315 at Cambridge
jopsuk
13 May 2008
sitting in the sidings opposite platform 1&4 today, about 11ish. What was that doing all that way north?
4 Jun 2009
That was 315809. It came through Tottenham Hale around lunchtime assisting 317510 that failed earlier this morning back to Ilford. I believe 809 had a fault on it too, but I can't remember what. 317510 failed on departing platform 5 at Cambridge this morning working an Ely service with a loss of power.
But like you, I'm not sure how it ended up that far north in the first place. But stranger things have happened than 315's ending up at Cambridge.
O L Leigh
20 Jan 2006
In the cab with the paper
I'm afraid I was PASS up this morning so wasn't really paying attention, but it's very likely that 315809 had been stabled at Bishops Stortford overnight. With the Stratfords all CAPE'd and the Cl317's falling like flies it is likely that this was the only unit available to go and assist. I know the formation took a breather at Bishops Stortford in the back platform on the way back up because I could hear the Cl317's hustle alarms going constantly and saw the units coupled together.
Mind you, I have seen 2 x Cl315's work down to Cambridge as a semi-fast in the evening peak before now.
O L Leigh
jopsuk
13 May 2008
most appreciated gents- it was an odd sight at the start of a long journey.
Mention of the service to Ely from Platform 5- I've wondered about this before, as if I cycle to work I see it as I go over the Mill Road bridge at about twenty five past seven (ish?) I take it this is a case of making what would otherwise be ECS a passenger service?
prod_pep
8 Aug 2010
Rare as it is, 315s have run in service on the Liverpool Street - Cambridge line both in the days of WAGN and NXEA.
Z12XE
30 Sep 2005
Indeed, they've also made it up the other side to Witham (just this week), Colchester and Ipswich.
Better than nothing
barrykas
19 Sep 2006
The aftermath of Hatfield produced all sorts of unusual workings:
GNER utilising 365s between Kings Cross and York
313s reaching Cambridge
And I may have been imagining things, but I'm sure I saw a train at Kings Cross advertised as running to Stansted (presumably reversing at Cambridge)
And NSE days occasionally saw 313s and 321s on West Anglia services.
Cheers,
Barry
Aictos
28 Apr 2009
Cheers,
Barry
No you probably weren't imagining things as I've seen 313s with a Stansted destination as well!
They've also got Spalding as well.....
Any idea if any 315s are likely to be running that far as to Cambridge on Saturday?
O L Leigh
20 Jan 2006
A lot of the former WAGN units had the same destination blinds, so seeing a train at LKX with Stansted Airport on the front does not mean it was actually going there. Our Cl315's and Cl317's had all the GN destinations, including Moorgate, together with Leeds, York and Spalding. It just meant that they only needed to print up one batch of blinds rather than two.
I'm not sure Cl365's were used to cover GNER services when the Mk4's were withdrawn for checks. I know they used Northern's Cl321's as single units and pairs of WAGN Cl317's, but I'm not sure the Cl365's were used. Cl313's were then "stepped up" to cover for units in use with GNER.
O L Leigh
delt1c
4 Apr 2008
Cheers,
Barry
321's were regular performers on West Anglia services when new. 313's were not unknown as at the time they worked into Liverpool St on NL services via Graham Road Curve. I have travelled on several 313's on Hertford East Services
Failed Unit
26 Jan 2009
Central Belt
The mk4 problems were in 1996? I am not sure if the 365s were fully in service at that point. There was a photo of a couple of 317s at Newcastle. Like o l Liegh states I don't think the 365 has ever covered GNER. The only time I have seen them north of York was during testing.
bluenoxid
9 Feb 2008
Sandy was 1998. 317's and WY 321's were used but I cannot verify whether or not the 365's hit the lines north of Peebo
Skimble19
12 Dec 2009
I don't think GNER used the 365's as WAGN only had half the fleet at that time, where as they had a lot of 317's.
Z12XE
30 Sep 2005
Some 315 fun today
2B11 10.03 Stansted Airport - to London Liv Street was formed by a 315 failed at Stansted Mountfitchet, then was assisted by 1B37 10.15 SSD - LST (2x317s) to Bishop's Stortford, where it arrived 135 late.
barrykas
19 Sep 2006
Fairly sure said apparent Stansted service actually appeared on the departure boards at Kings Cross...But that was a long time ago, so I may be misremembering, or just plain imagining it.
4 Jun 2009
Some 315 fun today
315802. When the 317's were coupled up to the 315, the breaks still wouldn't come off the 315 hence the reason it took longer to move than it probably should have done.
317666
4 Sep 2009
East Anglia
Yeah, I was onboard the 08:32 Cambridge - Liverpool Street, formed of 315837, and the 19:28 Liverpool Street - Cambridge, formed of 315847 yesterday.
Z12XE
30 Sep 2005
Even more 315 fun today, GEML this time:
315848 & 842 worked
2J04 0556 SNF - SMN
1J05 0648 SMN - LST
ECS To Colchester
Booked for but didn't work 2F20 to CET (no 315 passed guard)
then 2F21 0935 CET - LST, but starting COL.
