There are 10 high-power HF transmitters at Woofferton. They range from Marconi senders of various vintages, including two BD272 250 kW units that date back to the 1960s, to the more recent 300 kW B6124 solid-state transmitters, and four of the most modern RIZ 250K01 wideband systems, * which are also capable of operating in Digital Radio Mondiale (DRM) mode. In fact, the BBC’s daily DRM transmission for Europe is broadcast from here.
Outside in the antenna field, there are 35 shortwave curtain arrays (aerials) supported by 25 masts. Most of the antennas can be operated in full or half-curtain mode, depending on the coverage required, and can be electronically steered (slewed) to beam transmissions in a variety of directions. This is done by varying the phase of the signal and feed points to the antenna, rather than by physical movement.
