Would Closed Rail Links In England Reopen?
Who Thinks Pickering To Malton Will Reopen?
  • Total voters
    51
I think it is as I had a look on google earth and the gap is wide enough.
Google Earth is not a recognised Permanent Way design tool.
Alternatively - wide enough for what? A single track at standard structure gauge, with a 2-3 metre cess on at least one side? And at how does the track actually get there (both figuratively in terms of alignment from the station, and around the buildings, and actually in terms of construction, ie free space for lifting components in).
And where are the drainage runs going? And the cabling? And the fencing? Etc
bingleybong
4 Mar 2016
An aside but isn't S Taylor and Sons an extended former railway building? This in no way makes a line fit through of course.
Brubulus
13 Oct 2022
Cambridge
It is, which is why I'm slightly confused by the idea it's foundations would be shaken to bits as it was designed to deal with being right next to a railway.
Northampton
I'll give you proof.
The gap is 27 feet wide. It must be enough.
1 gap does not a railway make. What will the curve radii be? Is there sufficient space for the transition between the two reverse curves necessary at that location?
Lidl wasn't.
lyndhurst25
26 Nov 2010
Perhaps if we started from the beginning:
OptionCostsBenefitsNegative issues
Malton-Pickering NYMR£200m+, Probably £300m (Very High)Connects small town to national network
allows through trains to Whitby (possibly)
Allows railtours on/off NYMR
Journey times from York competitive/comparable to bus
Requires substantial demolition of homes and businesses
Requires 3 level crossings
requires infrastructure interventions at Malton
Requires major intervention in NYMR to permit through trains
Requires capacity intervention on Whitby branch to get through trains
Malton-Pickering (Outgang)£150-250m+ (very high)Connects small town to national network
Journey times from York competitive to bus
Requires substantial earthworks
Requires level crossings or bridges
Requires infrastructure interventions at Malton
Requires small modification to road infrastructure for access
Malton-Pickering South (Black Bull)£100-180m (Very high)Connects pub and caravan park to national network
Rebuilds some previously closed lines
Requires connecting bus/1.5 mile walk
Requires infrastructure changes at Malton
Requires changes to road infrastructure for bus/parking
Run bus from Malton (either existing or dedicated), integrated times and fares~£0.1-0.25m (Low)Much lower costs
No rail changes required
Investment in bus infrastructure of wider benefit for Malton and Pickering
Requires small cost to integrate fares and times in
Requires small cost in marketing
Requires small investment in bus infrastructure at both ends.
Why don't we trial if there is public transport demand by integrating the Malton-Pickering bus into rail timetables. It is worth pointing out the bus is timetabled for 15-20 minutes, and the likely travel time from Malton to Pickering town by rail would be 8-10 minutes. Travel time to a Pickering parkway at the Blackbull would be about 6-7 minutes, but the bus would then be a 5-10 minute wait and further 5-10 minute journey.
Excellent assessment @zwk500.
To add weight to your analysis, you could include timescales.
Options 1-3 could be running, at a push, by 2031.
Option 4 could be running, at a push, in 8 weeks.
Northern or TPE train to Malton. Bus Malton to Pickering. NYMR Pickering to Grosmont or Whitby, Northern Grosmont to Whitby. With integrated ticketing and timetables? Up and running in a few weeks? Years to never more like. Britain (outside London and PTE areas perhaps) is incapable of integrated transport.
Current rail plus bus through ticketing to Pickering or Whitby is a shambles, with a seemingly random selection of origins available depending on which TOC sets the fare to the railhead. Northern to NYMR through ticketing existed at one time in the past, but no longer. I don’t even think that there is NYMR/Northern ticket inter-availability between Grosmont and Whitby.
If this existed that I would probably use it, but good luck to anyone trying to negotiate the arrangements.
Northampton
Nothing as complicated as that. Treat Malton-Pickering as Luton Airport Parkway - Luton Airport currently is, or the Heathrow bus links. The service exists, the data processing isn't exactly onerous. I agree 8 weeks may be a bit optimistic to agree the commercial aspects but certainly possible by the May timetable change.
For instance, it could be agreed that the fare for this leg is the same as the bus fare, and that all money for the bus leg will go to the bus company, and the times published are those of the existing bus link.
Reads like the justification in a Network Change options table:D
RT4038
22 Feb 2014
So what is the point of the through fare then?
Northampton
So that it appears in journey planners, and people can buy 1 ticket for journeys anywhere on the network to Pickering. Being visible in the same system is half the battle for integration efforts. Plusbus, as mentioned, is rather a mess.
Glenn1969
22 Jan 2019
Halifax, Yorks
I thouight York to Whitby via Pickering had been in journey planners and on RTT for some time. Unfortunately it's in dire danger of being withdrawn as a commercial route by Transdev in April.
RT4038
22 Feb 2014
The journey can appear on Journey planners, without a through ticket. The DB journey planner does just that for many journeys - sells the bit that it can.
lyndhurst25
26 Nov 2010
Indeed it is, but not available from many stations where people would want to use it from (like much of the north of England). I think that it is only available if LNER is the fare setting TOC to York.
Then you have these two oddities, via Scarborough.
Northampton
This is the key problem though, it just sells part of the ticket. It could also do with better marketing.
But if the bus is in danger of being withdrawn this kind of proves the point - it's worthless to build a railway very few want to use.
bluenoxid
9 Feb 2008
Could I ask what the point of the project is?
If it is Whitby connectivity, would option 5 be a Scarborough to Whitby bus rather than trying to run something via Pickering.
Eyersey468
14 Sep 2018
But if Network Rail reopened it for NYMR and not for other trains the NYMR would be fine with running to malton. Also if the NYMR got a lot more money from donations or other causes they could run to malton.
Would the extra revenue from passengers offset the increase in maintenance costs though?
Northampton
Please don't reopen this part of the debate. It was hard enough to get the point across in the first place.
The NYMR cannot afford to fund the extension on it's own. And NR will not be building a railway for anybody else.
Class08Shunter
18 Aug 2022
North Yorkshire
I really didn't think this through. I forgot about trying to fit the track in. I don't think you have enough room to fit track.
If the NYMR can't fund it on their own, NYMR and NR could share the cost.
Northampton
No offence, but how were you thinking a railway would run without track?
We've been through all this, and whether they could or not is utterly irrelevant. NR will not be giving the NYMR any money to build tracks.
Class08Shunter
18 Aug 2022
North Yorkshire
I knew about the track being laid but I didn't know if you had enough room to lay track. What I started thinking about was preparing to lay the track.
You're right as Pickering Engine Shed is part if S Taylor and then they would've extended it. So the railway would still fit through as the engine shed was original and the extension was after the line closed in 1965. Because they extended their business in Pickering and the railway has to go through that, what could happen is the part of the building circled in red can be demolished and they can work in the remaining parts. Obviously you would have to give them compensation.qwert.PNG
Neptune
29 May 2018
You're right as Pickering Engine Shed is part if S Taylor and then they would've extended it. So the railway would still fit through as the engine shed was original and the extension was after the line closed in 1965. Because they extended their business in Pickering and the railway has to go through that, what could happen is the part of the building circled in red can be demolished and they can work in the remaining parts. Obviously you would have to give them compensation.View attachment 125440
And if their business can’t function without that bit you’re demolishing what then?
YorksLad12
5 Feb 2020
We still demolish the bit circled in red but as compensation we extend the business north.
I'm not related to this Taylor (quite a few, but not ths one), but I think if you proposed this to me, I would tell you where to go. I might even draw a diagram. It's not as if you've ever get a Compulsory Purchase order - this isn't HS2 demolishing an ancient woodland you know, and they're not the only issue with reinstating the route.
Exactly. Without knowing the business in question, there may be a reason why the building is the shape it is. "Extending north" doesn't help if you need width for equipment. Given the amount of building that's taken place on this long-closed, never protected route... we do seem to be a bit hung up on one building here.
Class08Shunter
18 Aug 2022
North Yorkshire
They probably used Pickering Engine Shed first then expanded. So if they were extended north they would have to use smaller equipment.
Tobbes
12 Aug 2012
The only way this would be rebuilt is if NR (& therefore the Government) decided that this was a national priority and both the resources (cash, expertise, more cash) that would get you to a place where Compulsory Purchase Orders could be granted. Given that bar, I'm be (frankly completely) astonished if this ever met that bar.
Neptune
29 May 2018
So that’s ok then is it? Do you know the business and know they can use smaller equipment? This really is starting to sound desperate. Trains or bust isn’t the be all and end all of every town and village whether there was a railway there or not 50+ years ago!
