Yahoo news article regarding Railcards and Trainline
father_jack
26 Jan 2010
Trainline announces Railcards will no longer work on all trains​
Katie Collier
Tue 22 October 2024 at 10:35 am BST2-min read
Customers with a Railcard will need to check if they can get on earlier trains than what they have paid for <i>(Image: Kirsty O'Connor/PA Wire)</i>
Customers with a Railcard will need to check if they can get on earlier trains than what they have paid for (Image: Kirsty O'Connor/PA Wire)
Trainline has issued an update for customers with a Railcard to help them avoid being fined when travelling on trains.
The change means passengers can no longer use their Railcard on all trains.
Customers will need to check if they are able to get on earlier trains than what they have paid for as some railcards “can only be used on fares that’re above a certain price, at a certain time.”
Trainline announces change to flexibility of Railcards​
In an explanation to customers, Trainline said: “Generally, all Railcards can be used for discounted train fares during Off-Peak times, weekends, and public holidays.
“Some, like the age-related Railcards, can be used during Peak times with a minimum fare, and the Disabled Persons Railcard can be used at any time.
“Some Railcards have specific restrictions on the times you can travel.
“Others can only be used on fares that’re above a certain price, at a certain time.”
Further explaining the change to customers, Trainline gave an example of where the change would come into effect.
The full terms and conditions for each Railcard can be found on the Trainline website.
It said: “For example, if you’re travelling between 04:30 am and 10:00 am, some Railcards can only be used on fares that cost £12 or more.
“This is especially important when you buy Anytime tickets or other flexible tickets.
“If you travel on a train before 10:00 and have used your Railcard to buy your ticket, make sure you didn’t pay less than £12. Your ticket won’t be valid before 10:00 am - even though it's an Anytime ticket. You could be fined!
“When you search for tickets via Trainline with a Railcard applied, it's best to travel on the train you searched for. If you end up travelling on an earlier train, make sure to double-check any restrictions.”
Not seen this mentioned yet in the light of the recent minimum fare/ deliberate fraud/ unclear conditions debate.
signed
13 May 2024
ROI
That's just nothing changed then. There is still no warning/messages on the booking process about railcard validity.
The exile
31 Mar 2010
Somerset
Otherwise known as “Journalist invents headline that is so misleading it’s effectively a lie” and third party ducks out of its responsibility to do things properly.
John R
1 Jul 2013
It reads as though it has been written by AI, not a journalist.
Doctor Fegg
9 Nov 2010
Charlbury
It’s a story from a Newsquest paper so that’s very possible - they have an AI tool which they use to reword press releases into newspaper stories.
Hadders
27 Apr 2011
As I understand, it there are now some pop-ups during the booking process that day say, where appropriate, that the ticket cannot be used before 10am.
30907
If that's the case, it's good if belated news.
However, if Trainline are claiming that there has been a change in the rules, they are being at best disingenuous.
Mcr Warrior
8 Jan 2009
This is what the linked to TheTrainline webpage is actually saying...
Relevant text...
TheTrainline said:
Railcards and travel restrictions
Generally, all Railcards can be used for discounted train fares during Off-Peak times, weekends, and public holidays. Some, like the age-related Railcards, can be used during Peak times with a minimum fare, and the Disabled Persons Railcard can be used at any time.
This is especially important when you buy Anytime tickets or other flexible tickets. If you travel on a train before 10:00 and have used your Railcard to buy your ticket, make sure you didn’t pay less than £12. Your ticket won’t be valid before 10:00 am - even though it's an Anytime ticket. You could be fined!
Relevant text...
Nothing on there says the rules have changed.
James H
25 Jun 2014
I saw a post on Reddit which suggested that Trainline's implementation was so clumsy it incorrectly marked a ticket to which the minimum fare had been applied as invalid in the morning peak
Mcr Warrior
8 Jan 2009
Link? That post might just need to be fact-checked.
James H
25 Jun 2014
This was the Reddit post: https://www.reddit.com/r/uktrains/comments/1g9ct8z/comment/lt6r2ew/
I always buy the Anytime Day Return incase a colleague wants an ad hoc meeting after 4pm when I usually leave. This has always cost me £12, discounted from £17.40 with the railcard.
I’ve been doing this commute for 3 years, just once a week and using the 26-30 railcard. However, today I noticed at the bottom of my ticket is says “Travel on services after 10:00 am. Your Railcard has been applied. As a result, this ticket is only valid on services after 10:00 am.”
It clearly states in the T&Cs the minimum is £12, which I pay exactly (£12.59 with admin charge).
Hadders
27 Apr 2011
Here's an example of what you see when you book online. I assume there are siilar warnings when purchasing via the app:
James H
25 Jun 2014
Yes, but it sounds like Trainline is putting a warning on a £12 discounted e-ticket to say it's not valid before 10am, which is wrong.
£12 is the correct discounted fare in the morning peak
In any event, the article mentioned by the OP won't help public understanding of what is already a poorly comprehended issue.
87electric
27 Jan 2010
Will someone please explain to Trainline that only Courts can issues “fines”. No wonder the passengers are confused by what is and isn’t a fine with railway ticketing issues.
AdamWW
6 Nov 2012
Or maybe they're just using the dictionary definition?
island
30 Dec 2010
I don't think that would be useful.
