Wind Power and UK Energy Use
Krokodil
23 Jan 2023
Wales
rubbish! Scandinavia pretty well relies on them, I have contacts in N Scotland whose energy bills are currently 42p per day. Admittedly they have invested in triple glazing and (sometimes) run a WBS, but the heat pump does pretty well all they need.
Is that air source or ground source?
AndrewE
9 Nov 2015
air source I believe. If people read things like https://energy-stats.uk/heat-pump-myths/ they will realise that statements like "Heat pumps are expensive and only useful in some climates" is just disinformation. @AlastairFrazer needs to back up that assertion with data or personal experience. If his heat pump doesn't do what is needed then it was probably badly specified or just installed wrong/ineptly. Look at a HeatGeek qualified installer to see what can be done - which follows a proper analysis of your heating needs in the first place!
Krokodil
23 Jan 2023
Wales
My concern is that as my house is 200 years old and has rubble walls, an air source heat pump wouldn't manage. The garden topography isn't suitable for ground source. So I'm trying to improve the energy efficiency where I can and am installing resistive underfloor heating, which I'll try and power (partially at least) using GB-Sol's photovoltaic ersatz slates via a large battery. A heatpump would have to feed into a wet system which does bring the costs up a bit. I ditched the combi boiler and installed a cylinder, which by heating it off-peak I can do so fairly cheaply and it means that I still had hot water during the 32 hour power cut we had last winter.
I'm trying to be less reliant upon the stove for heating the house (as building a fire every night is a chore) and the bedrooms will be the next part of the house to regain central heating. I'd never remove it completely as it provides a useful back-up during power cuts, running the heating from the future power bank would run it down quite quickly.
Doing the downstairs rooms is a while off anyway. Those are likely to be a major job that will include digging up the floor slab to replace it with limecrete to allow it to breathe properly again. This will include foam glass aggregate insulation and the opportunity to lay wet UFH pipes without raising the floor level. That would be the ideal time to look at a heat pump for the ground floor, leaving resistive UFH in the bedrooms and bathroom.
Maybe you could try having a mini data centre system help heat your house, like this Essex home:
An Essex couple have become the first people in the country to trial a scheme that sees them heat their home using a data centre in their garden shed.
Terrence and Lesley Bridges have seen their energy bills drop dramatically, from £375 a month down to as low as £40, since they swapped their gas boiler for a HeatHub – a small data centre containing more than 500 computers.
Data centres are banks of computers which carry out digital tasks. As the computers process data, they generate lots of heat, which is captured by oil and then transferred into the Bridges' hot water system.
Mr Bridges, 76, says keeping his two-bed bungalow near Braintree warm was a necessity as his wife has spinal stenosis and is in "a lot of pain" when it gets colder.
"It truly is brilliant," Mr Bridges continues. "I'm over the moon that we got picked to trial this out. You can't fault the heating system – it is a 100% improvement on what we had before."
"You don't need to go to a sauna after coming here," Mrs Bridges, 75, adds.
The HeatHub was developed by Thermify and is part of UK Power Networks' SHIELD project, external, which aims to come up with innovative ways for low-income households to transition to net zero.
Through SHIELD, the Bridges also had solar panels and a battery put in, which have contributed to their savings.
AndrewE
9 Nov 2015
I will pm you (assuming I can make it work) with a link which might be helpful. In the meantime I can only observe that unfortunately - by the nature of things - there is least pv or other solar gain when we most need it!
People are finding that stand-alone air-to-air heat pumps are a good investment, even at 2 per house, and at last they are now included in Govt. subsidy shemes. Previously I believe they were excluded because it was thought that they might increase the load on the grid by drawing power if used for a/c - in fact a) this is when solar/pv is in surplus and b) it might cut NHS bills form old people, and others, getting over-heated!
Hence the value of BIG batteries and cheap-rate Octopus Flux (and other) tariffs...
A
Invest in a second shed....
with a pv roof...
What happened to the plans to use hydrogen as standard in boilers?
It died when they found out the number of gas explosions would be expected to treble, unless doubly redundant flow limiting valves were fitted to all gas supplies.
Even with that substantial expense, the number of gas explosions would be expected to be comparable to now.
Also the cost is astronomical, and the flames are transparent - causing interesting problems in the kitchen.
I am skeptical that the industrial capacity needed for meaningful retrofit and mass heat pump installation actually exists.
I think it'd be better to throw the industrial capacity at the supply side instead and 'brute force' the demand end.
jon0844
1 Feb 2009
Heat pumps are expensive and only useful in some climates.
Storage heaters (especially if installed in conjunction with a reasonably priced home battery solution) may provide a useful lower-cost alternative that could mop up spare electricity as suggested before.
Heat pumps are extremely efficient and plenty now are capable of delivering high flow temperatures that can negate the need for new pipework or radiator panels (but with a slightly higher cost of course).
Storage heaters may suit in some cases depending on tariffs, or perhaps if you have a good amount of solar. If export rates reduce in the future, the incentive to just sell off the solar generation in the day may wane, and if your batteries are fully topped up then why not top up the storage heaters instead? (of course, some people will just divert that solar into their car or run the washing machine etc).
Nicholas Lewis
9 Aug 2019
Reality is without the govt grant they are unviable for most homeowners. This year govt has gifted £300m for heat pump grants which will support 40k installations and you can be sure majority of installations will be for householders that are already well off as you still need to find upwards of 10k to undertake installation albeit depends on how much internal work is required. The current scheme will be supported upto 2028 and from next year they are adding in air con units as well with a 2.5k grant not sure if thats from the same pot or they've put additional budget on for that. So at best we may get another 80k homes converted which would c200k from this scheme. Of course commercial building owners will be doing their own installations and maybe some housing landlords but we are way off decarbonising space heating in the UK anytime soon. We already see year on year NESOs Future Energy Scenario report lowering the demand expected as electrifying is not happening at the pace forecast. Mind you just as well as the infrastructure build out is lagging behind.
As an aside what about heat stores eg big insulated tanks with immersion heaters instead of storage heaters for home heating?
takno
Verified Rep - Traksy
Heat batteries were added to the scheme along with the combined heating-cooling units.
Heat batteries basically are next-generation widgets which combine insulated tanks and storage heaters - they heat up a small tank of dense salt solution until it's really hot, which is space-efficient compared to a water tank and doesn't involve as much plumbing. That can then be used to heat up normal water in the same way as a boiler would. They seem to be available from a bit under £2k, so are much more achievable for poorer households, and are likely to lead to a larger number of households being converted for the same grant money.
Personally I'm all for combining heat batteries for water and some kind of storage heaters for heating. I also think air-to-air heat pumps sound like worthwhile tech. We seem to have an almost pathological obsession with installing small-bore pipes and naff radiators in the UK though. Presumably people just like drafts and cold spots all over the place, and enjoy the continuous racket of expensive copper pipes rubbing against rafters as they expand and contract.
Trainbike46
18 Sep 2021
belfast
You're assuming everyone is getting the full amount of £7.5K there, but that is very unlikely to be true, especially as the scheme now includes various cheaper technologies (e.g. the limit for air-to-air and heat batteries is £2.5k).
I don't believe the budget is changed. However, adding air-to-air heat pumps (which you refer to as "air con units", but their main purpose is heating, though they can offer cooling as well) is a very good move, as they are a relatively affordable way of installing heat pumps, especially for smaller properties and flats. If I owned my flat, I would be installing an air-to-air heat pump, as it is a really efficient way of heating a property, with low up-front costs (there are units available for as little as £500 excluding installation). One suitable for my flat is available for around £1500 excluding installation, with an SCOP of 4.0. So with the Boiler upgrade scheme, the cost can be very low for smaller houses and flats, even after including installation.
Nicholas Lewis
9 Aug 2019
OFGEM issue a quarterly report https://www.ofgem.gov.uk/sites/defa...rade_Scheme_BUS_Quarterly_Report_Issue_14.pdf the grants issued equate to nigh on 7.5k per approved application. Circa 65k households have received the grant at end of October 25 which shows the scale of the challenge to remove gas fired boilers.
Thats very cost effective and would be easily covered by a grant if you can get one.
AIr to air heat pumps mostly come with air conditioning functionality which disqualifies them under current rules.
I understand that they plan to change the rules.
Yes, that is my understanding too, but they are imposing income limits that will disqualify the vast majority of households.
Personally I was thinking about getting an air to air heat pump system, but I didn't want to surrender my boiler immediately - as a hedge on it not working properly and for hot water.
That made any kind of grant impossible.
takno
There was a lot of speculation about income limits before the budget, but I can't see any evidence that it's actually happened - the scheme still appears to be open to everybody.
Trainbike46
18 Sep 2021
belfast
The £2.5k grants (for air-to-air and heat batteries) are new, so wouldn't have been awarded in the past data you refer to, that will only include air-to-water (at £7.5k) and biomass boilers (at £5k). Biomass boilers are unpopular, and in my view should be excluded completely. the £2.5k grants will likely make up a very sizeable fraction of future awards after the announced changes are implemented.
Are they? I've not seen any announcements to that effect.
If it is happening I wonder how this will work with rental properties.
Most air-to-air systems don't offer hot water at all, so I wonder how that will interact with the current rules that require all heating and hot water be delivered by the new system.
Nicholas Lewis
9 Aug 2019
One year to the day after 22GW of wind power was achieved for the first time, 23GW has been reached, with a new highest generating value of 23.8GW
Circa 3GW was being constrained off at 1730 when this record generating output was achieved. So still more available but until Eastern Green Links are commissioned in 2029 getting to max attainable output wont happen anytime soon but as Dogger Bank builds out we should see 24/25GW at some point before then.
Trainbike46
18 Sep 2021
belfast
There is reporting that the Eastern green link 3&4 will be accelerated, with delivery in the early 2030s instead of the late 2030s, and that this will lead to reduced curtailment of wind power.
(Ps does anyone else have an autocorrect that changes wind into wine? Or is it just me? )
Those projects are just going to run into the offshore HVDC bottleneck that is delaying the existing projects.
Trainbike46
18 Sep 2021
belfast
The article says they're doing this in part to ensure stuff can be ordered ahead of orders for the massive EU grid upgrade projects that are coming, preventing even more severe delays?
Class 317
7 Jul 2020
Cotswolds
Correct this should ensure earlier delivery with key components being ordered earlier.
AlastairFraser
12 Aug 2018
Heat pumps may be quite efficient, but not suitable for everyone and the heat battery technology mentioned above may be better in the long run.
I agree that storage heaters will work well with solar and battery solutions.
Solar and battery solutions is probably something that we should subsidise more as a country, we need to provide some decentralised power sources to avoid stratospheric grid upgrade costs, and encouraging local generation of renewable power is good news for us all.
We don’t need to subsidise, people just need to do the maths. I had an esitmate recently and payback was 7 years. Or put another way, around 10% rate of return.
AndrewE
9 Nov 2015
I think a certain amount of subsidy would be justified if it helped reduce curtailment which costs us a lot of money - and the grid upgrades, even the east and west sub-sea cables won't be ready until the next decade or later. The Octopus tracker https://wastedwind.energy/2025-12-14#why-buy-twice shows a figure of £1.387 billion so far this year, which is a lot of money per head.
Hence putting as many batteries as can be managed across the country wherever the local distribution network can handle the surplus will encourage people to mop it up at a low or even negative price and reduce the subsequent peak demand with negligable infrastructure work (i.e. cost.)
Do we even have the workforce to scale this up on top of all the other building projects lined up?
AndrewE
9 Nov 2015
I would have thought that domestic sparkies could adapt to this limited-scope initiative quite easily. If there is a shortage of them, then lots of apprenticeships would double the numbers every few years, especially as it could be a long-term project and on top of that the skills would be expandable to solar pv and the full breadth of domestic work to make a decent career.
Certainly we have more capability for solar/battery installs than we do for heat pump and other housing retrofit at the moment. It's an actual industry. I had some installed in November 2024, and it proceeded so fast I actually had some minor cash flow issues with the payment schedule!
The IET is moving towards approving "plug in" inverter systems for use in flats etc where the panels would be put on the balcony but need no structural alterations.
With that sort of system the work required would fall yet again.
