Tetchytyke
How is the work being done at St. Pancras give trains are terminating and heading back north there?
The trains are all using the upstairs platforms.
(off topic) when did Network Rail go from keeping chuggers beyond their boundaries to allowing them to harass people on concourses
How much with it cost to install them at every station with step free access that a Thameslink train goes to? And those it will go to in the future?The hoarding is for material storage for installing the harrington humps. Unfortunately its only going in along the core so is going to cause issues.
Whereas as now wheelchair passengers have to come to us to ask for a ramp, and then we know they're on the train to call the destination station, once the humps are in people are going to get on without telling us, thinking they can get off at the other end and find they can't as their destination will have no idea they're coming causing them either to miss their stop or delay the train.
If they aren't compatible with trains other than the 700s you probably can't install them at non-core stations however much you have to spend. The core can reasonably operate a restricted loading gauge, with wider or longer stock banned or limited to crawling through at low speed.How much with it cost to install them at every station with step free access that a Thameslink train goes to? And those it will go to in the future?
There's a good idea! If you have to go out of your way to avoid them-then they are causing an obstruction, and it needs dealing with. At Lime Street you can normally avoid them by turning immediately left after leaving the barriers (or arrive on a Virgin service which is guaranteed to use an unbarriered platform) though I've not seen any for a while now.. Merseyrail have tried it at Liverpool Central, they seemed to be doing little more than getting in the way of passengers leaving the station and thankfully, after that period, I've not seen it since-with the exception of poppy sellers and soldiers collecting for Help for Heroes, which was done in different places.Dunno, but every time they inconvenience me (which is every time I see them as their whole modus operandi blocks passenger flow) I make a formal complaint, and encourage others to do so too.
I suggested earlier that someone with mobility difficulties might board anywhere on the train at a core station and then find they can't alight at a non-core station because their door doesn't align with the hump.Why don't they make the whole platforms through the core level with the trains as only one type going through? Would be good for everyone with cases etc. instead of these silly humps in the middle.
The modular platform humps are known as 'Harrington Humps' after first being installed at Harrington station, which is in the north of England.
