Yellow cone-shaped things beside rail?
rockford
18 Apr 2011
The title says it all really... Lol.
What are they?
They're bright yellow cylinders with a cone-shaped top which points down under the track with a black tube sticking out which runs under the rails.
I did try searching, but I have no idea where to start with that ^ description! :)
They seem quite random in their placement and they don't seem to correspond to any other infrastructure.
Thanks!
Andy.
7 Nov 2009
Newcastle
Ones I normally see are small barrels with a flat top. Guess there is no standard design.
driver9000
13 Jan 2008
I have seen at least 3 different designs of flange greaser, the most common is the flat topped barrel round here though.
My other thought was that it could be a sandite bin although they are quite big and I've never seen a cylindrical one.
142094
7 Nov 2009
Newcastle
Any ideas:
1) How much lubricant is actually used either per passing train or day/week?
2) How often they are refilled?
3) What kind of lubricant is used (assuming that it is something that is not harmful to the environment if it gets into the soil/water)?
Hydro
5 Mar 2007
Any curve satisfying certain conditions in terms of radius/speed will generally require a lubricator.
They are filled up, and I don't mean to sound like I'm being patronising, when they are below a certain level/empty. They should be checked on patrols for the levels of grease in them. I think it's the same lubricant that we apply to fishplates before the summer. I don't think it's especially harmful, but it is very messy. Thick, black and smelly.
Hydro
5 Mar 2007
They are for the axle counters, containing the electronic bits that keep count of the axles passing over the counter heads.
rosswilson
7 May 2011
beat me to it! Here is a picture:
Is that what those yellow boxes are? Axel counters? I always thought they were just junction boxes for the wiring.
There are literally dozens of these all within 100m at Cardiff Station.
Why would there be so many axel counters at a station?
Ross
brillopad
5 Feb 2011
Ross
No they aren't axle counters - axle counters are located close to the rail and sense the passage of a wheel rather than the axle.
I don't see them very often but one place is Dawlish seafront where the sea can inundate the track and make track circuits unreliable.
142094
7 Nov 2009
Newcastle
Ross
They look similar to point heaters, which may be what you find at Cardiff.
Hydro
5 Mar 2007
They're not axle counters themselves, they're the counter electronics for the axle counter. 1 wheel = 1 axle, which is why they're called axle counters and not "Half the number of wheels on a train counters".
