Would you live in a hard water area?
Would hard water put you off living in a certain area?
No. Not something that ever even vaguely entered consideration when choosing where to live.
If anyone has a real problem with it, there are enough systems available to soften it, and if you just don't like drinking it get a filter jug or buy bottled.
Peter Mugridge
8 Apr 2010
Epsom
I do live in a hard water area - and having stayed in soft water areas, I find the hard water tastes better...
Geezertronic
14 Apr 2009
My father in law moved from Birmingham to Mablethorpe (Skegness) and the difference in the quality of the water in Mablethorpe is dramatically worse compared to the Elan Valley water that we get in Birmingham. When we visit him, drinking water from the tap makes me ill as does kettle boiled water. His taps are covered in limescale, and I mean covered. He has a water purifier, and uses a lot of bottled water
I am not sure of the source of the water there but it is dramatically worse than Elan Valley water we get in Brum
The purer water is, the more it tastes of nothing. Mineral water is of course quite hard.
That said, the nastiest tasting water I've come across was in Sicily - it had a very milky taste, I wonder if this was due to high calcium levels? It was vile, though, and difficult to drink enough of it despite the heat.
big all
23 Sep 2018
redhill
water quality should never be the main choice to anything its all good drinkable water
transport parking health schools jobs housing council tax and general infrastructure are 1000% more important than water
alxndr
3 Apr 2015
No, I wouldn't even think about it. I grew up in a hard water area and know no different. I couldn't even honestly tell the difference between when we had a working softener and when we didn't any more.
cactustwirly
10 Apr 2013
So my home area is a very hard water area, and my uni is in a soft water area, and apart from having to filter the water before using it in a kettle, I haven't noticed any difference
LWB
31 Dec 2009
So my home area is a very hard water area, and my uni is in a soft water area, and apart from having to filter the water VEFBEF using it in a kettle, I haven't noticed any difference
There is growing evidence that it causes dyslexia.
EssexGonzo
9 May 2012
I live in a very hard water area. The "why-didn't-we-do-that-years-ago" moment for us was installing a water softener. A very, very wise investment that I'd recommend for anyone. We kept a hard water tap for drinking but irons, kettles and appliances are furring up much more slowly now and we're using far less soap and laundry products. It's easier to wash the car too!
So no, in my view avoiding an area because of water hardness would be silly unless there was a medical reason as you can mitigate the hardness quite easily.
StoneRoad
6 Jan 2010
Haltwhistle
Much prefer Hard Water for drinking from the tap, as that is what I grew up with ...
But prefer soft water for use in washing machines and the like.
I've been told that some areas now have "hardness" added to the supply.
I have to remember when I'm in TLC of Wales not to use too much soap or shampoo, otherwise rinsing off is very time-consuming.
gazthomas
5 Jun 2011
Llandudno
So they still fur up? In a soft water area, there is no furring up at all.
Is that your concern?
Half of Great Britain is in a hard or hardish water, as this map illustrates. You would have to live in the west and north to avoid hardwater.
https://www.bristan.com/hard-water-map
So the option is to either move, get some form of treatment device or live with it. I chose the later, but do use a descaler on my kettle and shower head from time to time.
I wonder though, with all that calcium in my water whether I'll have less issues with osteoporosis when I get older!
gazthomas
5 Jun 2011
Llandudno
I'm not sure how accurate that map is as I live near Gatwick and haven't had any problems with furring up kettles in the last 20 years.
It's indicative. For more accuracy you would have to look at each water supply company's website, assuming they share this data (many do). The source of water, abstraction from aquifer or reservoir and river plus the local geology can create a lot of local variability.
I'm still intrigued to as to what triggered the question! If the question was would you live near Gatwick I would say no, certainly not Crawley!
AndrewE
9 Nov 2015
What do you think you are "filtering" out? Hardness is dissolved solids and unless you are softening the water you are probably just taking out the chlorine.
radamfi
29 Oct 2009
No. Would it put you off? If so why?
It might not necessarily be a deal-breaker but it does seem that most hard water areas are also expensive places to live, so it means even less reason to live in those areas.
cactustwirly
10 Apr 2013
I know, it's a jug which contains a filter, which contains sodium ions, which swap with the Mg & Ca ions in the hard water.
gazthomas
5 Jun 2011
Llandudno
Brita, who supply the filters for my Russell Hobbs kettle suggest they do reduce carbonate hardness: https://thinkyourwater.brita.co.uk/en/faq/
I certainly have no "scum" on the top of my tea or any chlorine taste
gazthomas
5 Jun 2011
Llandudno
Well living in Brum it used to be soft but definitely getting more limescale these days.
That could be because Severn Trent Water have decided not to remove the carbonate as part of water treatment.
My 14 years in the water industry are starting to be useful!
AndrewE
9 Nov 2015
So you are softening it. No filtration needed (although it's probably a by-product of the process.)
Water from Welsh reservoirs is soft, groundwater is almost invariably more or less hard. Where I live we get either River Dee water or Midlands aquifer water so it alternates between soft and hard.
Darandio
24 Feb 2007
RailUK is the last place I would have expected to see your expertise needed, but there you go!
Has anyone had any experience in using specific tea bags for their water condition? I notice Yorkshire Tea do a hard water blend, i'd assumed it was a load of old cobblers.
cactustwirly
10 Apr 2013
It's called a Brita filter...
AndrewE
9 Nov 2015
Are you up-to-date? I ask because there has been a big change in water treatment. Once upon a time all water had to be alkaline to prevent plumbo-solvency and lime was added to any water from an acidic supply. Unfortunately dissolving even a little bit of dry lime is quite difficult and expensive: nowadays they add phosphoric acid to acidic supplies instead, so that even though the water is acid the inside of lead and iron pipes are passivated by the phosphorus reaction compounds created.
So my water is alternately alkaline if it is the groundwater being used, and more acidic than the Dee water if it's from Bala!
