What is the SRRS?Is there a map of the SRRS?
What is the SRRS?
Beneath wartime Britain ran a secret railway network built to move troops, weapons, and supplies while bombs fell above. It carried the lifeblood of the nation—quietly, invisibly, and almost unbelievably—through the darkest years of the Blitz. This is the untold story of the hidden trains, engineers, and everyday workers who kept an island at war alive.
This story is an almost complete fabrication - there was no parallel Strategic Rail System separate from the normal network. Some work was done to provide connections between lines where they crossed each other in order to maximise the number of alternative routes that were available to avoid bomb damaged areas, and some secondary lines were upgraded to increase capacity, but that was about all. Obviously attempts were made to camouflage military depots, but that had little to do with the railways. The photos are mostly irrelevant to the story, including several taken in post-1948 BR days, one taken in France, and another which I think is in North Africa! The narrator uses American pronunciations, such as ‘dee-pot’ (innumerable times) and ‘rowt’!
That may be true, but somebody gave it the concept of an SRRS to start with and guidance as to what to include. AI doesn't invent ideas in that way. So it's somebody's weird idea turned into a narrative by AI, with a (rather good) simulated 1950s voice over some not very relevant photographs. For anyone with a bit of background knowledge and a smidgeon of critical thinking it's obvious manure, but .....That is an AI Youtube channel. None of the content is written by a person or voiced by one. It is also, as we have discovered, a crock of manure.
It does, actually. Youtube is suggesting video ideas and structures to creators now *directly* and you can machine learn a whole channel based off AI's ideas for what would work.That may be true, but somebody gave it the concept of an SRRS to start with and guidance as to what to include. AI doesn't invent ideas in that way.
In the 1984 TV film, 'Threads', about the aftermath of a nuclear strike on Sheffield, one of the other events is a 'ground burst at Crewe', I seem to remember.and few critical nodes
If it was the station, I'd question how anyone could tell the difference.In the 1984 TV film, 'Threads', about the aftermath of a nuclear strike on Sheffield, one of the other events is a 'ground burst at Crewe', I seem to remember.
In that case let's hope that schools teach the next generation to develop critical thinking above all else, or there's no hope.It does, actually. Youtube is suggesting video ideas and structures to creators now *directly* and you can machine learn a whole channel based off AI's ideas for what would work.
This channel has been set up and then left to excrete a turd every few days, while the person who set it up goes on to mimic more channels with slop. This is extremely common.
I thought it sounded like Lord Haw-Haw apart from the transatlanticisms.a (rather good) simulated 1950s voice over
They may not have built a secret railway network, but they very rapidly built a secret network of buried pipelines and underground storage facilities to distribute aviation fuel around the country. It is amazing what can be achieved in a very quick time if the will is there.I haven't watched the video. From contrex's quote; "Beneath wartime Britain ran a secret railway network". This seems to imply a load of tunnels. I wonder how quickly they could be built at sufficient length/capacity!
A couple of others were a connection between the two lines at Canterbury, and an alternative route through Northallerton. The latter crossed over the Wensleydale line only a few feet above rail level - if it was ever needed the plan was to position a suitable wagon on the lower track and lay the upper one across it.Some building took place to ease potential pinch points that could pose a problem in the event of attack. One that immediately comes to mind is the WCML just north of Carlisle Citadel, where an additional two tracks were laid including a second bridge over the Caldew and Eden
Canterbury rather than Maidstone, surely?...a connection between the two lines at Maidstone...
Canterbury yes, also one at Dorking, reusing an earlier link that was derelict.Canterbury rather than Maidstone, surely?
that video is utter nonsense -Is there a map of the SRRS?
"Soviets invest millions in improving UK rail network"If it was the station, I'd question how anyone could tell the difference.
Correct - it is utter drivel and is, essentially, an AI "hallucination"That is an AI Youtube channel. None of the content is written by a person or voiced by one. It is also, as we have discovered, a crock of manure.
Another one was an additional connection between the S&D lines and the Perth lines at the north side of the Forth Viaducts at Stirling.A couple of others were a connection between the two lines at Canterbury, and an alternative route through Northallerton. The latter crossed over the Wensleydale line only a few feet above rail level - if it was ever needed the plan was to position a suitable wagon on the lower track and lay the upper one across it.
