Wooden keys still in use
mmason16
1 Jun 2026
Staines-upon-Thames
Wooden keys on bullhead track
After coming across some abandoned track along the old Staines West branch, I noticed that despite the heavy degradation of the wooden sleepers, the wooden keys still looked fairly intact.
Does anyone know whether wooden keys are still used anywhere on the operational network today?
Thanks.
28 Oct 2017
If you look at little used sidings you will find plenty of examples.
Yesterday I was at Bradford Interchange and the last panel of track before the buffers in the siding beyond Platform 4 (against the retaining wall) is bullhead rail and has wooden keys.
I seem to remember parts of the South West have extensive bullhead rail on concrete sleepers, and so wooden keys will be common there.
mmason16
1 Jun 2026
Staines-upon-Thames
Bullhead rail on concrete sleepers has always confused me, surely if the railway authority has gone to the effort of installing a concrete sleeper, they would install CWR as well?
Are wooden keys more likely on concrete sleepers than wooden?
28 Oct 2017
It depends when the concrete sleepers date from! I think these are pre-1948 and installed by the original Great Western Railway. Concrete sleepers are very long lasting.
Amlag
8 Jul 2018
At Plymouth the Down Through line still has some wood keys in use on the wooden slprs chaired BH track.
I noticed a year or so ago some wood keys in some of the wooden slprs chaired BH non platform lines at Birmingham New Street.
Two bolt (as opposed to 4 bolt) fishplates are now very rare on passenger lines.
In the South West they still survive in use in the platform lines at Maiden Newton, where speed is very slow and all trains have to stop there for token purposes.
Acathater
11 Dec 2025
NorthWest
There are some wooden keys on the locomotive run round loop at Morecambe station.
The loop is rarely used now since the nuclear trains are all top-and-tailed
Dave S 56F
23 Jun 2020
Cleckheaton west yorkshire
The Bentham line from settle jct to carnforth pandrol clips and jointed bullhead rail also sections of the furness line in cumbria and a short section in Halifax on the up line to Dryclough Jct.
Mugby
25 Nov 2012
Derby
They certainly are. Many concrete sleepers that were originally produced for bull head rails were later converted for flat bottom rails by the simple expedient
of swapping the baseplates. Some are still in use today on secondary lines.
John Webb
5 Jun 2010
St Albans
.....Concrete sleepers are very long lasting.
Concrete sleepers came into use mainly in WW2 when imported hardwood timber was unobtainable and British timber also limited. The Building Research Station at Garston, Herts., measured the forces on sleepers on a main line* in 1942 and then designed pre-stressed concrete sleepers as an alternative method of supporting the rails.
*My source doesn't tell me which line.
McRhu
14 Oct 2015
Lanark
There was an apocryphal (or maybe not) story about a party of campers derailing a train at Rhu by removing a few lengths of wooden keys for their camp fire. The keys seemed to loosen quite easily despite the inside face of the chair being serrated.
YorkshireBear
23 Jul 2010
Could have been after dry weather, we have wooden keys in check rails on KWVR and after long dry spells they remove much much easier.
Dr_Paul
3 Sep 2013
Wooden keys can indeed dry out and shrink. I was working on the Cob on the Ffestiniog Railway back in the 1970s, checking the keys and oiling the fishplates, and several keys were loose and were replaced by new ones which were then wedged with a special sledge-hammer between the rail and chair. The loose ones had dried out and had shrunk to the degree that they could be moved with one's hand; a few had actually fallen out of the chair and were on the ballast.
ajwffc
30 Sep 2023
I think there are wooden keys on the check rail on the Niddrie lines at Newcraighall North Jn.
McRhu
14 Oct 2015
Lanark
Yes - I remember dry weather (ie- the long, hot 70s summers) loosening keys. I had thought it was due to the expansion of the rails, but drying out/shrinkage sounds makes more sense. I wonder if there was ever such a thing as a keyless chair although that would obviously bring its own problems in laying and removing bullhead rails.
