D365
- Joined
- 29 Jun 2012
- Messages
- 13,198
Hydroflex wasn’t ready in time!
Although it's due to start running from Glasgow today on demonstration runs around the Cathcart circle.Hydroflex wasn’t ready in time!
To be (somewhat) more specific - there's no guarantee that it will be running on hydrogen!Although it's due to start running from Glasgow today on demonstration runs around the Cathcart circle.
So perhaps a few days late but it's still there.
Guess you will have to go to Central and find out for yourself from today. Due to run from around 1200.To be (somewhat) more specific - there's no guarantee that it will be running on hydrogen!
The word on the street is that it won't be running on hydrogen. It will be running on the overhead wire. So look out for 'pan up'. It is noticeable that Porterbrook have spun this as being a 'hydrogen ready' train. What an absolutely con!!Guess you will have to go to Central and find out for yourself from today. Due to run from around 1200.
It has always been a trial unit to discover the issues involved with Hydrogen conversion.The word on the street is that it won't be running on hydrogen. It will be running on the overhead wire. So look out for 'pan up'. It is noticeable that Porterbrook have spun this as being a 'hydrogen ready' train. What an absolutely con!!
So the hydrogen fuel cell only powers the heating?! What an absolute joke. So in fact, as you say, it's basically a battery train with additional and unnecessary complexity and weight?It has always been a trial unit to discover the issues involved with Hydrogen conversion.
Hydrogen trail are actually battery EMUs with many fuel cells added to enable the use of regenerative braking and reduce peak power requirements form fuel cells roughly halving the number of fuel cells required for off the wires use.
The Porterbrook unit has a single fuel cell that doesn't even cover the train heating requirements, but is enough to provide the learning experience
They ran out of time to get it fully working before COP26.So the hydrogen fuel cell only powers the heating?! What an absolute joke. So in fact, as you say, it's basically a battery train with additional and unnecessary complexity and weight?
Pretty sure that wasn't how it was hyped:
https://www.porterbrook.co.uk/innovation/case-studies/hydroflex
No that isn't what I said, it can be used to help supply traction power but it isn't even enough to power the heating (if turned on) on its own on version 1 of Hydroflex.So the hydrogen fuel cell only powers the heating?! What an absolute joke. So in fact, as you say, it's basically a battery train with additional and unnecessary complexity and weight?
And will all this small print be made clear in the inevitable press releases trumpeting what the serried masses of Porterbrook and Birmingham's innovative engineers have achieved which is, er, converting a Class 319 from an EMU into a less-efficient EMU! I think not....this all seems like last-minute fudge to me.No that isn't what I said, it can be used to help supply traction power but it isn't even enough to power the heating (if turned on) on its own on version 1 of Hydroflex.
Hydroflex version 2 with much more fuels cell capacity isn't ready yet hence battery /OHLE for the COP running.
The key point about all hydrogen MUs as you have summarised is indeed "it's basically a battery train with additional and unnecessary complexity and weight"
As predicted it was running off the overheads on its first run around the circle this morning.The word on the street is that it won't be running on hydrogen. It will be running on the overhead wire. So look out for 'pan up'. It is noticeable that Porterbrook have spun this as being a 'hydrogen ready' train. What an absolutely con!!
https://twitter.com/PorterbrookRail/status/1456211511341428739?t=Id6pfI2nbstrJh4CUsOc6w&s=19#HydroFLEX arriving at Glasgow Central station this morning. Thanks to all our supply chain partners, a brilliant example of the UK rail supply chain working together #TogetherForOurPlanet #COP26 https://t.co/uGx0BvDt3L
Yep, you can see the pantograph is up in that video. How farcical.As predicted it was running off the overheads on its first run around the circle this morning.
Video of it arriving at Glasgow this morning was posted by Porterbrook:
Does anybody know when the "hydrogen" unit is running tomorrow?
I'd quite like to go out and get a photo.
Is this its path?? https://www.realtimetrains.co.uk/service/gb-nr:K09514/2021-11-05/detailed
I managed to catch the 230 at Crossmyloof yesterday: https://www.flickr.com/photos/amaccaluim/51648565317
Just stumbled across this topic. You use the unit kW, which is a unit of power in a lot of this, do you mean kWh, which is a unit of energy? Assuming the 440kW of Gemini its output power? But then say 0.75d/kW, guessing that's actually 0.75d/kWh? Sorry to be pedantic but is a little confusing as to what's being referred to at each point.Genini works Based on 440v x 1000amps = 440,000 watts, (440kw) and 0.75d per kw charging, (with inflation from 1956 to today is about £2.10 per kw) / 100 mile range… 21p per mile, Gemini is still more economical than a Class 230…
For the 230, Based on the quotes of £2.20 a mile, c60 mile range, and reported (wiki) 4*106kw batteries at 750v to operate… the operating characteristics are similar, its batteries cheaper, but its per mile cost considerably higher.
How do you know that it won't be?So the new factory will not be flat out.
Could become a new fashion item in the US..buy an old London tube train as a play thing.According to the article on Vivarail website "A week of firsts at COP26", a potential US customer wants to buy 230001. Looks as if Vivarail have an order for one two car train for the "pop up". So the new factory will not be flat out.
History repeats itself…
in 1956 the BTC negotiated with Scottish power to charge 0.75d per unit to charge 79998/9 (later Test Unit Gemini) a 2 car Battery powered Derby lightweight to run on the Aberdeen Ballater line.
I understood it could manage around 100 Miles on a charge, but was charged at each end of the line.
(railcar.co.uk website).
Gemini is still with us, and in Scotland too.
I dont know its performance today, but back in the 1980’s Ive ridden on it for upto 40 miles on a charge using its aging batteries then.
(someone keep me honest and check my maths)
it does have some efficiences though, according to Rail Engineer the 230’s battery/genset is c3 tons, Geminis was over 30 tons. Its batteries cost £50k in 1956, thats just over £1mn in 2021.. Vivarail wins on that, Rail Engineer suggests is £100k, though only a 7 year life… when I was on Gemini its batteries were 30 years old and still half life.
Summice, in 65 years, weve reduced the upfront cost & weight of the battery, at expense of the operational range and battery life.. but still not progressed technology beyond a 2 car unit running on test in Scotland…
its a pity Gemini isnt in Glasgow this week, it’d certainly give the 230 a run for its money… if Gemini had the batteries of the 230 replacing the size/weight space it’d straight beat the 230 into the ground in operational range and cost… its not too late to try it, and Gemini does need new batteries I understand.
Lots of photo and video updates on the ex-Class 314 conversion at:Are there any details of the class 230 run on Saturday, I’d be very interested in photographing it? Thanks for any info, I couldn’t see anything on RTT.
The class 314 has just been renumbered 614209! Series for units powered by diesel ‘or other fuel’.
That's my video thanks for sharingCabride of a Barrhead trip yesterday has been uploaded, can't recall seeing one of a vivarail unit before? Great way to see how the wiring has progressed too:
I’m not even sure where 001 is based now that Long Marston is a Porterbrook site.Has the 230 made it all the way back to base yet, or is it still en route and being recharged for the umpteenth time?![]()
230001 is still at Polmadie and the plan is to bring it to Bletchley for storage in the next few weeks (by road). There it will be modified with Fast Charge equipment and tested, ready for working on the Greenford branch in 2022, subject to Vivarail winning the job.I’m not even sure where 001 is based now that Long Marston is a Porterbrook site.
ROTFLMAO….So it isnt capable of moving very far under its own power…. And “… storage alongside 230003 - 230005…” sounds appropriate - I’m not surprised but I didn’t realise the other three were already sidelined.230001 is still at Polmadie and the plan is to bring it to Bletchley for storage alongside 230003 - 230005 in the next few weeks (by road). There it will be modified with Fast Charge equipment and tested, ready for working on the Greenford branch in 2022, subject to Vivarail winning the job.
230003-005 aren't stored. What do you think is working the Bedford-Bletchley service (the ones what West Mids can find crews for)?ROTFLMAO….So it isnt capable of moving very far under its own power…. And “… storage alongside 230003 - 230005…” sounds appropriate - I’m not surprised but I didn’t realise the other three were already sidelined.
Time to ditch the whole D-stock experiments IMO.
Well Polmadie to Bletchley is quite the distance... I don't think VivaRail have ever designed it as replacement for Intercity Routes. And the Bletchley-Bedford Shuttle barely runs due the the Covid Timetable.ROTFLMAO….So it isnt capable of moving very far under its own power…. And “… storage alongside 230003 - 230005…” sounds appropriate - I’m not surprised but I didn’t realise the other three were already sidelined.
As others have pointed out, you have misunderstood. 230003 - 230005 are not stored, they are in active service running the Marston Vale line. Bad choice of words, original post now edited. And as others have pointed out, Polmadie to Bletchley is some 360 miles and 230001's six big batteries were never designed to go that far. You wouldn't get steam locos going that distance without stopping for water let alone a battery train without charging it so perhaps it's time to ditch the whole steam experiment Mr Stephenson IMO ROTFLMAO FFSROTFLMAO….So it isnt capable of moving very far under its own power…. And “… storage alongside 230003 - 230005…” sounds appropriate - I’m not surprised but I didn’t realise the other three were already sidelined.
Oh and p.s. 230001 is still capable of moving further under its own power than HydroFlex, which needs a pantographROTFLMAO….So it isnt capable of moving very far under its own power….
