313121 now in Network Rail yellow
Monty
12 Jun 2012
starrymarkb
4 Aug 2009
Exeter
Level 2 or 3 are in cab signalling. Level 2 uses existing track circuits to track the train with commands sent by radio. Level 3 is a GPS based Moving Block with the train reporting its position by radio back to the signalling centre
Nym
2 Mar 2007
Somewhere, not in London
Level 2 doesn't require lineside signals but can be overlayed with them.
From the lecture at the IET, the vehicles are fitted with ERTMS/ETCS Level 3
Manchester77
4 Jun 2012
Manchester
interesting how they're not planning on implementing it on the WCML I'd have thought they would as it would add extra capacity
Nym
2 Mar 2007
From the looks of the presentation, it's being implimented with higher priorities where re-signalling is required soon anyway.
anthony263
19 Aug 2008
South Wales
Yes but it would cause disruption and we cant that on the west coast mainline can we? :D
The Great Western is due for re signalling from 2016 which could help provide much needed extra capacity between Reading & London Paddington.
Class377/5
19 Jun 2010
It's part of the Thameslink Programme works to have ATO introduced in fives years time in the Core. Handly located not far from one of the new class 700 depots for the commissioning of the ATO on them prior to 24tph peak service.
jopsuk
13 May 2008
Still could happen though.
Seems rather pointless. Why are 42" HD screens needed?
because Xzibit has been involved. Not mentioned: the lowered suspension, the external monitors underneath the body, the bowling ball washing machine or the hot tub.
Searle
4 May 2012
Ladbroke Grove
What section of the Loop Line will this be running on, and will passengers be allowed on it? It's my local line, I'll hopefully look forward to seeing it there sometime :D
MCR247
7 Nov 2008
Well obviously passengers won't be let on a Network Rail Test train
barrykas
19 Sep 2006
Is it just me, or does the knob for switching control of the test track signalling from Kings Cross to Hitchin and back (as seen here) appear to be rather over-engineered?
gimmea50anyday
8 Jan 2013
Back Cab
Lol at pimp my train ride! With the work being done at wolverton I was wondering if it was West Coast Customs who won the contract! XD
Aictos
28 Apr 2009
The Northbound (Down line) between Hertford North and Bragley End will be used as the test facility, note in the peaks it will not be in use.
Everything is timetabled to be signed off and in use by July, that was from senior FCC management involved with the project.
jon0844
1 Feb 2009
It should have had two separate key slots, with each key needing to be turned simultaneously - while having been down in a bunker with retina scans, fingerprint detection, armed guards etc...
Aictos
28 Apr 2009
Been watching Goldeneye recently then???
Anon Mouse
20 Mar 2011
Any reason why its not being re-numbered into the class 930 range?
Looks good, never thought I would actually want to take a snap of a 313! :)
Crossover
4 Jun 2009
Maybe it is intended to be like one of those "big red buttons" that everyone just wants to press, even though it says not to :D
ert47
28 Feb 2010
In train entertainment. You can watch movies while cruising at an altitude around 1.1 metres.
attachment.php
^ amateur artist impression
jon0844
1 Feb 2009
attachment.php
Is that the train stuck outside Cambridge because of a red signal? Once again, I see a distinct lack of information to explain the delay.... ;)
In all seriousness, 42" HD screens are almost as cheap as more reasonably sized conventional ones.
Its probably a sourcing thing.
fgwrich
15 Apr 2009
Hampshire
Lol, unfortunatly not. Some work was carried out at Wolverton, but it looks like the main conversion works being undertaken by Alstom in Wembley - any custom shops around there?
