Wiring LNER block instrument
reidacus
28 Nov 2023
Swindon
I've just picked up my first LNER combined block instrument for an up / down line but i'm failing at the first hurdle in trying to wire this thing up. After testing with a power supply, voltage across connectors 10 and 11 control the upper dial and reversing the polarity has the intended effect in switching between TOL and Line Clear. My struggle now is how to correctly wire up the bottom dial. I had assumed one of the rear connectors was a master 'power in' line, with the commutator deciding which other pegs to activate when turned to close the circuit but the combinations I'm finding are confusing me. If anyone has knowledge in this type of instrument and a simple wiring diagram, it would be greatly appreciated.
reidacus
28 Nov 2023
Swindon
So the diagram you pointed out seems like the closest match but I don't have pins 1,2 and 3 but I don't think that's of any big consequence as the unit has no bell anyway. If I pass a positive voltage through pin 9, connect pins 7 and 8 together and connect pin 5 to the negative power supply, the commutator successfully switches the down line dial to TOL when selected. If I however connect a negative voltage to pin 6, when the commutator selects Line Clear, the down line still flicks to TOL. I've tried different permutations but it probably comes down to my lack of fully understanding the diagram. Any ideas where I'm going wrong?
Ashley Hill
8 Dec 2019
The West Country
Perhaps the internal wiring needs modifying so the block reads over itself. That’s beyond my knowledge,someone here may know.
John Webb
5 Jun 2010
St Albans
The upper dial works independently from the switch as it is powered from the adjacent box.
The lower dial is worked from the commutator switch, but is normally in series with the indicator dial in the adjacent box, so there needs to be a connection from the output terminal connected to the lower dial back to the 'Earth' terminal to complete the circuit. Just one or two 1.5v batteries will be enough to work the dials.
reidacus
28 Nov 2023
Swindon
Thanks John. I'm using a variable power supply at the moment to give it the power it needs but my question really boils down to what terminal needs to be connected to what in order to achieve what you mention above as there's no indication what the output or earth terminals are. (I'm not doing anything with the top dial, only the bottom one).
PhilH
4 Feb 2017
If memory serves, this style of commutator doesn’t reverse polarity. It needs two batteries connected in series with a common centre tap and then uses positive or negative voltage (in relation to the common centre at 0V) to swing the needle to TOL or LC.
John Webb
5 Jun 2010
St Albans
Sorry, we've a couple of these on display at St Albans South, but have not tried to wire them up yet. I've not yet had a chance to look at the diagram referred to in post #2 above, so can't offer any further advice at present.
reidacus
28 Nov 2023
Swindon
Thanks all for the feedback. I'm going to look into the centre tap solution and i'll report back here once i've had a chance to do so next week.
John Webb
5 Jun 2010
St Albans
On the same subject.
How would I wire up a pair of block bells for display purposes only?
One side of a room to the other, not miles apart.
The 'back contact' of the tapper should be permanently wired to one side of the bell. The other end of the bell goes to the negative of the battery or power supply (you will need around 6v). The front contact of the tapper should go to the positive of the battery. The centre-point of the two tappers are connected together (terminals possibly marked 'L' for 'Line'), as are the two negatives to the bells commoned up. Indeed you can use one battery supplying the +ve and -ve to both bells and the connection between the tappers means that a length of three-core cable can be used with the battery at one end or the other. (Apologies I don't have a decent drawing to hand!)
