185s question
TheGrew
31 Jul 2012
The 185 wasn't more broadly produced because they were designed for the steep gradients of the transpennine routes and uses the same engines as the Voyagers. It is quite heavy and thirsty compared to the 158 for example.
M60lad
31 May 2011
With 185s having the same engines as Voyagers why don't the engines sound like Voyager engines?
TheGrew
31 Jul 2012
I'm not sure but it might be partially down to the transmission. The Voyagers are diesel electric with the engines driving an alternator that generates electricity then used by electric traction motors (a bit like a Hybrid Car). The 185s use a more conventional transmission (more akin to a normal car).
Pete_uk
28 Jan 2017
Stroud, Glos
I remember someone calling them 'The lards bucket lard bucket' as they were so heavy.
Watching videos of them, they do get a move on. I guess it's a case of a order to meet a particular need as opposed to a jack of all trades.
Mollman
21 Sep 2016
Preston
There also wasn't much demand for new DMUs by then, and what demand there was went to the lighter weight Turbostar.
D365
29 Jun 2012
Was the Class 170 still in production when First Transpennine placed the order?
Mollman
21 Sep 2016
Preston
The last ones were built in 2004/5 so I expect it would have been. No new DMUs were then ordered until the 172s in 2010.
fgwrich
15 Apr 2009
Hampshire
IIRC, I believe First were impressed by Siemens can do attitude at the time and following large orders of the Desiro family for both FGE / SWT & the SRA + Central / Silverlink that played a part in Siemens being a rolling stock partner for the FTPE Franchise with Keolis.
Meanwhile, didn't Arriva have a proposal for an Alsthom built unit, possibly something on the Coradia platform (probably just as well they didn't!).
As for the Turbostar option, it's likely they were ruled out from the early stages. Although they were in construction from when the 185 was ordered till when they started entering service, the 185s were ordered with the intention of having a superior performance than a 158 and something matching that of a class 180 - presumably for the WCML sections which a Turbostar wouldn't have met.
Either way, like most Siemens built units, they've been excellent performers over the years even if they are a little on the heavy side. Just a shame that a, like the 444 nobody else ordered them and B, the SRA cut the order number down!
Ash Bridge
17 Mar 2014
Stockport
Either way, like moose Siemens built units, they've been excellent performers over the years even if they are a little on the heavy side. Just a shame that a, like the 444 nobody else ordered them and B, the SRA cut the order number down!
Yes, if only they had been built with an additional intermediate car or perhaps a gangwayed cab as per the 444?
TRAX
2 Dec 2015
France
There’s more to the sound of an engine than just the model of it. The train that’s around it, the position of the engine, etc, a lot of stuff plays a part in how an engine sounds.
And as was pointed earlier, the transmission is different.
darylyates17
8 Nov 2015
St Helens
185s have big exhausts which give them the unique meaty sound (I personally think Siemens designed them to sound like they do) you can clearly hear the block sounds the same as the 180 and the Voyagers if you listen carefully when the engines are idling.
31 Aug 2020
Morecambe
Always wondered this about 185s, how come they are all numbered 185/1s? I don't recall any overhauls similar to what the 91s went through in order to be re numbered to /1s rarther than /0s
notadriver
1 Oct 2010
Technology has moved on. The 195 has similar performance with less powerful and more efficient cleaner quieter engines.
fgwrich
15 Apr 2009
Hampshire
Thanks to the mechanical transmission set up, you can hear a touch of similarity in this video.
Still excellent units though!
darylyates17
8 Nov 2015
St Helens
Same engine and gearbox (with shorter ratios) as the 180s so will sound similar you can’t really hear the exhaust inside unless in a tunnel.
A lot of it is due to the mechanical gearbox on the CAF units helps with acceleration.
notadriver
1 Oct 2010
Yes 172s had the ZF 6 speed eco life box and were superior in acceleration to 16x and 170s. They had a 485 bhp engine per car able to hit 60 mph in around 83 seconds. A typical 158/ 166/168 takes around 100 seconds with the torque converter gearbox. The 523 bhp engine each 195 vehicle can produce a 67 second time to 60 mph in power mode.
simonmpoulton
25 Jun 2011
Isn't a mechanical gearbox in these newer units inherently less reliable than the hydraulic gearboxes in the older units? Or has modern gearbox design moved on to the point where this isn't the case anymore?
TRAX
2 Dec 2015
France
While I don’t have facts and figures about their reliability, it does seem to be the new norm in the UK (see all of the diesel Civities), has been in use abroad for some time, and ZF make reliable products.
Bevan Price
22 Apr 2010
But 172s seem better than 196s at climbing banks, despite a slightly inferior power to weight ratio. From a standing start at Bromsgrove, pairs of 172/2s are the only dmus that I have had passing Barnt Green in less than 5 minutes.
notadriver
1 Oct 2010
I wonder if the gearbox is set up differently on those.
TRAX
2 Dec 2015
France
For starters it’s not the same gearbox model, the Civities have the successor of the 172’s ZF Ecomat Rail, the ZF EcoLife Rail, which works a bit differently.
IanXC
Emeritus Moderator
18 Dec 2009
4th vehicles were on the agenda at the outset, you'll notice the vehicle numbers are 51xxx, 53xxx and 54xxx. Authorisation to purchase these was never obtained from the SRA.
43096
23 Nov 2015
I assume you are referring to skipping 52xxx? The 521xx series (and indeed most of the 52xxx series) is not available as it is used for Sprinter vehicles.
Ash Bridge
17 Mar 2014
Stockport
Something I hadn’t noticed, thanks for pointing it out!
driverd
29 Mar 2021
Arriva were going to go with voyagers. I think I still have an old leaflet with an artists impression of one pulling into Huddersfield, knocking around somewhere.
It was less about the WCML and more about the gradients - although as was realised later in the franchise, the 170s had an advantage on Hull/South routes in that they could utilise SP speeds. A great shame it wasn't realised sooner really (from a personal standpoint) as I find the 170s far superior to the 185s.
Allegedly (so the senior management said), the then MD preferred the clean fronts of the 360s to the gangways of the 450s, therefore it was to be flat fronts!
Personally I always found the 170s a better unit from the passenger, staff and in service reliability perspective (things like air con, engines and toilets generally worked on 170s, less so the 185s) but the performance of the 185s remains impressive.
Spartacus
25 Aug 2009
The Pennines have a history of producing rather specialist units, the old 110s and 124s being good examples.
The 170s were nice in their way (not least due to the declassified section) but they weren't half sluggish over the hills compared to the 185s.
Crossover
4 Jun 2009
They also can't do SP (Sprinter) differential speeds because of their axle loading. From memory, this was of particular detriment on the Hull line where the 170's largely plied their trade. The acceleration of the 185 made up for the lower top speed on that line though
