Wilts Wanderer
- Joined
- 21 Nov 2016
- Messages
- 3,199
Hello
I have an existing wood burning stove in my home, which pre-dates when I bought the house (2013) and certainly the HETAS regulations in 2015. My property is an old mid-terrace, built circa 1880, originally with large open fireplaces in four different rooms, linked to a combined chimney flue. Three are now sealed & ventilated, the downstairs living room is open and contains a medium-sized wood burning stove. When we moved in we were told the stove and chimney had recently been serviced and that we should have the chimney swept every couple of years if burning wood, as the resin can build up.
Having only used the stove a few times each winter when it’s actually been cold, and not since 2018/19, I today had a chimney sweep round to do the necessary. We’ve previously had no issue with sweeps, but today he said that our stove is not HETAS compliant, lacks a closure plate at the bottom, and may not be properly installed / chimney lined correctly, and therefore he was unwilling to do the work. It occurs to me, why is this only a problem now - don’t existing woodburner stoves have grandfather rights? Equally I don’t understand why he still couldn’t sweep the chimney as the resin deposits will be there either way.
Does anyone have any knowledge / experience with this sort of thing? The stove does just sit where the old fireplace was, with a 125mm diameter flue bracketed to the four walls of the chimney and disappearing up for unknown distance. It’s always drawn well and doesn’t leak smoke into the house at all. We periodically get birds dropping material down from sitting on the chimney pots above, and heavy rain does get down a bit and causes a little superficial rust on the stove’s heat plate.
Just wondering if I got the world’s most awkward sweep or if we should actually get it professionally looked at / improved, which will likely cost hundreds of quid.
