Yellow fasteners on concrete sleepers?
83G/84D
28 Oct 2011
Cornwall
Can anyone explain what these are and what they are there for?
Lateral restraint anchors, aka lateral resistance plates. Most of it is out of sight, there’s vertical plates attached that you can think of like a small boat‘s keel. Helps retain the track position on curves.
There’s a few slightly different designs in use, the Unipart rail catalogue describes a couple here, one fits the middle of the sleeper and the other on the end: https://www.unipartrail.com/wp-content/uploads/2022/08/Lateral-Resistance-Plates.pdf
Benefits of Trackwork’s Lateral Resistance Plates:
Vertical ‘spades’ installed directly into compacted ballast provides increased stability and lateral resistance compared to alternative solutions.
Faster installation, with vertical ‘spades’ retro-fitted without the need for ballast excavation
Heavy Duty construction, eliminating the risk of deformation or buckling.
83G/84D
28 Oct 2011
Cornwall
Was it on a curve?
Yes a slight curve.
Thanks for the explanation, it was really helpful.
