Airports not served by rail
Shimbleshanks
2 Jan 2012
Purley
Hasn't it been closed with the opening of the road tunnel?
Google says:
  • Recent developments: The Kingsway Tunnel, completed in March 2023, diverts vehicle traffic under the eastern end of the runway. This tunnel is intended for cars, trucks, and motorcycles, so pedestrians and cyclists still have to use the level crossing, although the road is now only used by airport staff.
AdamWW
6 Nov 2012
Google says:
It would be a long walk otherwise.
Brooke
13 Jan 2020
Switzerland
Thinking about the original post, which was about Dublin, is it true that arguably all Irish airports are not rail connected (including NI as well)?
I think the closest to being rail connected are Kerry (Farranfore is a flat 1km walk) and Belfast City (Sydenham just over the bypass)?
Northampton
Believe that's correct, although there have been noises about reopening Lisburn-Antrim to provide Belfast Int'l with a rail connection, and about building a connection from Limerick to Shannon Airport (serving Shannon Town and the Business development as it does so)
MarkyT
20 May 2012
Torbay
Although the wires don't reach Chișinău airport (or Prague, I think).
I know the new trolleybus routes in Prague are discontinuously electrified, with the vehicles having batteries to cover gaps in wiring.
The JFK Airtrain runs on conventional standard gauge track, aside from the centre rail for the linear induction motors to work on.
Also it serves a number of separate terminals in a central loop. A direct subway or LIRR link would have trouble negotiating the tight curvature of the elevated loop alignment so would likely have only one roughly central station and still require an APM transfer to each terminal. I think the Airtrain is a good concept for the particular airport layout.
10 Feb 2015
Just like Tees Valley, I wouldn't call a station 30 minutes away an airport station no matter what you call it.
But Teesside Airport station was built for the airport and once had a minibus link to the terminal. Sadly that didn't last and the station is temporarily (?) closed with one platform and the bridge removed.
TravelDream
7 Aug 2016
I'd still say that doesn't count.
Luton Airport Parkway isn't an airport train station (now of course there's a light rail link to Luton Airport, but previously there was a bus link).
Rhoose Cardiff Airport isn't an airport station and their bus link still operates.
