XC not calling at Crewe?
Ovalo_Railways
16 Jun 2024
Esplugues de Llobregat
My question is remaining in: Why does XC routes from Bournemouth to Manchester doesn't stop at Crewe or pass at full speed this summer 'cause all the time goes calling after Stafford: Stoke-On-Trent & Macclesfield then terminating at Manchester Picadilly.
Welcome to the forum :)
What journey are you making?
XC rarely call at Crewe, because they rarely go via Crewe.
There are a few booked services, which means they retain route knowledge, which is useful in the event of engineering works or disruption.
XC are diverting trains via Crewe during some weekends this Summer, but without calls because they wouldn't normally call anyway.
Haywain
3 Feb 2013
It's not clear what you're asking but there are good reasons why trains not passing through Crewe would not call at Crewe.
MrJeeves
28 Aug 2015
Burgess Hill
Just to highlight what everyone else has said, on Mon-Fri there are typically three CrossCountry services travelling via Crewe, two of which stop at the station.
On Saturdays, this drops to two trains travelling via Crewe with both stopping. On Sundays, it's one train travelling via Crewe which stops at the station, too.
plugwash
29 May 2015
There are two main routes from Stafford to Manchester. Either Crewe, Wilmslow and Stockport or Stoke, Macclesfield and Stockport.
There is the occasional service that goes via both Stoke and Crewe and the occasional service that goes through east didsbury, but afiact this is only done for route retention purposes at unsociable hours.
It may be just coincidence that last time the timetables were laid out the manchester to bournmouth ended up with Stoke rather than Crewe as it's standard route. Modern timetable planners try to keep a consistent timetable through the day as this is much easier for everyone to understand.
jfollows
26 Feb 2011
Wilmslow
The second and third train in the list above only go via Crewe to allow a rush hour Stoke-Manchester stopping service to run, otherwise there would be a clash.
2K50 17:18 Piccadilly to Stoke is the up extra stopper, for example, which could not run if 1O68 17:25 Piccadilly-Bournemouth took the normal route via Macclesfield.
Both of these trains served Wilmslow before Covid, but the calls have been dropped now. 1O68 no longer stops at Crewe either, as noted above. It used to.
Prior to Covid there was also 1V42 06:00 Piccadilly-Bristol which served Wilmslow and Crewe but I think simply no longer runs or is 1V45 running a bit later via Macclesfield.
The exile
31 Mar 2010
Somerset
I mean what happened to the last 2 trains in the evening from Manchester to Bournemouth?
The last departure for Bournemouth is at 18.25 and doesn’t stop at Crewe because it goes nowhere near Crewe. The next departure (19.25) terminates at Southampton- hardly surprising as it would be well past midnight before it got to Bournemouth.
