Advance Ticket - can I get refund due to tube strike?
Essexman
15 Mar 2011
I've booked advance return tickets from Paddington to Bristol for Wednesday 12th but if tube strike is on next week as well, it will be hard to get to Paddington (from Essex). In the circumstances could I get a refund on the tickets?
hairyhandedfool
14 Apr 2008
Ask the company you purchased the ticket from. If your ticket includes travel by tube I would expect you to get a refund, if not, you may be relying on 'a gesture of good will'.
Essexman
15 Mar 2011
Thanks - I booked through East Coast but tickets are from Paddinton to Bristol - no tube. I'll see what they say.
What ticket do you have to cover the first part of your journey?
What was your planned itinerary?
Would taking an earlier connecting service, and/or taking a later train from Paddington, be acceptable to you?
Essexman
15 Mar 2011
None. Will use Oystercard.
Leave Upminster about 8.15 travelling via Fenchurch Street
9.30 Paddington - Bristol
15.30 Bristol - Paddington
Return to Upminster via Fenchurch Street
Don't want to go much earlier. 10.00 from Paddington would be just OK but any later and I'd miss event I'm going to.
OK, you are still covered in the event of delays, providing you allow the minimum interchange time.
However officially, as you are commencing your journey using Oyster PAYG, you will need to queue at Paddington to get your ticket "endorsed".
If you were using a paper ticket (e.g. a Travelcard), you could simply board the next train.
I don't agree with that policy, but that's what it is, unfortunately.
Sorry that is not a valid itinerary, so you are not covered in the event of delays. The last train from Upminster to form a booked connection the 0802.
As the itinerary was never a valid one, and as the reasons are out of control of the Train Companies, I do not believe you are entitled to a refund. However discretion may be shown, you can ask.
If you are happy to give it a go, you need to be at Upminster in time to make the 0802. Providing you do that, you are covered, this would hopefully give you 63 minutes to cross London for your booked train, or 93 minutes until the 10:00 train, which should be enough time. I'll leave it to others to advise on possible alternative routes to get from Fenchurch St to Paddington.
Essexman
15 Mar 2011
Thanks.
I'll see what the strike situation is next week and decide whether to ask East Cost for refund (which I accept is down to their goodwill), or give it a go in which case I'll get the 8.02 and maybe buy a travelcard (usually takes 60 minutes Upminster to Paddington by the way. I use several routes but all take about the same time).
BurtonM
3 Feb 2014
Manchester
Is the problem mainly to do with an inability to do Fenchurch Street - Paddington without the Tube?
Surely you could use a bus, taxi, or - God forbid - a Boris bike?
transmanche
27 Feb 2011
c2c train to Fenchurch Street, walk to Moorgate and Hammersmith & City line to Paddington.
Should be do-able next week as the H&C was running a service every 10 mins from Moorgate today. (You could also try the shorter walk to Aldgate and pick up a Metropolitan line train and change en-route.)
Deerfold
26 Nov 2009
All of which will be slower than the tube and on a strike day difficult to find or get on.
