Access to TRUST
turbostarrob
6 Aug 2015
Hi all,
My partner is a guard for Northern and I wanted to ask if they can get access to the TRUST system for allocations?
I understand my partner can call control for allox and generally never uses TRUST.
If not, I understand. If possible, happy days.
Thank you all for your help!
Hi all,
Doubt it, unless they have access to a PC and a log on, which aren't given out without a decent reason.
Discuss223
30 Oct 2024
Rowsley
Hi all,
It's worth him asking.
I don't see what harm it would do.
There is also a public website called Realtime Trains which displays allocations and diagrams, along with unit numbers.
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
Agreed with those saying no. A guard does not need Trust access.
Haywain
3 Feb 2013
There is that, and many TOCs have far better tools for most of the things Trust might be used for. The OP's partner should talk to the TOC about their requirements. If it's about crew and train allocations then Genius Mobile might be appropriate.
skyhigh
14 Sep 2014
Northern don't use it.
It's pointless asking as the answer will be no. The instructions given are to phone control if you need to check a unit allocation.
Horizon22
Jobs & Careers
8 Sep 2019
The TOC may have a different system that they can access that displays the information they require. TRUST is often fed from other systems anyway, especially as the day progresses and unit swaps / faults / disruption occurs and changes are made to the original daily stock plan.
TRUST logins are only generally given to performance, delay attribution & service delivery (e.g. control) staff which is used in their daily work.
Freightmaster
Verified Rep
7 Jul 2009
Hi all,
As per previous replies, RTT already gives allocations for Northern Trains workings,
so why would you need TRUST access for that, potentially risking your partners job?
MARK
Geeves
6 Jan 2009
Rochdale
As others have said I'm not sure trust works outside of computers that have it installed through I could be talking rubbish.
Ask IS what the deal with a WebGemini log on that can be accessed through your phone through the internet and it's very simple to use. I don't think it would be a problem but again the answer might be no.
voyagerdude220
13 Oct 2005
MARK
It might not necessarily be up to date, particularly at times of disruption or simply when an unplanned set swap is taking place.
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
I think we need to be very clear here - are we trying to solve a problem for the person who works for Northern, or are we trying to solve a problem for you (their partner)?
If the former, they need to speak to their Reps/Management about a way to find out which unit they need to be working. They may advise that phone calls are the best solution.
If the latter, for example you’d find it helpful if your partner could look up random things on Trust, I’m afraid this isn’t going to be possible.
Tom
19 Jan 2008
35,000ft
To be fair with knowing how the data flows work (assuming things aren't broken in odd ways), the limit of delay between it updating in TRUST and RTT (and hopefully soom other systems!) should be no more than 5 minutes.
If you really want TRUST access, then you need to find some work inside the industry, mostly in performance or software engineering around it, and then get an industry sponsor to approve you to have access, and then you need to pay the exhorbitant annual fees relating to that access. I've got it on my computers/iDevices because of what I do - but it's really quite hard to get access normally.
voyagerdude220
13 Oct 2005
Fair points.
I have access to Trust as part of my Train Station role, but mostly just use it as a back up way of tracking trains and obtaining delay reasons, not for the unit allocation function.
Adam0984
18 Feb 2014
Allocations for work purposes can be found on realtimetrains.co.uk or by going to the platform/siding displayed on station screens or depot notices. Failing that allocations can be given by control with a quick (occasionally slow) phone call to control which for a member of traincrew would be 2nd nature. No need for trust for day to day work
