Wrexham, Shropshire & Midlands Railway updates
In regards to WSMR though, how much of the WCML are they planning to use?
Isn't it just that bit from Euston to Nuneaton?
after that, they head off somewhere else and end up in Wales. (If I've got this wrong, forgive me, as im still a bit of a railway noob). If they can market the economic benefit to the community effectively, then I feel they may be prioritised.
I think on WSMRs application, Network Rail said 2 of the 10 paths were fine but the other 8 required flexing of other services. But ive seen in other applications that network rail literally disputes everything, even existing TOC paths/applications.
I think WSMR might be a dark horse... Alstom would've done their homework, surely?
Flexing is doing some heavy lifting. If a path isn't compliant, NR has to reject it.
Yes, ie all of the busiest bit (Euston - Rugby).
This will be an interesting decision for the Regulator.
”Dear Network Rail. You may remember that we have written to you formally on several occasions to highlight how performance on the network is not good enough, that when incidents happen on busy parts of the network delays are getting larger and it takes a long time to return services to normal, and that you must improve this situation. We have also written to you separately to point out that with the high levels of passenger numbers at Euston station, passenger handling and the passenger experience leaves a lot to be desired and you must improve this situation.
Meanwhile we are going to approve the following extra services on the WCML, which is one of the busiest parts of the network, so that Euston can get busier with more passengers and that any incidents on the network will get worse, causing higher levels of delay. Simultaneously, this will increase expenditure on the rail system by taxpayers due to revenue abstraction. Yours, ORR.”
(obviously the above is said in jest to make the point)
2 Feb 2019
Does anyone know when the Office of Rail and Road is likely to make a decision on WSMR and the other two (Lumo and Virgin) currently undecided open access applications for paths on the West Coast Mainline?
Zontar
10 Oct 2018
I was thinking the same thing. It was march 24 when the application went in I think.
Clarence Yard
18 Dec 2014
June 25 (at the earliest) is the current estimate as they won’t get anything useful from NR until March, much to the annoyance of the applicants.
12LDA28C
14 Oct 2022
I think we already know there is no money in Marylebone (and by extension Paddington) otherwise the original incarnation of WSMR wouldn't have folded.
Really? Nothing to do with a worldwide recession, operational restrictions imposed by rival operators and a competing service between Wrexham and London being introduced then?
Wasn't imposed by Virgin, DfT instructed them to as part of moderation of competition.
anthony263
19 Aug 2008
South Wales
WSMR wouldn't have folded if they'd been allowed to use the midland mainline class 170s like they originally wanted plus the restrictions placed on thwm
Class 170101
1 Mar 2014
Sure these didn't help but Wrexham to Marylebone was always going to be a slower journey than that to Euston regardless of the restrictions whether caused or not caused by MoC or other restrictions.
I don't recall those 170s being available.
12LDA28C
14 Oct 2022
Of course WSMR would be a slower journey than going into Euston but remember there was no direct Wrexham to London service when WSMR started. And there is much more to attracting a customer base than having a fast journey time.
Hadlow Road
11 Jan 2024
N E Wales
My wife and I used the excellent WSMR service, mainly because it saved a change at Chester, it saved using the less clean stock and it avoided the scrum at Euston. Marylebone was always a delight. Yes, the journey took longer, but no changes and great service made the difference.
Using it weekly I was so disappointed at the loss. Proper, effective and professional service. Fearing that this paean is off topic I hope that we will see the new direct service soon. Avanti’s hit and miss to Wrexham is, sadly, still challenging.
anthony263
19 Aug 2008
South Wales
It's in the book i had on Wrexham and Shropshire. It mentions them in negotiations for the 170s then suddenly told they no longer available
MCR247
7 Nov 2008
it sounds bad but to be honest good - they were needed at Central Trains.
CyrusWuff
20 May 2013
Definitely jumping the gun. ORR have further meetings regarding the numerous competing Track Access applications scheduled for 19th March and 16th April.
10 Feb 2016
That's from the MP.
AFICS all that is new is 'confirmation of support' from DfT. What does that actually amount to as the authorisation is ORR's?
Yes indeed
I don’t think the MP has much of of an idea of the thinking towards OA operators nowadays.
Is it desirable to have an extra 5 short formation trains a day on the WCML to provide a service to Shrewsbury. Also the previous WSMR couldn’t make it pay with one train each way.
The assumed extra revenue from MK seems optimistic when they already have 8 direct trains an hour to Euston.
I would love to be proved wrong but I think this is just pie in th sky, especially with the transition to GBRR
Meerkat
14 Jul 2018
That's from the MP.
Is it cynical to suggest the DfT are just taking the political approach - let ORR take the heat if they reject it? Bit like local MPs will support almost any madcap reopening proposal?
victormildrew
5 Apr 2021
Shrewsbury
Yes indeed
Why were they unable to make it pay?.
robspaceman
19 Jan 2010
Shrewsbury
Because it went right round the houses and took forever and had an overspecced offering of freshly cooked food etc etc (albeit delicious). This new proposal will be 2.5 hours and without the extra bells and whistles.
10 Feb 2016
Personally I would happily have a slightly longer journey, say 3 hours against having to change at Birmingham or Crewe. Maybe the shorter journey time will be sufficient to support 5 trains as day. Whether ORR or whoever decides such things in the future will be happy to provide those pathways is another matter
