WMR Class 196 Build and Implementation
FLIRTfan18
11 Mar 2020
Wolverhampton
WMR replied to somebody on Twitter a few days ago saying new trains on the Shrewsbury line will be in service during the latter half of next year, so if I'm not mistaken Covid has knocked it back by around an entire year
Sparks807Evo
22 Aug 2010
Last I had seen first unit should enter service by end of year according to the Conference document on here (http://news.wmtrains.co.uk/documents) with Hereford introduction first, then Snow Hill and then Shrewsbury.
Had seen that 196101 had shifted up to by the running lines when I passed yesterday so hopefully promising that it may move soon. Any particular reason why the gangway door colour has been changed as would have thought the headlights would be up to the required standard for the safety case to dispense with the yellow requirement? Is there a safety trend back towards the yellow ends as aside from TPE and Hull Trains new trains with their black end fronts, there has been a majority of yellow end switches including the Greater Anglia units' design being switched from black to yellow, as were the Class 701s for SWR and recently the TFW Class 230s which swapped from red to yellow.
Philip Phlopp
31 May 2015
I hear on the grapevine that the Class 195 and Class 196 units aren't compatible with each other - the coupler electrical connection is top mounted on the Class 195 and bottom mounted on the Class 196.
Humour me. Why ?
Energy
29 Dec 2018
Humour me. Why ?
I'm not sure why, it maybe the gangway as the 377s also have it bottom mounted? Doesn't look to be enough space for top mounted with the gangway there.
LOL The Irony
29 Jul 2017
Chinatown, New York
Humour me. Why ?
Is it maybe so they can be compatible with the mechanically similar 172's?
Speed43125
20 Jul 2019
Dunblane
Do you mean that they've effectively had to move it from the top to the bottom to fit the gangway in? ie. when the Northern ones were built they didn't consider the possibility of some being ordered with Gangways?
Looked much better with black gangway doors IMO.
It looks like a Fisher Price train, it really is a truly awful livery. Full yellow front might make it tolerable, though. Like the 350s, highlighting the ugliest part of the train above the solebar (the gangway connection and its many squashed bluebottles) really does make it look bad.
Energy
29 Dec 2018
I think so, can't think of another reason and there doesn't look to be enough space on top anyway.
Energy
29 Dec 2018
Can someone Photoshop the 196 into another livery? The WMR livery seems to look bad on any train so I'm interested to see what it would look like in another livery. It's a shame they went from the great London Midland livery to this...
LowLevel
26 Oct 2013
EMR have advised internally that the first ex WM 170s are now expected April '21 at the earliest so that tallies with the delay above.
Bob Price
8 Aug 2019
Just go on the TfW site and look at the 197's
hwl
5 Feb 2012
Humour me. Why ?
The typical <110mph UK unit dellner install is bottom mounted so effectively just reverting to UK normal for the 196s...
CAF might have actually read some RSSB documents this time including where the Dellner electrical connectors go!
Is there a safety issue from having it at the top? Though the bottom does seem the UK norm for almost all types of autocoupler.
atsf_fT
12 Jul 2011
planet earth
The doors you are seeing are the inner doors 'there 2 sets inner for when the unit is coupled and passingers walk through the outer doors when running are black ' it's been on depot like this for 2 months
Domh245
6 Apr 2013
nowhere
It certainly seems that plenty of modern stock is being fitted with couplers where the electrical connector is above the main block. Desiro Cities and FLIRTS both have 'top side' connectors, although Aventras do have 'bottom side' connectors. Seems to me that the bottom side mainly became so standard in the UK as a result of all the gangwayed stock that was procured in the 2000s rather than any inherent advantage, and if there's no need for electrical compatibility between the fleets, there's no point tying yourself to that arrangement of coupler
Energy
29 Dec 2018
Not sure about Desiro Cities but Flirts look to be capable of 125mph operation as there is a model (the FLIRT200) on Stadler's website although the GA models are limited to 100mph. This could be why it is top mounted so if Stadler get any orders for a 125mph unit they don't have to modify the cab.
the sniper
4 Sep 2007
I think the gangway doors would look better if only the bottom part was yellow, top part black, like various 350s have. Just enough to fulfil 1m2. Full black or full yellow are a bit much. The mock up at Tyseley, as seen in the third picture, three posts above, has this design but with orange.
py_megapixel
5 Nov 2018
Northern England
I don't know what's with this sudden trend of not putting TOPS numbers on the front. In the past it's only been on units with very streamlined fronts, such as pendolinos and voyagers, which don't have a sensible place to put it on the front. But now many if not most new rolling stock deliveries seem to be have it in tiny letters on the side. TPE even reliveried older rolling stock with it in a different place.
I know the railway isn't built for spotters, but still... why change a perfectly good standard?
Speed43125
20 Jul 2019
Dunblane
Perhaps the numbers give the trains a sort of 'utilitarian' look that is outwith the brand TOCs want to present?
There's a ban on 2+ people in a cab, so no TOC is able to do training that involves it. While there are other aspects that can be covered, there's not much point if they would lapse before the rest can be completed.
Slightly OT, but how long can they keep that up before training starts lapsing?
Apedlar12
13 Apr 2017
I guess covid may have some part in the non testing ' but WM metro have been training drivers on there route daily for over a month so no problem with drivers and instructors in the cab so not problem working rules wise.
And while takeing these photos of the 196 a got talking to 2 workers at the depot who said the 196 arrived two months ago !
And no testing has started has there seems too be a bit of a differnce of opinion between CAF and WMT about how testing should be done.
Odd it's been here for 2 months and it's not made a few runs out Stratford or whitlocks end like the 172s did.
I have seen this which looks like a test for the 196 and seems to be doing it all day today, tomorrow, Thursday and Friday but hasn't run today yet:
