Windows 10 and laptop screen of death
miami
3 Oct 2015
Bevan Price
22 Apr 2010
What's the general consensus on Windows ten then ?
I've put off the upgrade for about as long as I can and think I have to make a decision !
I accepted the free upgrade from Win 7 to Win 10. There are good and bad points.
Good - it is a lot faster, especially at starting and shut-down. No more waiting several minutes for these processes (bet see below). Other software also seems to work faster than on Win 7.
Not so good - you get less control over what upgrades you accept, and less control over when upgrades start. So, if you are in a hurry to use the computer, but it decides to apply upgrades at the start - tough luck, you may have to wait several minutes.
Bad - on installation, it is liable to delete or overwrite any "driver" software of which it does not approve. It has also renamed one of my data directories (folders) a couple of times without telling me. No lost data, but the first time it happened, it took a few minutes to find it.
Caution. It does not like some file / disc utility software designed for earlier versions of Windows - the software appears to be still working, but produces a lot of "mistakes". For example, I had to stop using Norton Utilities to "clean" unwanted files from the computer or to correct "faulty / unwanted" registry entries.
Cheers. Sounds like more trouble than its worth to me.
DaleCooper
2 Mar 2015
Mulholland Drive
I'm sure it will get slower with time, all versions of Windows seem to have that built in. My Windows 7 is a lot slower now than when I first installed it.
mbonwick
26 Oct 2006
Kendal
In my experience, the quickest way to resolve Windows 10 issues is just to reinstall it completely. You just need to create a bootable USB/DVD using another computer, and then perform an upgrade install. Usually fixes most things.
It sounds very much like a driver issue - but without knowing exact model and hardware details it's very hard to diagnose. I know my HP Pavilion had some issues with Win 10 replacing the Intel display driver with an MS one, but that was easily fixed by reinstalling the Intel drivers.
