Wrexham Central timetabling?
Goofle
13 Jul 2016
Looking at Real Time Trains the outgoing service to Bidston leaves Wrexham Central two minutes before the incoming service arrives! I’m pretty sure it’s the same train. Am I being a bit simple?
The incoming service is usually early I believe and the departing one a little late but isn’t this a weird idea?
You are confusing the public times with the working times. The train normally arrives around xx.29 and departs at xx.32
Eccles1983
4 Sep 2016
The op is correct.
A few anomalies exist on that line if you look further down it.
Bovverboy
1 Dec 2013
Are you maybe thinking of Wrexham General?
Public timetables show arrival at Central at :32, with departure at :30. (Yes, it's the same train, it's a single-track line with one platform).
https://tfwrail.wales/sites/tfwrail.wales/files/2019-04/TfW Timetable 4 19May 14Dec 2019_1.pdf
Working timetables generally show an arrival at Wrexham Central of xx.29 and a departure of xx.32. The publicly advertised times are, respectively, xx.32 and xx.30. Confusing, but that's how it is!
This is a far from unique situation. The 1658 Carmarthen to Manchester Piccadilly, for instance, arrives Picc at 2215 and departs for Chester at 2212! Luckily, it's usually in early.
PHILIPE
14 Nov 2011
Caerphilly
The 1658 ex Carmarthen is more or less a through train but not advertised as such and travels through Platform 14
Goofle
13 Jul 2016
Thanks for the replies, in particular the link to the timetables. To me even on there it says Wrexham Central (d) at xx30, when the incoming service service is Wrexham Central (a) at xx32. That’s pretty impressive!
It’s obviously easy to figure out as there’s only the one line and indeed one platform anyhow, I was just curious if I was losing my marbles!
Djgr
30 Jul 2018
It's due to minutes added in the public timetable to make it easier to meet punctuality targets. Very common scam I believe.
It's to ensure the on time statistics are better than if the actual booked arrival time was used, as the train is able to be counted as 'on time' more often than if the booked arrival time was used.
Djgr
30 Jul 2018
According to the public timetable Bidston to Upton takes 3 minutes, whilst Upton to Bidston takes 8 minutes.
I think this is (yet) another benefit from privatisation that many on the forum are so keen on.
The journey time on this route means that an hourly service with two trains has uncomfortably short turnarounds times each end. I think the depart-before-arrive times may be in part an attempt to make sure people are there for the train in good time and avoid extending the turnaround any further. The better acceleration of the intended class 230 replacements, and possibly skipping of lesser-used stops by some services, may ease this problem in future.
Djgr
30 Jul 2018
The journey time on this route means that an hourly service with two trains has uncomfortably short turnarounds times each end. I think the depart-before-arrive times may be in part an attempt to make sure people are there for the train in good time and avoid extending the turnaround any further. The better acceleration of the intended class 230 replacements, and possibly skipping of lesser-used stops by some services, may ease this problem ifuture.
Not totally convinced. Pretty much every passenger at the Bidston end will be there when the Liverpool-West Kirby train drops them off. No sooner, no later.
Esker-pades
23 Jul 2015
Beds, Bucks, or somewhere else
The Working Timetable has it down as 4-5 minutes between the two.
Here's how I see it:
1/2 minutes will be added on to make up for deliberately tight timings on the rest of the route. The timetable is only accurate to the nearest half minute, so it makes sense that one would round it down at the start of the journey (so the theoretical 3m15s becomes 3m), and then add the residual timings back on at the end.
