overdue, but very good news!
Russel
30 Jun 2022
Lichfield
Not sure what fleet number it was, but I caught one of Tamworth's newly received Versas yesterday, it sounded like it needed putting out of it's misery, shame Tamworth didn't receive a few extra Pulsars instead..
ferry58
24 Oct 2024
Stafford
Shrewsbury didn't have any Pulsars allocated... just plenty of old Versas.
isaac27
19 Sep 2025
nuneaton
Would these replace E400s?
Yes they most likely would as the double deckers are used on the 110 and sometimes a couple of local routes. The 110 is supposed to have 10 busses at the moment with most of them being the e400 and the rest made up with euro 6 pulsars.
DS25
30 Jul 2024
You might get some pulsars from telford when the MMC’s arrive later this year
E B
30 Oct 2024
Nuneaton
Hopefully we will see one on the 6 at some point, however that would be quite unlikely
BusLink61
1 Dec 2025
Lichfield
Some might even need painting. Some of the Derby ones look like they were last painted when they were new
Yes and apparently some of the interiors are in need of a refurb, I’ve known it with Arriva where the seats get a refurb but doesn’t get painted or vice versa, both should be refurbed together ideally.
Trainman40083
29 Jan 2024
Derby
More rebuild than refurbishment. Very tired.
isaac27
19 Sep 2025
nuneaton
I was told by a driver that when the route changed double deckers can no longer be used on the main part of route 6 due to tight roads and the hill in baddesley. Plus the 6 isn’t usually busy enough to warrant a double decker. They do sometimes use double deckers on the Tamworth part of the route though.
E B
30 Oct 2024
Nuneaton
Thanks for clarifying about the roads in Baddesley.
Yeah, I have only been on the 6 once (in Nuneaton) and I was the only one on the bus. Hope Tamworth gets some new single deckers as part of this order
isaac27
19 Sep 2025
nuneaton
Tamworth’s 2155 (gn10kwh) has now run out of mot which means it will most likely be withdrawn and replaced with another versa.
sharpley
18 Aug 2018
I use the 6 quite frequently, as you say the problem is at the top of the hill in Baddesley Ensor. Very tight roads, plus very low trees when you turn right off the main road at the top. Been on a couple of early services where the driver has had to get out and knock on doors to get cars moved.
SSmith2009
20 Dec 2021
East Midlands
A good long beep of the horn usually gets them moving ;)
isaac27
19 Sep 2025
nuneaton
I went on 3920 last week and it was in a right state, most of the dashboard was missing and the brake pedal kept squeaking as well as mismatched seats of about 5 different types and a rather uncomfortable ride. The driver did say it only had a couple of weeks left on the road.
Trainman40083
29 Jan 2024
Derby
Looks like Arriva Derby Enviro 400 MMC started tracking on the 38 at 16.03 today. I saw it in service around 13.15.
4548
Russel
30 Jun 2022
Lichfield
All of the Max Citaros were total sheds, honestly I'm surprised it's took this long for something like this to happen.
