flymo
The Russian land border with North Korea extends for about 11 miles, roughly the distance from Newcastle to Sunderland.
Does Wales have any motorways apart from the M4?Yet Dorset, Cornwall and no doubt plenty of others have none.
The Bristol Channel has the second highest tidal range in the world, at 15 metres. Spring tides can be as high as 55ft.
And the Black Isle isn't an island.Lewis and Harris is one Island, not two as the name might suggest, and the third largest of the British Isles
Ordnance Survey election maps seems to show otherwise...
If you were to fly directly, the shortest straight line between London Heathrow airport and Auckland airport in New Zealand, around 11,400 miles, only around 1,300 miles would be over land and the only major land masses you'd fly over would be Norway and Russia.
Election boundaries aren't always the same as district boundaries.Ordnance Survey election maps seems to show otherwise...
NY050690 is apparently more empty!Has someone already done OS grid square SE8322. The dullest emptiest of all the grid squares.
Yes, but the A48(M) is the only completely in Wales. Also, what is a branch line, not the Weymouth Quay branch then?Does Wales have any motorways apart from the M4?
Dorset also does not have any branch lines, the last to Bridport closing in the mid 70's
And Epping Forest.You can find the City of London symbol (red cross on a white shield) up to 20 miles from central London. It manages several commons in places such as Ashtead (near Epsom), Farthing Down (near Coulsdon) or Spring Park (Bromley).
I thought that was only the old mileposts?All road signs giving distances to London have Charing Cross as their datum of reference.
A great circle is a straight line along the surface of the globe, it's only a curve on a map.At the risk of being accused of severe pedantry, I'll observe that the shortest distance between those two points, as with any two points on earth, will be a great circle, rather than a straight line.
Hence 'along the surface' - if you were an ant following the line you would never know that it curves in three-dimensional space.It's curved in three dimensions. Unless you're a flat earther.
Yes, it's curved in three-dimensional space. However, in two-dimensional space (which the surface of the Earth is at human scale) if it were possible to walk on water, etc. you would turn neither left nor right when following a great circle route.What an ant thinks doesn't change the fact that the Earth's surface is curved therefore any line drawn on it is also curved. The clue is in the name "great CIRCLE".
I'm sure there's a word that could be used to describe a line that can be followed without a change of heading...
I love a good pedantic argument...The shortest distance between two points over the surface of a sphere, or an approximate sphere in the case of the earth, is a non-straight great circle. Not a straight line.
And vice versa?A great circle is a straight line along the surface of the globe, it's only a curve on a map.
By what amount does your heading change while following a great circle?
Is it pedantic to say a circle is not a straight line? No, it's a statement of fact.
Argh... terminology and frames of reference - the cause of many a great argument.Me too!
Heading changes constantly while following a great circle arc.
