150002 to Portsmouth
BestWestern
6 Feb 2011
If anybody fancied a rare photo opportunity today, FGW's normally Reading-based 150002 has found it's way onto a Portsmouth diagram .
It worked 1F03 06.30 from Cardiff, will shortly depart Portsmouth on 1F14 10.23 return, and assuming it remains on diagram will work 1F23 14.30 from Cardiff and 1F32 18.23 return, finishing with 2C95, the 22.00 back to Bristol. May well be late, it lost 20 minutes on the first trip down.
Greenback
Emeritus Moderator
9 Aug 2009
Llanelli
I don't find the 150's too bad, but they are inferior to the 158's, and not really suitable for Cardiff to Portsmouth services.
Monty
12 Jun 2012
Cor that's brave! 001 & 002 are not noted for their reliability..
Quickthorn
21 Dec 2012
I don't know it's full movements yesterday, apart from the fact it was 1F36 Westbury-Temple Meads (20 mins late), so probably on that diagram yesterday as well.
I also noticed yesterday a 3 car 158 set doing the Severn Beach. Apparently, that sometimes happens when a 158 set is under par and can't be relied upon to do much else, so perhaps they took the 158s off the Cardiff - Portsmouth and replaced it with 150002.
455driver
10 May 2010
150002 has been working off Exeter (normally around the Bristol area though) for the last 2 weeks, 150001 is still failing (oops I mean working) on Reading to Basingstokes.
fgwrich
15 Apr 2009
Hampshire
They must have some faith in it - they let it loose last Sunday on the Exeter - Penzance - Exeter all stops. But the use of 002 on long distances is a little er.. surprising!
PHILIPE
14 Nov 2011
Caerphilly
To work 06 30 Cardiff to Portsmouth, it should have worked 20 30 Portsmouth Hbr to Cardiff last night and serviced overnight at Canton.
NX
6 Jan 2014
Yes, the bag of bones that is 158955. There a total nightmare on the branch.
NX
Parallel
9 Dec 2013
158953 was only running as two coaches when I caught it the other day too, it was coupled to 158763 (Brighton - Great Malvern).
BestWestern
6 Feb 2011
A 158 was caped yesterday at P'mouth & Southsea on it's way to Cardiff, with continual suprious brake applications. Whether that set is back in traffic today I don't know. Availability seems patchy at the moment, and 150001/002 are generally spare at the weekends I believe, so the extra coverage in the Bristol area may be to allow some shed time for poorly west units.
Parallel
9 Dec 2013
I actually boarded 150002 this evening, it seemed very bouncy - more so than other Sprinters... Maybe it was just me imagining it but the member of staff collecting litter seemed to be getting thrown about the carriage a little!
It was actually very clean and there were some nice touches, like pink along the overhead luggage racks, clean floor and reflective fixings above the LED lights to make them less glare-y! On the bad side it was running 15 minutes late, 22 late by Filton and rolled into Cardiff 30 late, according to RTT...
fgwrich
15 Apr 2009
Hampshire
Our /0 twins are probably the best 150s in the FGW Fleet at the moment - the quality of the refurb certainly shows the rest of the ex LO & LM Sprinters up, even if they all retain their original seats.
J123
10 Feb 2014
I often see a 3 car 158 + a 2 car 150 making up one train pass through my local station Swanwick on the Portsmouth to Cardiff service.
BestWestern
6 Feb 2011
The service is strengthened when busier than usual loadings are expected; generally if there is an event taking place somewhere. The booked traction is always a 3 car 158/9 (or 158 798), and a 150 will provide any extra capacity required. This can be either a 150/1 or a /2, though the /2 units are far more suitable due to their refurbished interiors and end gangway connections.
davetheguard
10 Apr 2013
I noticed Reading's 150 002 at Portsmouth Harbour on Saturday 2nd August, on the 10.23 departure to Cardiff Central.
This unit is normally used Monday to Friday only - running up and down between Reading & Basingstoke only.
I suppose 150's do see some use on FGW's Portsmouth - Cardiff's in place of 158's; but presumably use of one of Reading's 3 car "Tiny Tanks" Sprinter prototypes away from the Basingstoke branch is very rare. Has it ever happened before?
  • 1. Reading's Tiny Tanks 150 002 on 10.23 Portsmouth Harbour to Cardiff Central before departure.jpg
davetheguard
10 Apr 2013
Oops! Well-spotted swt-passenger.
Mods, you might want to move my post to merge with the other thread.
Ash Bridge
17 Mar 2014
Stockport
Just looking at your shot of 150002 Dave. Noticed the two outer cars have got some sort of raised panels on the roof,was this unit originally fitted with Air conditioning by British Rail, and if so is it still functioning?
Monty
12 Jun 2012
If it is still fitted it's certainly not functional anymore. I've been in both units enough during the summer to know that. ;)
455driver
10 May 2010
It was fitted with air con when in use as a test bed unit (numbered 154002?), the wiring on these units is interesting* to say the least.
* not the exact word used but I couldnt post the exact words used!:lol:
Ash Bridge
17 Mar 2014
Stockport
Thanks for the replies Monty & 455Driver, just wondered why centre car dosen't appear to have had the equipment fitted also.
455driver
10 May 2010
When it was in use as a testbed it was formed as only 2 coaches, that might be one possibility.
Ignore the above its rubbish.
I have just googled-
sprinter 154002
and it looks like only one coach (the one without the toilet) was fitted with air con.
Kite159
27 Jan 2014
West of Andover
I was surprised at the appearance of the 2-car 158763 for the 15:46 Brighton to Bristol service this afternoon.
Although not knowing the diagrams, this could be just the usual arrangement for that service.
PHILIPE
14 Nov 2011
Caerphilly
Booked 2 x 158 (2 Cars). However, was short formed today with 763only. Obviously 766 didn't want to play. Usually if one not available a 150+158 combo will work.
pompeyfan
24 Jan 2012
On Saturday I went from Portsmouth to Exeter and return, and due to various ticketing restrictions traveled via westbury, I was surprised to see how many services were strengthened on the line and around Exeter, sadly though not a single train of the day was on time for me, the service from Portsmouth to westbury lost time presumably due to extended dwell, the HST apparently had issues around paddington, and on return we lost time outside Tiverton parkway as an XC HST threw a wobbly, and finally the 158/150 combo hit something around mottisfont and caused an emergency brake as well as a 15 min wait while the guard and driver checked the brakes, this then meant we lost our path on the netley and had to sit behind a stopper losing even more time!
387star
I worked that train was a nightmare going to Brighton
Was due to the booked coaches involved in a fatality at Nailsea on the day before
Parallel
9 Dec 2013
This unit was running to Weymouth today! Was nearly 20 mins down when I saw it.
