1A85 18.10 BTN - VIC sent wrong way
Bromley boy
18 Jun 2015
These things don't happen very often which is why I am inquisitive. Don't worry about it then if it is an issue
It happens more than you think.
The trick of course is to realise and not to take it, but very easily done, particularly if the driver regularly takes the London road direction.
High Dyke
1 Jan 2013
Yellabelly Country
Indeed... three alone in my business area in the same week; none involving me.
I know, and these things don't happen very often which is why I am inquisitive. Don't worry about it then if it is an issue
You know the reason for the delay.
I doubt you are going to get an exact reason why the mistake was made, other than the fact we're all human and so we're all capable of making mistakes for a variety of reasons.
Bromley boy
18 Jun 2015
I’ve always wondered what happens on the signaller’s side if they send a train the wrong way. Is it a full no tea and biscuits job?
I’ve had a couple now, thankfully realised in time, called the signaller and wait a couple of minutes for the interlocking to “time out” and the route to be put back correctly.
Tomnick
10 Jun 2005
Simply - no! Not in our area at least. No doubt their manager will have a word with them (mainly with a view to protecting their delay minutes budget, but also to make sure there's no obvious underlying problem), and if they do it repeatedly there might be some further action, but it's all treated fairly sensibly.
Failed Unit
26 Jan 2009
Central Belt
I bet the mess room banter lasts a while. Just like the “failed to stop” does for a driver. Oi Bill you sending that unit to Grantham instead of Lincoln again... (select stations of your choice)
Interested if you are sent on a different route (but valid) such as you are an express and you are put on the slow, would the driver expect to be told by signaller or just keep going?
Bromley boy
18 Jun 2015
Thanks that's interesting.
If the driver takes it it's treated in the usual heavy handed fashion! Although, as I understand it, it's not actually classed as a safety of the line incident so won't follow you around if you move TOCs.
The embarrassment of having to explain to the passengers is the biggest worry, although if I'm ever in that situation I'll just blame the network rail signaller :D.
jizzer
2 Feb 2012
It is treated as a SOL incident and shows a driver's lack of situational awareness.
Some are worse than others in the time that a driver has to view the wrong routing signal.
Wrong routes offered have doubled over the last couple of years and is a massive issue for Network Rail.
30907
There are (were?) specific local instructions permitting alternative routes without a specific instructions. Brixton and Shortlands Jn on the Chatham come to mind, are there others?.
GW43125
8 Dec 2014
There's a story of a District driver who took the route towards Rayners Lane (that's a Piccadilly route); he never heard the end of it!
GW43125
8 Dec 2014
I *THINK* that SW mainline express drivers won't challenge a route via Chertsey if they sign it. Similarly, if you're empty stock routed via the Hounslow loop instead of Twickenham or vice versa.
Bromley boy
18 Jun 2015
And the signaller's!
I know at least a couple of drivers who've taken wrong routes and not had it endorsed onto their licences. It doesn't seem to be treated as seriously as TPWS against a red, or even failure to call etc.
Anecdotally it seems more of a problem from PSBs than IECC/ROCs - perhaps unsurprisingly?!
Bromley boy
18 Jun 2015
Knowing thosd locations rather well, If you were fast to Bromley South then yes, you could accept it as it gets you to where you need to be. You wouldn't question a routing via Stewart's lane either, in and out of Vic, although it takes a few minutes longer.
If you were scheduled to call at intermediate stations between shortlands and Vic then definitely not, for obvious reasons. You could only accept the Catford Loop if specifically instructed to do so by the signaller.
theageofthetra
27 May 2012
Beckenham
I guess the seriousness of the incident would also depend if the wrong route taken wasn't signed by the driver or not cleared for that stock?
theageofthetra
27 May 2012
Beckenham
And sign it!
Bromley boy
18 Jun 2015
And sign it!
Absolutely. Taking a route you didn't even sign would certainly look worse than taking a route you drive regularly, although it has certainly happened many times.
On the other side of the coin I know a driver who was offered a route that would have been an acceptable for the service but was out of gauge for the (unusual for the route) stock he was driving. Noticing that was one of his better days in the office, and he made sure everyone knew about it afterwards!
Confused147
12 Aug 2017
Why are people blaming the driver for a train being routed the wrong way? Do train drivers set the points, signals etc etc or is that the job of the signaller?
Bromley boy
18 Jun 2015
The driver is required to recognise a wrong route if it is offered. If they take it they get into more trouble than the signaller who set it!
roversfan2001
19 Feb 2016
Lancashire
No, but the driver drives the train along the route.
(NB: I'm not blaming the driver here).
The signaller is wrong for setting the wrong route and the driver is also wrong for accepting it.
whhistle
30 Dec 2010
I was witness to some funny goings on at Rugby once.
There was something in Platform 2, so that was OOU. For some reason, something was in platform 1. The signaller had accidently routed the stopping Bimringham service on the through road. After waiting for the interlock to time out, [the Signaller] then figured out the Birmingham simply didn't have a platform, and sent it back on the through road, not stopping at Rugby.
Jimini
8 Oct 2006
Reading
Pretty sure I read on here a few months back that Virgin drivers are trained to take the Northampton loop rather than via. Weedon without questioning it with the signaller if routed that way?
Peter Mugridge
8 Apr 2010
Epsom
I seem to recall an instance where a Eurostar was once signalled towards Victoria instead of via the Stewart's Lane Flyover to Waterloo... ( I believe the driver realised in time ).
GW43125
8 Dec 2014
I too have heard that story but I don’t think he realised in time...
Maybe it was a French driver and he’d had enough of Waterloo?
farleigh
1 Nov 2016
I must say that it seems an unfortunate culture on the railways if people are disciplined heavily for what are genuine mistakes like this. A healthy management culture would involve people being able (and expected to ) learn from their mistakes rather than carrying it with them on their record. Apologies if I have mis-read it but it would seem to me that you people who work on the railway do the very best you can and mistakes are comparatively rare. They do of course happen.
westcoaster
4 Dec 2006
DTOS A or B
On thameslink we have a few routes where it sates in the sectional apendix we do not need to challenge a route, unless booked to call at a station.
These include
blackfriars to bromley south via catford (can go via beckenham junction)
Purley to Gatwick via the quarry line (can go via redhill)
Victoria to brixton (can go via stewarts lane)
Tulse hill to east croydon via crystal palace (can go via selhurst)
